ORiOn
Drives: Polo BlueGT / Audi S5
Post by ORiOn »
That's what i tough! Thanks! :)
Adam87
Drives: T5.2
Post by Adam87 »
[quote="iichel"
It will not be listed but i'm sure some people here, including myself, will be able to assist you with it.[/quote]
That's great, will let you know how I get on
Adam87 wrote:Great news ciclo [emoji106] I have a my15 T5 highline and will be retrofitting lane assist, bi-xenons, RLS, heated seats etc :wink: , I see that you retrofit the t6 BCM into the polo (7E0 937 090), will it work with xenons? Yes, perfectly. All I can see in etka is listed with halogen or led. Also Is there anything extra in instrument cluster to add? I believe there is no convenience menu? It only add a menu for driving assistants (when they are installed, I guess) .I have this cluster installed. Nice 8)
Adam87 wrote:Thanks for the reply iichel, would you say to use coding from 7H0 bcm for xenons or will it be listed in long coding? No problem. :wink: Is there any specific prefix after part no 7E0 937 090 * ***? Yes, uses this PDF to choose according factory equipment of your T5, and choose 7E0 BCM it has all the functions of your T5 Highline and those you want to add. I would choose the best. :)
Adam87, you know, more information means more help.
Do you have pictures of your T5 (interior and exterior)? Any link to another forum?
iichel wrote:It will not be listed but i'm sure some people here, including myself, will be able to assist you with it.
ORiOn wrote:Hey guys!
Is it possible to install original bi-xenons an a polo with 6R0937087B BCM?
Thanks! :D
The best to run correctly xenon headlights is to install one BCM Max. It is now much easier. :wink:
Any other option is undoubtedly worse.
Adam87
Drives: T5.2
Post by Adam87 »
Thank you ciclo, with regards the options list, do I have to write all the codes down and make a list or can I order a max bcm that is capable of all? My T5.1 GP is a highline so already has cruise, powerfold heated mirrors, elec Windows, front fogs,AC and I have had the new cluster fitted
Have now fitted roof rails and side bars since this pic
Adam87
Drives: T5.2
Post by Adam87 »
Also want to fit auto distance reg aswel [emoji6]
The more important thing is that the new 7E0 BCM is suitable for Central locking frequency (MHz) and for tail doors (rear wing doors :?:, sorry I do not know as they say in English)
For everything else you can choose (and highly recommended) the BCM that it is capable with all equipment available.(PR-codes A8M, A8Z)
ACC? (I also want it :lol:) but perhaps a new ABS/ESP unit with appropriate software is required, also other units. I do not know for sure because my knowledges are limited about ACC, but it sure is an expensive modification.
Adam87
Drives: T5.2
Post by Adam87 »
ciclo wrote:The more important thing is that the new 7E0 BCM is suitable for Central locking frequency (MHz) and for tail doors (rear wing doors :?:, sorry I do not know as they say in English)
433mhz is ok I'm guessing, which pr code is the highest spec? Or what is the difference between them?
I had a courtesy t6 with acc and now I want to fit [emoji3] I did take an autoscan of it aswel [emoji6], I think definitely BCM, maybe ecu and abs?
434 MHz
7E0937090A Z0J ...8IT+7Y1+8T0,8T1,8T2,8T3,8T5+3RD,3RE,3RF,3RG
or
7E0937090 Z4Y ... 8IT+7Y1+8T0,8T1,8T2,8T3,8T5+3RB,3RC,3RP
Check which fits with your T5.
I also have several T6 autoscan with all possible configurations, without CCS, with CCS on stalk, with CCS on MFSW buttons, with ACC, etc... :lol:
Adam87
Drives: T5.2
Post by Adam87 »
Ace [emoji106], it's the first one I need, will that support lane assist do you know? I can see it in the codes, I can send you the t6 autoscan if it helps you in anyway?
Can you help with coding to get mirrors to fold on key? Which number in LC do I need to change?
Spolos
Drives: Volkswagen Polo 6R Comfortline 2012
Post by Spolos »
Hi Ciclo,
I want to tell you how happy I am with the ch/lh and cables for BCM MAX! Everything works just fine without errors and stuff thanks again! This is for the people ho want to do also a BCM Max retrofit Ciclo is THE Polo Doctor!!!
Thanks man for all the help!
Spolos
gpeixoto109
Drives: 2013 Polo 6R 1.2TDI
Post by gpeixoto109 »
Spolos wrote:Hi Ciclo,
Spolos
Absolutely! He knows everything! :D Ahah
federicodrdpro
Drives: White Polo 6R TDI
Post by federicodrdpro »
edit
Last edited by federicodrdpro on Fri Apr 15, 2016 3:43 pm, edited 1 time in total.
federicodrdpro
edit 2
Last edited by federicodrdpro on Fri Apr 15, 2016 3:44 pm, edited 1 time in total.
federicodrdpro
ciclo wrote: Image
This is a small part of my big project, the best is yet to come. Patience.
Ciclo, why do you change this mirror with 7E0 857 511 G mirror? HBA not work with 1K8 857 511 mirror?
CNK
Drives: 6R
Post by CNK »
federicodrdpro wrote:
ciclo wrote:
ransonneil wrote:Is it The rear view mirror?
@ransonneil ImageBrilliant!
Yes, it works only with PQ35 BCM (e.g Golf 5, Golf 6).
Polo 6R has got PQ25, so ciclo used mirror from VW T6 ;)
Locked
