Rear Disc size
Rear Disc size
Quick Question so i buy the right brakes - what size are the rears?
Re: Rear Disc size
I think it's 228mm but I would need to double check
Re: Rear Disc size
Front Diameter: 256mm
Thickness: 25mm
Centre Bore: 39mm
Rear Diameter: 232mm
Thickness: 9mm
Centre Bore: 39mm
Hoping this correct
Thickness: 25mm
Centre Bore: 39mm
Thickness: 9mm
Centre Bore: 39mm
Hoping this correct
Re: Rear Disc size
Just checked. 232 is correct
