govindsharma
- Drives: polo 1.2 petrol HighLine
Dear Sir when i had changed the my POLO radio coding with that of with rear camera installed.I found error in my car after engaging rear gear that is following i think and for one instance i had seen OPS screen in my car radio and after that one massage that there is no backup camera installed.Sir please tell me if i will install backup camera can it will show image in my car radio and one thing also please tell me which wire i connect to radio to see OPS screen in my car radio and what is its PIN layout.
Sir please tell me what is these error.
thank you.
Address 56: Radio (J503) Labels: None
Part No SW: 6RF 035 187 HW: 6RF 035 187
Component: Radio 013 0116
Revision: -------- Serial number: VWZGZ1S0840292
Coding: 0000044000000F
Shop #: WSC 12345 123 08192
VCID: 0605E043B1A5FF2EA11-8053
2 Faults Found:
01327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication
Fault Status: 01110100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 9
Mileage: 51 km
Time Indication: 0
Date: 2014.04.13
Time: 07:58:50
02873 - Control Module for Back-Up Camera (J772)
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 10
Mileage: 51 km
Time Indication: 0
Date: 2014.04.23
Time: 07:20:43
thank you.
2 Faults Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 9
Mileage: 51 km
Time Indication: 0
Date: 2014.04.13
Time: 07:58:50
Fault Priority: 5
Fault Frequency: 1
Reset counter: 10
Mileage: 51 km
Time Indication: 0
Date: 2014.04.23
Time: 07:20:43
Ok, Undo what you done, and now that we finally know the radio that is installed (not showed in previous autoscan)
here you have all the information CLICK , read the link and all included links (1,2,3). I take this opportunity
to greet Gannu_1, an excellent person and a good friend.
PDC 6R
https://drive.google.com/file/d/0B2nv91 ... sp=sharing
PDC 6R
govindsharma
Dear Sir please clear my confusion that why there is can high and can low wire in head unit.Is these wire is connected to can network then why i am not being able to see PDC in head unit or which and how i had to connect wire from PDC to BCM of can gateway so that i see PDC in my car headunit.I am new to car electronics so please tell me by drawing if you need my car PDC picture i will give you.
Thank you.
Thank you.
so all the can wires go to the can gateway. the gateway is like the phone central.
mostly, the gateway is integrated in the BCM.
can wires always come in sets of two wires, a high and a low wire.
furthermore, you have several can networks in your Polo 6R:
- can powertrain (engine, gearbox, abs, power steering etc)
- can convenience (radio, climate control, mdi, bluetooth, trailer)
- can diagnostics, to connect the VCDS cable
you need to add one set of wires (2 wires, one high, one low) from a can wiring pair for can powertrain to the pdc module (in case of OEM PDC module).
so find a pair of can wires (i.e. at the BCM, steering angle sensor, AFS, instrument cluster)
the connection between your radio and the parking sensors is not to be added.
it already exists. it's the convenience can from the radio to the gateway.
Run these wires from the 16-pin connector of park aid unit to 73-pin white connector BCM (or alternative place indicated by iichel
, it's easier) with the following correspondence.
T16/15-------------------->T73b/18 Can-low (orange/brown)
T16/6--------------------->T73b/19 Can-high (orange/black)
Info: viewtopic.php?f=10&t=42713#p466570
POLO 6R PDC CAN BUS powertrain: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
govindsharma
Sir thanks for this brief reply it means .
1 I have to buy can cable that is http://www.aliexpress.com/item/Rear-OPS ... d56a5a0f48. Please check it .Sir i will extract twisted can cable from it and connect it from PDC to BCM or to canbus powertrain cable.
2 Sir have to cut it and sould it in between instrument and BCM power train cable.
3.Sir which wire will i have to connect with head unit.
4. Sir can i connect these can wire to my Head unit's can high and can low point because these cable are there.
5 Sir can i make these cable by own .
thank you.
thank you.
