Posts: 8837 Joined: Sun Feb 24, 2013 10:20 am
Post
by ciclo » Fri Nov 27, 2015 7:47 pm
CNK wrote: One more question .. Is the BCM 6R0 937 087 K is compatible with cruise control?
Yes.
I do not understand what you mean exactly.
What wires?
CNK
Posts: 634 Joined: Mon Apr 06, 2015 10:18 pm
Drives: 6R
Post
by CNK » Fri Nov 27, 2015 8:41 pm
What wires?
I was thinking about CCS wiring to my 1.4 85 like yours to 1.2 TSI.
It's possible to 1.4 85KM:
https://www.youtube.com/watch?v=UT2Jkb77uZ8
It's the same wiring set?
Post
by ciclo » Fri Nov 27, 2015 9:05 pm
The cruise control system of my R-line is from factory.
And yes, the wiring you need to install CCS on your 1.4 has to be in the same way as you see in the previous link (made by ciclo
1.4 85ps july 2011
ECU
http://www.uk-polos.net/viewtopic.php?f ... 45#p502036
CNK
Drives: 6R
Post
by CNK » Sat Nov 28, 2015 2:35 pm
Thanks!
My car is from July 2011, but the tenth letter of VIN is C, so it's 2012 model. Can I check my ECU number in VCDS?
sendoc
Posts: 31 Joined: Wed Oct 07, 2015 11:20 pm
Drives: polo match 1.4 (6R) & Toyota Avensis T3
Post
by sendoc » Sat Nov 28, 2015 5:37 pm
ciclo wrote: sendoc, normally 1.4 petrol (non BlueGT, non GTI) have a 80-pin ECU.
The cruise control pin in the ECU 1.4 is the T80 / 24 .
engine code (CGGB) and model year B 1.4 6R.
Hi cilco
6RD 953 503 J - I saw this on aliexpress website.
Will this stalk fit my Polo ?
Post
by ciclo » Sat Nov 28, 2015 9:34 pm
sendoc wrote: ciclo wrote: sendoc, normally 1.4 petrol (non BlueGT, non GTI) have a 80-pin ECU.
Hi cilco
Hi snedoc...
Do not know, we need to know more information about your 6R.
Post
by ciclo » Sat Nov 28, 2015 9:40 pm
CNK wrote:
Thanks!
All 6R which are manufactured in July is the following MY.
Yes, you can check the ECU with the VCDS.
CNK
Drives: 6R
Post
by CNK » Sat Nov 28, 2015 11:01 pm
So probably it's my ECU number: 03C 906 024 CN
Address 01: Engine
Protocol: KWP2000
Part No: 03C 906 024 CN
Component: CGGB MM4HV 8994
Coding: 0000071
Shop #: WSC 00788
I bought this stalks:
https://www.dropbox.com/s/e9uq7sm179t7r ... 8.jpg?dl=0
6R0953521B + ring 6R0959654, according to your instructions
I hope that this stalks will work properly.
But first I need to go to my friend to coding my new instrument cluster
(In Poland it is not possible to coding new instrument cluster in Volkswagen Dealership..
hmthakur
Posts: 148 Joined: Sun Apr 05, 2015 6:54 pm
Drives: Polo gt tsi 1.2 dsg
Post
by hmthakur » Sun Nov 29, 2015 1:02 pm
Hi CNK,
From where did u order these stalks ?? Are they new or used?? I have to order them for my tsi
CNK
Drives: 6R
Post
by CNK » Sun Nov 29, 2015 1:43 pm
hmthakur wrote: Hi CNK,
Hey. They are used (from Polo GTI 2013). I bought them on online auction (
http://www.allegro.pl/show_item.php?item=5126319702 )
Post
by ciclo » Mon Nov 30, 2015 6:35 am
CNK
Drives: 6R
Post
by CNK » Thu Dec 10, 2015 5:57 pm
Could you help me? I changed the instrument cluster and stalks, plugged cruise control and now I have error:
Error stabilisation control (ESC) when I press the gas pedał..
https://www.dropbox.com/s/d8xmj4r4tbs9y ... 5.jpg?dl=0
CNK on Fri Dec 11, 2015 12:44 am, edited 1 time in total.
