Goodo. Should work fine there
It does sometimes take 20-30 mins to pick up a signal first time around
Is it currently in germany somewhere?
How to upgrade your RCD-310 to a Sat-Nav RNS-310
- Bigtam
- Drives: Polo GTI 2016
Re: How to upgrade your RCD-310 to a Sat-Nav RNS-310
No bought it from a guy over on Briskoda and he is in Crawley and it comes up around that area
- Bigtam
Thanks for your help Alex.Just checked the Nav and the unit cant see any satellites will check it tomorrow and see if it works then if not will buy a new GPS aerial.Do you know what coding I have to do for to get the mic working on the steering wheel.
Sounds like its definately not receiveing the satellites then. The connections are quite fragile on them - thankfully inexpensive to replace though.
Afraid not without looking. Itll be in the long coding helper on the radio settings i imagine.
- Bigtam
Working now it was a dodgy GPS antenna
Polo1971gti
- Drives: Polo gti
Hi there links where to buy the microphone mine has never worked
Got to use my phone on loudspeaker when makin a call
My music does Bluetooth ok
