Hahah, maybe R is the sixth geariichel wrote:funny how the guy has a very large dutch accent as well as calling a 5-speed manual a 6-speed manual LOL
- CNK
- Drives: 6R
yes, because it's a polo Reverse-line
It is already solved the enigma of buttons. The number 2 (if possibleCNK wrote: I am also plans to install ambient lights in footwells, but I want to do it like in the Passat CC (two color: white & red)
Nº2---5G0959442Q
For ambient light (red):
A relay:
1 signal from T73b/7 BCM
2 Ground
3 Input +30
5 Output to ambient lights.
White, the connections are the same like in the dome lights.
what about 6C0959442C?
PR codes for flat bottom steering wheel + cruise control 8T2
- CNK
- Drives: 6R
I meant footwell lights like this:ciclo wrote:CNK wrote:White, the connections are the same like in the dome lights.
(Skoda)
They are factory-installed in the Passat CC
open doors:
closed doors and lights on:
These are photos from the Golf 5
Exactly.CNK wrote: I meant footwell lights like this:
https://www.youtube.com/watch?v=ekZ62slNltA
They seem to be the same buttons. (sports steering wheel) ... I have not had time to verify.iichel wrote:what about 6C0959442C?
My ref number is also to DSG.
iichel wrote:
- CNK
- Drives: 6R
I've heard that red light can be connected to the gray cable from cigarette lighter socketciclo wrote:Exactly.
In such case you will have the ambient lights lighted whenever you start the car, day and night, bad business. You need 58 signal, not +15 signal.
- CNK
- Drives: 6R
Hmm .. Backlight lighter lit only when lights are turn onciclo wrote:In such case you will have the ambient lights lighted whenever you start the car, day and night, bad business. You need 58 signal, not +15 signal.
In Golf 5 it is grey-blue cable so I think in Polo it is similar..
You're right, but that signal is 58d,... and not is the same as 58.
- CNK
- Drives: 6R
Could you tell me what is difference?ciclo wrote:You're right, but that signal is 58d,... and not is the same as 58.
For example:
58d ... interior lights through dimmer.
58 ... license plate light, you need this signal to activate the relay.
- CNK
- Drives: 6R
But when I connect it to lighter (grey-blue), I will be could change light through dimmer
I've seen that in other cars and it works well