CNK
Drives: 6R
Post
by CNK » Thu Dec 10, 2015 11:41 pm
Thanks, I tried this, but it didn't work...
my log from VCDS:
VCDS Version: Release 12.12.3 (x64)
Data version: 20140905
Friday,11,December,2015,00:29:44:30570
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 77
VIN: WVWZZZ6RZCY019098
37-Navigation -- Status: Malfunction 0010
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 CN HW: 03C 906 024 BH
Component: CGGB MM4HV G 8994
Revision: --H09--- Serial number:
Coding: 0000071
Shop #: WSC 00788 648 00255
VCID: 6CD1B4F24CFC9D7E575-5072
1 Fault Found:
18038 - Accelerator Position Sensor (G79)
P1630 - 000 - Signal too Low - MIL ON
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 127
Mileage: 43261 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Bin. Bits: 00000100
Load: 0.0 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 78.0°C
Absolute Pres.: 1009.8 mbar
RPM: 0 /min
Readiness: 0010 0001
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210224E3216E00BB842524EB84D900401300
VCID: 871B6B5E325ADE265A7-80D2
2 Faults Found:
18265 - Load Signal
P1857 - 008 - Error Message from ECU
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 127
Mileage: 43357 km
Time Indication: 0
Date: 2000.14.00
Time: 00:24:10
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3310
Hex Value: 0x13B6
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
01314 - Engine Control Module
013 - Check DTC Memory
Fault Status: 01101101
Fault Priority: 0
Fault Frequency: 1
Reset counter: 127
Mileage: 43357 km
Time Indication: 0
Date: 2000.14.00
Time: 00:24:10
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3367
Hex Value: 0x13B6
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326D6A8A6D580B8E5D9-8067
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0256
Revision: BF046001 Serial number: 0434 158110732
Coding: 3CB02BBF08F32400923808002C2B0CD100C0410F60040000200000000000
Shop #: WSC 85046 004 02308
VCID: 45872156CCD68C36E8B-8010
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 1K8 951 171 A HW: K89 511 71A
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 08BC32
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00NXZLZ
Coding: 003232
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9D126AEDC8634E059-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB40570INGS61HS
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB405R0ILP041NW
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB404P0K4DOJGD6
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB404P0K4DOM92Z
Part No SW: 6R0 920 870 CX HW: 6R0 920 870 CX
Component: KOMBI H05 0608
Coding: 140A00
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 8D1759765C26B47660B-80D8
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0256
Revision: BF046001
Coding: 002200
VCID: F0E9208223D4F99EEBD-80A5
Component: IMMO H05 0608
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADD32EA0D08034EA59-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660186144
Coding: 010000
VCID: 295F8DE6408E4856EC3-807C
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 R HW: 1T0 035 680 R
Component: RNS-MID H23 6276
Revision: AB001001 Serial number: VWZ6Z7P2234584
Coding: 00000400000000A20000
VCID: 3D7749B6A406C4F6B0B-8068
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V12 8195
1 Fault Found:
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 27
Reset counter: 127
Mileage: 43256 km
Time Indication: 0
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6B63FEEA6A2666327-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 27
Reset counter: 127
Mileage: 43256 km
Time Indication: 0
Address 77: Telephone (J412) Labels: None
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 025 0983
Revision: -------- Serial number: 35502105249241
Coding: 020100010101010000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: N/A
VCID: 254781D624966C36C8B-8070
No ASAM data for: "EV_UHVPremi" (VW25)
End ---------------------------------------------------------------------
Post
by ciclo » Fri Dec 11, 2015 8:16 am
I suppose that firstly was installed the instrument cluster and at this moment had no problem.
What ring of steering column has installed, the original or the which was bought with the stalks?
Check the ECU connector, all the contact terminals must be firmly seated in its slot.
... also verifies that all cables for Cruise Control System (T41, BCM, ECU) are in the correct slot.
