6R BlueGT ACC retrofit
BlueGT_6R
Drives: Blue GT
Post by BlueGT_6R »
Hi all,
I've been thinking some time about a ACC retrofit. After a lot of digging i have come to the next conclusion;
It is possible with the right parts.
This is my current part list:
Steeringwheel (with DSG): 6C0419091K
Airbag (not sure): 6C0880201G
Steeringwheel wiringloom: 6C0971584A (not sure)
Steeringwheel electronics ??????????????
ABS-ecu: 7E0907375Q (T6)
BCM: 7E0 937 090 (T6)
Radar: 7E937090 (T6)
Or
Radar: 5Q0907561F (6C)
Mountingplate: 5Q0907461 (6C)
Bolts: N 10158605
Bracket: 5G0998561 (6C)
Cover: 6C0907225A ( for the 6C radar, no idea about the T6)
Lower frontbumper grill: ???
Now i am thinking of this, will the 6C radar work with an T6 BCM and ABS-ecu, or do i need the T6 radar, and will it fit :roll:
And do i need steeringwheel electronics after a rebuild, or can i keep those of the 6R? Someone care to elaborateAlso and share the needed part number?
Acording to Iichil i need to reflash the currect tacho to support ACC, is this possible with VAG CAN PRO? Any one an idea, otherwhise ill send them a e-mail
With kind regards,
PS, i'm sorry if i am in the wrong section :oops:
Re: 6R BlueGT ACC retrofit
moggel
the steering wheel will have the control electronics in it.
i think you'll need the radar from T6 since it's canbus controlled. the mqb electronics don't work well with the PQ25 BCM
you'll need to check the Z-codes for the BCM as well, since there is a difference between the ACC and CCS BCMs.
and don't forget the lower bumper grill with the hole in it.
i guess the radar should fit, since the t6 and the 6c radar do have the same dimensions, just a different frame behind it.
the only issue could be the bumper reinforcement bar, that on the 6r might not have the mounting holes for the radar.
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
Has anyone ever done this???
BlueGT_6R
Drives: Blue GT
Post by BlueGT_6R »
Martin, as far i can tell, no.
@ Ichill, will search for the z-codes :)
BlueGT_6R wrote:Hi all,
These references steering wheel and airbag not match. As you can see not have the same shape.
https://www.google.es/search?q=6C041909 ... 66&bih=643
https://www.google.es/search?q=6C088020 ... 66&bih=643
BlueGT_6R
Drives: Blue GT
Post by BlueGT_6R »
Good spot, thanks. Will look for a other airbag module
