I removed the fuse on the 57 mark and all the light bulbs work perfectly.
Here is an autoscan from VCDS:
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Saturday,26,December,2015,14:53:59:62939
Chassis Type: 6R (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 44 56
VIN: WVWZZZ6RZAY263597
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYB) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 AH HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 9970
Revision: --H13--- Serial number:
Coding: 00254016002400080000
Shop #: WSC 124697 483 00190
ASAM Dataset: EV_ECM16TDI02103L906023AH 003010
ROD: EV_ECM16TDI02103L906023AH_VW25.rod
VCID: 6CD7223B877E2C7E58B-8039
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 049 HW: 0AM 927 769 D
Component: GSG DSG AG7 402 9060
Revision: 00040024 Serial number: TFK01004030233
Coding: 0000020
Shop #: WSC 23988 000 1048576
VCID: EED3A833FA625E6EF6F-5000
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AF HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0005
Coding: 210228E3417300B5842A14EB82D800421300
Shop #: WSC 02069 000 00000
VCID: 820BEC8319FA4A0E027-80D7
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Part No SW: 6R0 907 044 B HW: 6R0 907 044 B
Component: Climatronic H08 0305
Revision: V0000000
VCID: 326BFC436DDABA8E527-8067
1 Fault Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground - Intermittent
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 103
Mileage: 16596 km
Time Indication: 0
Date: 2000.14.13
Time: 09:07:05
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 092100027
Coding: 3CB02BBF48A10000013806003CAB0FD00080410F60842000200000000000
Shop #: WSC 07150 298 85912
VCID: 3E73D873A9826EEEA6F-806B
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 040410 05 54 0403
Coding: 0005F3
Subsystem 2 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T
Component: J387__TSG_BT 006 0902
Coding: 08BC30
Subsystem 4 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Coding: 08BC32
Subsystem 6 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Coding: 08BC32
1 Fault Found:
00901 - Back-Up Lamps
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 17170 km
Time Indication: 0
Date: 2000.14.25
Time: 16:56:07
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 HW: 6R0 919 475
Component: PARKHILFE 4K H07 0008
Revision: -------- Serial number: 71391009039009
Coding: 100101
ASAM Dataset: EV_VW250ParkiAssis2 S01006
ROD: EV_VW250ParkiAssis2.rod
VCID: FBF5916772103BC6411-80AE
Component: VW10Airbag00G H08 0020
Revision: -------- Serial number: 003GX0014B1Q
Coding: 003047
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4A9B84A3ED4AD24E0A7-801F
Crash sensor for side airbag; driver side:
Serial number: 3572SRB40000B22CDAFN
Crash sensor for side airbag; passenger side:
Serial number: 3582SRB40000B238A2E9
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB405D6Q5D6GOR9
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB405F6Q5D6I8N.
Part No SW: 6R0 920 861 D HW: 6R0 920 861 D
Component: KOMBI H13 0024
Serial number: 00000002312652
Coding: 140E00
Shop #: WSC 12469 483 00190
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01004
ROD: EV_DashBoardUDSJCIPQ25_VN81.rod
VCID: 3663C05389B2A6AE7EF-8063
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 D
Component: GW-K-CAN TP20 0207
Coding: 002200
VCID: F0EFB64B2356489EE43-80A5
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 10834 km
Time Indication: 0
Date: 2061.14.28
Time: 08:54:24
Address 25: Immobilizer (J285) Labels: 5K0-920-xxx-25.clb
Component: IMMO H13 X005
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
ROD: EV_ImmobUDSJCIPQ25_SK25.rod
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F6DF537EAE897663D9-807A
Address 56: Radio
Cannot be reached
End ---------------------------------------------------------------------
I hope I did everything you said I need to do.
Thank you again
