No, I don't have these buttons since I have a multifunction steering wheel to operate the pages of the screen
On the older clusters sold in India, there's no CC led. So no notification comes up.
T41/2 and /3 go to steering angle sensor (slipring) and not to the stalks, right?
aayushnair
- Drives: Skoda Fabia 1.2 tdi
I'll check over the weekend to see if those slots are taken.
This will tell me if the wiring already exists right?
Cheers,
Aayush
Cheers,
Aayush
There is no cc led on my 2013 polo cluster. That is really cheap of vw.
I thought of soldering one but then I came across comments on the net stating the cc light stays on till the cc switch is on and not when the cc is actually engaged.
To fix the issue one needs to reflash (?) the EEPROM with suitable software (not vcds). But I am not an expert in this area and on otherhand I did not have time/ required software, importantly being single driver of the car I'd know it anyway.
aayushnair
I gave it a go, added the wires, but it gave me airbag errors and the car wouldn't start, like as if the immo kept kicking in. So off came the extra wiring and cleared the codes for it to start working again.
Definitely not the same wiring for this cluster, anyway got the CCS to work and that's what matters, maybe a cluster upgrade soon.
If anyone can help with the no communication with instrument cluster error would be great.
Have to say though, without your guides and gannus pics this diy would've been super difficult. So thanks a lot ciclo and gannu.
Will write about my diy experience soon!
Cheers,
Aayush
Cheers,
Aayush
Hello guys!
Thanks to all and in particular to ciclo for Share the knowledge!
I have the question about part number for the stalks. I want upgrade a my Polo with CCS and TRIP-computer. According to ETKA I have to buy for my Polo (BY2013) the stalk with the partnumber 6R0 953 507C. On the Ebay I´ve found may stalks, who seems very similar with partnumber 6R0 953 521C. It seems to me that they are compatible. Maybe I'm wrong? Or, this number refers to angle sensor which is connected with the stalk?
Thanks!
Thanks!
Hi Werner, Welcome.
It's the same part, right for your Model Year 2013.
CCS+TRIP computer
6R0 953 507C individual part.
6R0 953 521C in combination with ring, 'from factory'.
CCS+TRIP computer
Perfect. Thank you!ciclo wrote:Hi Werner, Welcome.
CCS+TRIP computer
Can anyone help me ?
I've fitted cruise control to my polo 6r 2012 but it isn't working. Has anyone had the same problem and solved it ?
I've autoscanned it and this is my results
VCDS Version: Release 15.7.4 (x64) Running on Windows 8.1 x64
Data version: 20160216
www.Ross-Tech.com
Saturday,13,August,2016,16:18:18:26102
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZDY003866 Mileage: 91070km-56588miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CGPB) Labels: 03E-906-019-CGP.clb
Part No SW: 03E 906 019 M HW: 03E 906 019 B
Component: SIMOS11.1 H03 9487
Revision: --H03--- Serial number:
Coding: 00110016002400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12MPI02103E906019M 001008
ROD: EV_ECM12MPI02103E906019A.rod
VCID: 2E5310DF7172B34EDC-807A
1 Fault Found:
6118 - Cruise Control Switch (E45)
P0568 00 [039] - Implausible Signal
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 91078 km
Date: 2016.08.13
Time: 16:11:59
Readiness: 0010 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 230224E3216D00B5C42D24E884D700801300
VCID: 020B946F996AE72E68-8056
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 13
Reset counter: 29
Mileage: 88853 km
Time Indication: 0
Date: 2016.07.04
Time: 14:38:09
Hex Value: 0x0000
Hex Value: 0x8000
Hex Value: 0x1203
Hex Value: 0x2BB4
Hex Value: 0x6C7F
Hex Value: 0x7F7F
Hex Value: 0x7FF8
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 39793383B03C64F679-806C
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 140122207
Coding: 3CB829B808A10400002008C02F2B0C50F0C041FF60063040200000000000
VCID: 45814F73CCC410160D-8010
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1621
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1621
Coding: 18BC30
1 Fault Found:
00895 - Cruise Control Switch (E45)
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 33
Mileage: 91078 km
Time Indication: 0
Date: 2016.08.13
Time: 16:12:08
Component: VW10Airbag01X H10 0020
Revision: -------- Serial number: 003GX018CXN0
Coding: 003158
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4A9B7C4FEDDAFF6EE0-801E
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405P1C4LIG91J
Crash sensor for side airbag; front passenger side:
Serial number: 3585HRB405B1D5MSEPC1
Crash sensor for side airbag; rear; driver side:
Serial number: 3515RRB406317ABOJHOX
Crash sensor for side airbag; rear; passenger side:
Serial number: 3525RRB406917ABO5GLM
Part No SW: 6R0 920 960 K HW: 6R0 920 960 K
Component: KOMBI H04 0605
Coding: 440801
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3D712793AC1458D655-8068
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 002100
VCID: 70EFCEA7A3C6E5BE8E-8024
Component: IMMO H04 0605
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADBDCCF8D1A1F6EC0-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584584
Coding: 010100
VCID: 2A5B1CCF459ADF6E00-807E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6D0DDBEA78BA46D7-807A
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 186 L HW: 5M0 035 186 L
Component: Radio RCD310 004 0119
Revision: 00000001 Serial number: VWZ1Z2M2000558
Coding: 01000400020001
VCID: 35613FB39C2480969D-8060
End-------------------------(Elapsed Time: 01:45)-------------------------
Any help is appreciated
Many thanks
www.Ross-Tech.com
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91078 km
Date: 2016.08.13
Time: 16:11:59
Revision: --------
1 Fault Found:
Fault Priority: 0
Fault Frequency: 13
Reset counter: 29
Mileage: 88853 km
Time Indication: 0
Date: 2016.07.04
Time: 14:38:09
Hex Value: 0x0000
Hex Value: 0x8000
Hex Value: 0x1203
Hex Value: 0x2BB4
Hex Value: 0x6C7F
Hex Value: 0x7F7F
Hex Value: 0x7FF8
Revision: 0003SH02
Coding: 18BC30
Coding: 18BC30
1 Fault Found:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 33
Mileage: 91078 km
Time Indication: 0
Date: 2016.08.13
Time: 16:12:08
Coding: 003158
Coding: 440801
Revision: BF046001
Coding: 002100
Serial number:
Coding: 010100
Coding: 11250
Shop #: WSC 00788
Many thanks
Many thank Ciclo.
My information I have told me to pin 24 but have now put into pin 69 and works perfectly.
You're welcome
The world belongs to those who do different things with the same ingredients as the rest ... AND DARE TO SHOW IT!
VCDS Autoscan FULL was the key for the solution.
Enjoy it, YOU deserve it twice.
Hello . I have a problem. I bought a car from Germany and the car is the cruise control lever No. 6Q0 953 503 EJ and driver BCM 7H0 937 089F.
The VCDS is all encrypted.
Cruise control does not work and wipers at the first race.
Where to start .
What to look for.
Please help
The engine 1.6 TDI
Production Year 2012
We are asking for help.
Where to start .
What to look for.
Please help
The engine 1.6 TDI
