One fog light always on??
georgebentham
Drives: Polo 6C GTI
Post by georgebentham »
Hi all,
I've noticed this morning that the passenger side foglight is on all the time when the lights are on? (It's a new GTI)
Is there a reason for this or do I have a wiring issue?
The car is only 3 months old I'm gonna go into VW for someones head if there is wiring issues already!
Thanks in advance :D :D
vc-10
Re: One fog light always on??
Post by vc-10 »
Are you sure it's not the cornering fog?
vc-10 wrote:Are you sure it's not the cornering fog?
+1 ...
nats148
Drives: 2015 1.8 GTI - Golf Anniversary
Post by nats148 »
+2 just what I was going to ask :)
Sent from my iPad using Tapatalk
Guy
Drives: GTI
Post by Guy »
This confused me at first too. I'd like to switch the whole cornering fog facility off. But there doesn't seem to be a menu entry for it.
Is that something a dealer could do?
Ricmondo
Drives: Polo Blue GT
Post by Ricmondo »
I've found the cornering light facility to be really useful, not only to light my way but also to warn pedestrians just before I mow them down.I can't imagine why you'd want to disable it but we are all different and that's what makes life interesting isn't it.
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
I'm with Richmondo on this one... I LOOOOOVE the feature. Makes visibility around corners at slow speed perfect. :)
Scott Bounce
Drives: Polo 6C GTi
Post by Scott Bounce »
You can turn it off in the Car Setup... I think it resets each time though.
georgebentham
Drives: Polo 6C GTI
When is this supposed to be on then? because I was just sat on my driveway the other day and it was on then.
Is there a sensor on a certain amount of steering lock that turns them on?
People at work keep telling me I have a light out when I'm pulling into the car park :roll:
It should only come on at low speeds when turning, I have a feeling that maybe both come on briefly when reversing - that is based on what I've noticed with daughter's late 2009 Ibiza and what I've read.
If you are turning into spaces and "keep" some steering "on" they might be staying on after you have stopped, I've only ever noticed them coming on when cornering at low speed with wife's Polo.
If you have a problem, I'd afraid that it will probably not be a wiring problem but some control problem - that is if it is not just doing what we are describing.
Edit:- BTW if not said already, only one side will normally come on while driving slowly, and probably when in reverse.
Ricmondo
Post by Ricmondo »
And when you use the indicator, turn signal if you come from the wrong side of the pond.
JackM_24
Drives: Soon to be 2015 Polo GTI
Post by JackM_24 »
georgebentham wrote: People at work keep telling me I have a light out when I'm pulling into the car park :roll:
I too hear this every morning, more so now just to take the p***
Maybe it's the new function of static cornering lights when reversing, this function is activated by default in the new VW models. (if possible)
I have activated on my 6R and I think it is very useful for maneuvering in tight spaces with poor illumination, to avoid scratches with the columns, walls, etc ... in front corners of the car. :lol:
lancslad1985
Post by lancslad1985 »
People always used to tell me on the way into and out of work my fog lights were on. It's because I was turning or reversing. It's a pretty cool function and something I wish my new car had.
