Solution needed for replacement for TPK
Willni
- Drives: Polo '14 6R, Golf 07' Edition 30
Re: Solution needed for replacement for TPK
rcd310 is just your basic radio unit with fm/am/dab
rcd510 is a touch screen unit with a 6.5inch touch screen but no handsfree but can have it fitted
RNS 310/315 is a 4.5inch touch screen with maps and bluetooth built in
rns510 is a 6.5 inch touchscreen with maps but no bluetooth in it but can be fitted to it
I have the tpk bluetooth kit vw offer that i don't use, but at this time i haven't removed the microphone for it yet (it's hooked up to the ignition and cba)
jambokaos87
- Drives: 2014 Polo R-Line
I am also looking for an all in one solution for my 14 plate Polo. A lot of the head units I've seen do not have DAB radios included which is quite important for me.
Willni
http://www.ebay.co.uk/itm/VW-RNS315-GPS ... SwQYZWv3Vvjambokaos87 wrote:I am also looking for an all in one solution for my 14 plate Polo. A lot of the head units I've seen do not have DAB radios included which is quite important for me.
something like that if you want bluetooth and dab built in
jambokaos87
Cheers Willni.
Is it a straight forward job to swap out the old unit? Would I no longer need the TPK Mount?
Very simple and yes the TPK can be removed
jambokaos87
Cheers mate. Ordered one now
MattBlueGT
- Drives: 2013 Blue GT
Jambo, did you order it from that eBay link?
MattBlueGT
Alex, so you don't need any part of the tpk system with the 315 as its all internal? Also, I don't know if I have a gps antenna so will I need to fit one with it?
You'll need a GPS antenna if it doesn't come with one plus a microphone if it doesn't come with one
jambokaos87
No mate, decided to hang fire until Friday (pay day)MattBlueGT wrote:Jambo, did you order it from that eBay link?
jambokaos87
Couple of questions that I have before I take the plunge:
1) Will my existing DAB aerial (for RCD 310) work with the new RS 315?
2) Will the installed mic for the TPK kit (seems to be tucked behind the tim of the driver's side A-pillar) work with the new unit?
Yes same connection and no you need the appropriate mic
I'll post a link shortly
Willni
Here's the link for the microphone (it will sit hidden in at the dome lights)
http://www.ebay.co.uk/itm/VW-RNS315-RCD ... SwZd1VaDzp
And here's the sat nav antenna (if it's magnetic just sit it onto the back of the unit and it will work, that's what I did)
http://www.ebay.co.uk/itm/SAT-NAV-GPS-A ... xyrrpTfL5O
Ta willni. Saves me looking
jambokaos87
Thanks very much guys
