Damn thought that would be the case don't really want to go for sideskirts as wellCNK wrote:But I bought sideskirts too
Without sideskirts it looks like a single stair between bumper and rest of car.
For example: https://scontent.fwaw3-1.fna.fbcdn.net/ ... e=572D24D1
CNK's Polo 6R 2.0 Shadow Blue
- Drives: Polo '14 6R, Golf 07' Edition 30
Re: CNK's Polo 6R 1.4
ciclo wrote:Therefore will be soon, let's see what happens.CNK wrote: Horn and buttons works, I will try to coding this on the new BCM.
Do you have the three bags?
By the way, Krzycho's Golf can be one of the best in its class around the world, I like it , your 6R follows the same path.
No, not yet. Yesterday in Poland was a day off from work, and today I ran out of time to go to the post office after work, so tomorrow I pick a mysterious package
BIG THANKS
PS. @ciclo It's possible to coding old type of key in 6R: http://www.uk-polos.net/viewtopic.php?p=509407#p509407
Old keys have smaller circuit board. So.. You probably now, what I mean..
- RekinPoznan
- Drives: 6R
Great mods
Success in further modes, I think of the directory to this forum is how you write one of the best .
the first modification for me, Xenon headlights with LED with succes , next in progress
Best Regards Chriss
Best Regards Chriss
Heheh, dziękówka! Miło widzieć tutaj kolejną osobę z PolskiRekinPoznan wrote:Great mods
Best Regards Chriss
Thx, in next future I will change my front bumper and maybe something else
Hi everyone!
I haven't forgotten about this forum!
I had no time, because I had been writing a master's thesis.. While others collect Pokemon, I collect parts for my Polo
Parking Sensor PDC Hole Drilling:
Magic package from @ciclo:
Thanks a lot Fernando!
R-Line Bumper in shadow blue color:
6RU Polo Sedan PDC button from @firegrafik:
Thanks Alexander!
Chrome Headlight Side Mirror Window Trunk Switches (Golf 6/Passat B7)
new vs old:
VW Shark Antena Negro GPS/GSM (3C0035507N):
Important question:
anyone is using this in Polo with RNS510? Do you have any idea? I bought it because it was the cheapest
I paid for it 59PLN
and something more:
and something else:
Thanks Alexander!
new vs old:
Important question:
I paid for it 59PLN
and something more:
and something else:
Hello Syzmon, I'm glad to see you here. (I collect galaxies )
Hmmm...
or perhaps a magic mirror.
I hope all wires shown in the pic were joined with the plastic ties or cloth tape to the original harness.
If the installation was successful the lights controlled at this moment by 7E0 BCM are:
Low beam. (+ switching with High beam)
Turn signals.
Switches and Instruments lights.
Parking lights (but rear and front lights still joined by the same wire) suitable for halogen headlights.
Brake lights.
Reverse light.
License plate lights.
Rear fog light.
Still not controlled by BCM:
High beam, it depends on the mirror (7E0 HBA or 1K8) and stalks (7E0 or 6R0)
DRLs, it depends on new headlights (Bixenon or LEDs)
Front fog lights (static cornering lights), it depends on new headlights (Bixenon or LEDs)
Front parking lights separated, it depends on new headlights (Bixenon or LEDs)
When you install the Rain Light Sensor I have another surprise for you.
Hmmm...
Turn signals.
Brake lights.
Reverse light.
Rear fog light.
Yeap, these are old photosciclo wrote:I hope all wires shown in the pic were joined with the plastic ties or cloth tape to the original harness.
It's for better air circulation
I'm joking. You are right.. (as always )
LED headlights
This is surprising what people can send in a kitchen sink box
I purchased the wrong button by mistake:
It's RHD. So I have to look for a new button..
CNK wrote: It's for better air circulation
I'm joking.
WOW! LED headlights, perfect! So, your new static cornering light will be in the new R-line fog lamps.
This is the reason of +30 red wire to SB57a---Fuse15A---SB57b--->T73b/11.
+ T73b/9 --->T2/1(left fog light),
+ T73b/10 --->T2/1(right fog light),
+ VCDS coding, of course.
Buttons
PS: I forgot to write in above reply that the interior lights also are controlled by the BCM.
As you wrote to me:ciclo wrote: WOW! LED headlights, perfect! So, your new static cornering light will be in the new R-line fog lamps.
https://docs.google.com/document/d/1kW6 ... _EMULqTl_g
Yes, I know, you have it, but for me this isn't so important to have second mirror-switches (now I need to connect and check headlights )ciclo wrote: Buttons
Useful manual from @iichel: https://mypolo.nl/xenforo/threads/howto ... o-6r.9747/
Necessary parts viewtopic.php?p=494636#p494636
Can someone has a guide to install wiring (like OEM) for xenon/led headlights on Polo 6R?
This should be similar to this: http://www.vwgolf.net.au/showthread.php ... de-and-AFS
https://www.drive2.com/l/7316241/ - sensor axle
It is very easy do it properly and with common sense, and is very easy do it badly due to run the harness by a place where you should not do ... you know what I mean. (I take my share of the blame)
If you are able to write a master's thesis you should be able to make this installation with the information you already have available.
A remark:
According ETKA this is the appropriate connector for LED headlamps http://www.carsystems.pl/connector-kit- ... d1856.html
Not this one http://www.ebay.co.uk/itm/ORIGINAL-Audi ... 1723514994
However I'm sure that iichel can help you better with the installation of LED headlamps. He has more experience than me in this issue.
My email is available to you for small questions you have.
You can be sure that everything will end working perfectly.
By the way, everyone has to know that I have not sold absolutely nothing. My help is a reward for your willingness to share.
A remark:
Connectors are no problem, I need to have PDC main harness too, so the cheapest way for me is to buy complete harness from VW Polo 6C with LED's, something like this one:ciclo wrote:It is very easy do it properly and with common sense...
A remark:
[/size]
In this way I can have all necessary connectors and wires (for LED headlights and PDC, and maybe for something else - there is a lot of wires ).
I can't find guide about how to pull wires, so I was looking for any info..
And..
Here is some info, which I found today: https://docs.google.com/document/d/1fLs ... sp=sharing (headlights, axle sensor, washers etc) - maybe it will be helpfull to someone else
And something about PDC/OPS Retrofit on Polo 6R; https://docs.google.com/document/d/1wmk ... sp=sharing
I'm more than happy to help you with the led headlights! Of course. Also afs etc
Hahah, You are great!
Thx iichel, now I need to buy parts from this topic: http://www.uk-polos.net/viewtopic.php?f=56&t=68178
There is any difference between 6R0907357, 6R0907357B and 6R0907357C? Which one should I buy?
http://allegro.pl/audi-vw-polo-passat-m ... 20408.html This would be ok?
Saturday cleaning:
It seems to me that I miss only parts of the auto-leveling sensor.
For BCM Max (7E0) method of installation is the same as in your guide?
Regards!
Saturday cleaning:
Regards!
Yes auto leveling headlight system is the same for all bcm. Power train can, 12v acc, and, 3 wires to sensor and per headlight 4 wires
Ok, thanks @iichel, so tomorrow I'm going to buy itiichel wrote:Yes auto leveling headlight system is the same for all bcm. Power train can, 12v acc, and, 3 wires to sensor and per headlight 4 wires
