[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 ciclo's Polo. R-line 1.2 TSI 90hp 119gr.🤝 - Page 129 - UK-POLOS.NET - THE VW Polo Forum
I need your help for installing Ultrasonic sensor alarm polo. I collect required equipments in the picture for the sensor(1) and alarm system(2), but ı need to know that should I need VCDS coding for activate this system or key recognition etc.? If I buy these parts and connect them with wires is it work? Should I connect them BCM? I appriciate for your help.
Sensor
pin 1
pin 2 GND
pin 3 T73c/15 (BCM black big connector)
pin 4 Permanent +12V
Horn
pin 1 T46b/25 T46b = middle connector, the smallest on the BCM
pin 2 GND
pin 3 Permanent +12V
Deactivation button (not obligatory)
pin 1 T73a pin 38 (BCM big white connector)
pin 2 T73a pin 37
pin 3 T73c pin 69 (connect with existing wire)
pin 4 to brown/black cable from centre reading light. But I don't know to which BCM connector it goes
For coding, I don't know.
hello ciclo
This button is unique to the polo 6r? 6RU927122
I want to install a button to activate the OPS without having to put the reverse, and this button is ideal for this purpose.
thank you
Sensor
pin 1
pin 2 GND
Horn
pin 2 GND
pin 2 T73a pin 37
I can't find any words to say... Your're real master icchel !!! Thank you and ciclo for your all effort to help for wv end-users... I'm sure you're better than the most of WV services in my country I share my info and pictures after I installed to the car. In addition to this, I didn't see alarm deactivation button for polo in the carprog2 program schemes. Dou you know where is the connection diagram of this system? (Anyway it is not mandatory ı will not use it so then)
the button is part number 6Q0962109B
you need the door sill trim LHD 6R4853371H (left, 5-doors, with alarm PR code 7AS) or 6R3853371A (3-door, I'm not sure it makes a difference for 3 doors?)
connector is 8E0971832
try security access for PDC module and make sure you have latest VCDS version
this error I don't know about. but that's all google shows.
What PDC module? I do not have parking sensors. I've tried 2 different pcs and the VCDS 12.12 and 14.10.2. See the scan I made and the modules that have installed please.
