Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
ORiOn wrote:
Mart!n-GTI-DK wrote:
ORiOn wrote:I'm really interested on the radio!
If I find a good price I will definitely buy it! And with all your guys help, i'm sure one day we will make it work 100%! :D
There is a guy here in Denmark that can make it work. I got a quote of 16.500 DKK (£1742) for him to fit it in my Polo. (That includes a new BCM)
Do you know what bcm is needed?
Nope. Not many businesses tell's their secrets I'm affraid. :(
I guess the 7E0 937 090 since it has a gateway with address 5F
ORiOn
Drives: Polo BlueGT / Audi S5
Post by ORiOn »
I have the 7H0 937 090 (BlueGT), think it will work?
No you need 7E0 from transporter t 6
favi wrote:Do only these two controllers work for folding mirrors ( mirror engines 6R0959801BD Z0D, 6R0959802BF Z03 )? It's really hard to find those ones. I only found 6R0959801BD , it comes from vw Beetle. There is a big problem with the other one. Can anyone help? I have a mirrors regulator and mirrors from 6c. I hope that they are gonna work.
Read here http://www.polo6rfreunde.de/index.php/T ... ?pageNo=20 it may help.
wamba wrote:hi ciclo
I need your help please
I would add a second video input on my RNS 510
you know if there is an adapter for it
Hi wamba!
On these matters of not OEM parts I'm like a fish out of water.
Image luck with your search... :lol:
firegrafik wrote: So do you have coding information, that DRL works only when light switch on "Auto" position? And when it is on "0" position - the DRL is off.
It is not possible to code these two things at the same time because in AUTO position with the lights off by the light sensor is just like that 0 position. In this conditions DRL always ON.
iichel wrote:These are the functions of byte 23 that I know:
byte 23
bit 0 Alternative voltage supply for high beam and T58d (button illumination)
bit 1
bit 2 Cornering lights as DRL and LED DRL off - xenon only
bit 3 Low beam as DRL and LED DRL off - xenon only
bit 4 LED DRL off with handbrake on - xenon only
bit 5
bit 6 DRL active
bit 7 LED DRL off unilateral with indicator on - xenon only
Bit 5 Parking lights - full brightness (LED module)... and with light switch on parking lights ... if bit7 marked... Dim brightness when indicator is activated. :mrgreen:
Martin, I still have not found anything to Dimming the DRL when indicator is activated. :lol:
firegrafik wrote:
ciclo wrote: ... my question about T73a/9, T73b/69 is a simple curiosity. :wink:
Maybe one of both pins is related with ...
Fernando, have you found out what is the T73b/69 pin for?
Could it be the "out, power supply to T73b/45 and engine ECU" for CCS by MFSW?
It is very likely not...
Byte29 bit6 marked
Bus lin via T73b/36
In ECU can check that they are fully functional. http://wiki.ross-tech.com/wiki/index.ph ... ing_Values , http://www.ross-tech.com/vcds/tour/adv-meas-blocks.php
This way are recognized these CCS buttons in my BCM...
Jetta 2015 (with 7E0), T6 ... look for Auto scan from this models.
Byte17 it also is implicated...
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
ciclo wrote: It is not possible to code these two things at the same time because in AUTO position with the lights off by the light sensor is just like that 0 position. In this conditions DRL always ON.
Nevertheless, I believe that it is possible. I am just curios.
For example Skoda Octavia A5FL, which has BCM PQ35. Byte 26, bit 3. Change 0 to 1. The result: in "0" position the DRL are not working, in "Auto" position depends on RLS, there are or DRL, or headlights work.
firegrafik
ciclo wrote: Byte29 bit6 marked
Bus lin via T73b/36
Some moments isn't clear for me. Usually MFSW control unit lin-bus wired to T73b/17 like the door units. And activated by byte 9 bit 3 on 09-Centr.Electric. So there are some questions for now.
1) Do you mean, that for MFSW with CCS buttons there is necessary to change lin wiring to T73b/36( join to horn alarm lin wire), and to activate it, needs to mark byte29 bit6?
2) Will the all MFSW's buttons work properly in this case?
3) Once the CCS(GRA) had been activated at the engine's ECU (5byte, 5bit) will it need more coding changes?
Thank you for links. I am going to have a brainstorm.
Mart!n-GTI-DK
ciclo wrote:Martin, I still have not found anything to Dimming the DRL when indicator is activated. :lol:
But you remembered... I'm touched. :lol: :lol: :lol:
I see what you mean, but not all the functions on the PQ35 (golf platform) are also on the PQ25 platform.
For example:
- Automatic coming home
- Passenger side mirror dip in reverse
- US lights
- Footwell lights dimmable
firegrafik
iichel wrote: .......
Totally agree with you, iichel, but I can't say that this thing is a function. Just a switch :lol: .
There are many unknown bits in the 09CetrElectric, so I really hope to find the right one.
Perhaps it is also possible with PQ25..Image (Byte 23)
By the way, excellent video channel. :wink:
byte 23
bit 1
bit 5
bit 6 DRL active
Byte 23 bit 5 on
Byte 23 bit 7 on
Byte 12 bit 0 on
Switch in setting 0 -> LED bright + tail lights on (me like), DRL dim when indicator on
Switch to dipped beam -> LEDs dim
Locked
