Alarm/Central Locking Problem
MarkN
Drives: VW Polo 2003
Post by MarkN »
Hi everyone, I've had this problem a few years and no mechanic has been able to sort it, hopefully someone here will know the issue
When I unlock the car, the alarm will sound if any of the passenger doors or boot is opened before the ignition is turned on
The alarm will also sound if I enter the driver's side and don't start the ignition within 20-30 seconds
This is so annoying, if anyone has any ideas of how to fix it, I would be extremely grateful
Mark
alexperkins
Site Admin
Re: Alarm/Central Locking Problem
Post by alexperkins »
could be a faulty switch in the drivers door
Have you got remote central locking?
Is it a factory fit alarm?
MarkN
Post by MarkN »
It's a factory alarm. I don't have remote central locking so have to unlock all doors from the driver door
I was thinking installing remote central locking might help but not sure?
alexperkins
Site Admin
A remote central locking kit may well work around it
rclick.co.uk do some really good quality kits and great prices
Ah, so I think that that "feature" is just one of VAG's way of doing things, I'm sure if I were to use the dumb key to open daughter's late 2009 Ibiza (instead of using the remote key), the same thing would happen. It was not always that way in the past for most cars - well not in my experience of Fords and Vauxhalls - but then they only had manual central locking - no remote function on key.
Just a thought, are you sure that that car did not leave the factory with remote central locking and over time someone has lost the original keys with the remote function and just bought a cheaper basic key for the car?
alexperkins
Site Admin
Like RUM says, normally its remote central locking if you have an alarm
A scan with VCDS would confirm if its got a central locking enabled controller.
ct1996dub
Drives: mk4 9n
Post by ct1996dub »
hi have you tried getting some one to plug in to your vehicle to check for faults ?
alexperkins wrote:could be a faulty switch in the drivers door
I've chopped out a bit of alexperkins original posting, but, despite what I posted earler, I think that what is above still could be your problem.
