Polo 9N/9N3. CCS. Stalks + steering ring + wiring + support. SOLD
Only shipping to Europe.
To install POLO 9N/9N3 CCS you need a BCM 6Q0, 6Q1. (you can check with VCDS)
Exceptions:
BCM 6Q2 NO support this function.
1.2L MPI HWY (47 kW / Simos 3PD) ECU NO support this function.
Read here: http://wiki.ross-tech.com/wiki/index.ph ... tting_(9N)
You buy exactly what you see in the pictures.
Stalks (used. 2013/14)
With CCS + Trip computer. They work perfectly in 9N/9N3 (without ESP)
Steering ring (used. 2013/14)
For models without ESP.
Special wiring (new. OEM)
Additional stuff
In most cases you only need the plastic ties to hold the wiring.
Click on pictures
More info here: http://www.uk-polos.net/viewtopic.php?f ... 10#p477801
Some notes about the condition of the stalks:
If I increase the brightness of camera the marks are not visible.
The stalks have only two years of use, all internal switches work perfectly.
You will receive a full technical support to install CCS correctly. It is necessary codify with VCDS (for example).
Gift
Interface 11.11.3, for all VW Group models up to 2011-2012. (Vista, XP, W7)
Perfect to codify CCS POLO 9N/9N3 and much more.
STALKS + STEERING RING + WIRING + ADDITIONAL STUFF + INTERFACE + TECHNICAL SUPPORT FOR INSTALLATION (via email)
Price: 70,00 EUR = 51,01 GBP ... http://themoneyconverter.com/
Shipping Cost and Paypal fees: included in the price.
Shipping: only to Europe. Tracking number.
Payment: By Paypal (full safety).
Exceptions:
Additional stuff
Click on pictures
Gift
Re: Polo 9N/9N3. CCS. Stalks + steering ring + wiring + support.
Hi mate I am interested in this item I have a polo 9n gt tdi how do I check this will work thanks
Hi Gazza24, do you have VCDS?
If you send me an autoscan I can tell you if it would work in your Polo 9N GT TDI.
VCDS is also necessary to encode the ECU. Very easy.
If you do not have VCDS (no problem), you can check the reference number on the Cent. Elect.:
Eg:
http://pimpowski.de/images/lolek/tempom ... %C3%9F.jpg
http://i45.tinypic.com/352j8nr.jpg
This part is beside the pedals, you can take a picture with the smartphone.
Please, where are you from? Shipping only to Europe.
Eg:
I had to slightly modify the price due to the increased weight of the package with the gift and consequently the shipping costs. Crystal clear.
I maintain the initial offer to Gazza24 if he does not want the gift.
I do have vcds but I can't find ny cable I will look for the code later I'm at work atm
OK, don't worry, when be possible for you...
Initial offer: 55 € http://themoneyconverter.com/
Sorry mate decided to invest my money else where thanks tho
Hi Gazza24, thank you very much for letting me know, it is very important to me.
With all sincerity, if you need my help with this installation feel free to ask as much as you need to know.
Again, thank you for informing me.
Is this still for sale ?
I fancy fitting cruise control to my 9n GT tdi , and will take it !
Hi Moltenice. Yes, it is still for sale.
To avoid confusions with the price due to I edited this sale some time ago:
STALKS + STEERING RING + WIRING + ADDITIONAL STUFF + INTERFACE + TECHNICAL SUPPORT FOR INSTALLATION (via email) + SHIPPING + PAYPAL FEES = 70€
Do you have a VCDS auto scan from your 9N? With auto scan I can tell you if these stalks fit in your 9N GT TDI.
Otherwise, please can you tell me the reference number of your BCM? Thanks.
Eg:
This part is beside the pedals.
Eg:
Hello,
It's 6Q0,
Presume the dash needs to come out to fit this ?
It's 6Q0,
Ok, so no problem to install on your 9N.
No need to remove the dash. I didn't it on my 9N3.
To reach the white connector... (please take account that for 9N RHD are mirror images, but it's the same process)
then you see this...
You can enter the arm (rubber arm ), this is not easy, nor difficult, it required a little patience, nothing more. It took me 3 minutes.
On these links you have more info and pictures:
viewtopic.php?f=56&t=58703&start=210#p477801
http://pimpowski.de/GRA_nachruesten_pimpowski.htm
http://workshop-manuals.com/volkswagen/ ... ical_data/
I send you a private message with my email if you want to contact with me for payment, also to installation help if you need.
Send me a pm, I'll take it!
Iv sent you an email .
Ok, email received and replied.
I ask you my sincere apologies for the delay in my reply. I'm very sorry.