JapFan
- Drives: Roomster 1.2 TSI DSG
Hello All,
Sorry for dropping in guys I seen all the great upgrades going on here and I must say very good job. Unfortunately I do not have Polo just a Skoda Roomster because of family reasons/disabled people. But I think that the cars share some common things under the hood. I was thinking to take some upgrades from this post to my Roomster. Let’s say upgrading the BCM to a T6 BCM and maybe some other things. However I need some guidance what is and what is not possible. Currently I will be upgrading RLS sensor together with the automatic mirror and Bluetooth phone module… Already upgraded steering wheel MF buttons both sides and big NAVI Colombus or RNS510…
Here my autoscan to give you some info…
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 HN HW: 03F 907 309 AK
Component: SIMOS10.22AH10 5493
Revision: --H10--- Serial number:
Coding: 00250056202400080000
Shop #: WSC 33361 790 00099
ASAM Dataset: EV_ECM12TFS02103F906070HN 004005
ROD: EV_ECM12TFS02103F906070HH.rod
VCID: 75E46048D4300DEA83-8020
Readiness: 0000 0000
Part No SW: 0AM 300 061 T HW: 0AM 927 769 D
Component: GSG DSG AG7 431 5110
Revision: 00043014 Serial number:
Coding: 0000020
VCID: 3C72B56C7C9A9CA2BC-5102
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 AT HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0002
Serial number: --------------
Coding: 41DC487D212508C98219126D845510400905
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH_VW25.rod
VCID: 102A31DCCB9248C230-8044
Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl
Part No SW: 5J0 907 044 D HW: 5J0 907 044 D
Component: Climatronic H09 0103
Revision: K0000000
VCID: 2B5086304AF40B1A25-807E
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 P HW: 6R7 937 087 P
Component: PQ25 BCM H30 0565
Revision: -1------ Serial number: --------------
Coding: 7A980B3808010000003800007C0B9CC000C0400F608C0000020010000000
Shop #: WSC 12345 123 12345
VCID: 51ACF4D8081801CA7F-8004
Subsystem 1 - Part No SW: 6R0 959 801 AJ HW: 6R0 959 801 AJ Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5240
Serial number: 13202557140211123500
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 AQ HW: 6R0 959 802 AQ Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5240
Serial number: 13202560140208004939
Coding: 020000
Subsystem 3 - Part No SW: 5E0 919 719 F HW: 5E0 919 719 F
Component: E221__MFL-PR6 H05 0130
Serial number: 000000000B1539160216
Coding: 820000
Subsystem 4 - Part No SW: 6R0 959 811 J HW: 6R0 959 811 J
Component: J388__TSG_HL 006 5240
Serial number: 13102565140203164825
Coding: 0A0000
Subsystem 5 - Part No SW: 6R0 959 812 J HW: 6R0 959 812 J
Component: J389__TSG_HR 006 5240
Serial number: 13202564140124020604
Coding: 0A0000
Address 10: Park/Steer Assist (J446) Labels: 5J0-919-475.clb
Part No SW: 5J0 919 475 HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0003
Coding: 100103
ASAM Dataset: EV_SK25XParkiAssis2 S01002
ROD: EV_SK25XParkiAssis2.rod
VCID: 72EE5B54A55E1AD2A6-8026
Component: VW10AirbagTB0 H10 0020
Coding: 004230
ROD: EV_AirbaVW10BPAVW250_VW31.rod
VCID: 4A9EE3B4ED4E32123E-801E
Serial number: 3495RRB400A50Q3O7HJT
Serial number: 3505RRB400I50SK6MPVM
Part No SW: 5J0 920 841 G HW: 5J0 920 841 G
Component: KOMBI H04 0709
Coding: 110801
ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
VCID: 2E568F2471E67E3202-807A
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R7 937 087 P
Component: GW-K-CAN TP20 H30 0565
Revision: -1------
Coding: 832200
VCID: 70EA515CA35228C250-8024
Component: IMMO H04 0709
Shop #: WSC 00000 000 00000
VCID: 6ADE43348D8ED2121E-803E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 G HW: 3T0 035 680 A
Component: RNS-MID H55 5238
Revision: AB001001 Serial number:
Coding: 04000400040000800000
VCID: 34629D4C97CA54E274-8060
Subsystem 1 - Part No: 3T0 051 859 AM
Component: EU East V13 8350
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11220
Shop #: WSC 33361
VCID: 306A915CF7D268C210-8064
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Coding: 0000020
Revision: K0000000
Coding: 020000
Coding: 020000
Coding: 820000
Coding: 0A0000
Coding: 0A0000
Coding: 100103
Coding: 004230
Coding: 110801
Revision: -1------
Coding: 832200
Coding: 11220
Shop #: WSC 33361
Hi JapFan,
welcome to the community. You have come to a good place.
You will need some work on you Skoda Roomster even though you have read well into what you need.
Rain and light sensor will work, for sure. The automatic lights, they will need the BCM High or Max and the according wiring needs to be done.
A pre-made set is made by ciclo, or you can get creative and make your own. I highly recommend ciclos services since he is very good in explaning and making.
What you can consider, even though I don't know the Roomster very well:
- Xenon headlights
- MDI
- Heated seats
- High beam assist? (don't know whether it will fit, the 7E0 mirror)
- Rear view camera
Your car already looks very well equipped with the DSG, climatronic, PDC and cornering lights. Enjoy it.
Maybe you can make your own topic so we can get to learn you and your car a bit better.
- Xenon headlights
- MDI
- Heated seats
- Rear view camera
Copy-paste:govindsharma wrote:Sir thanks for this brief reply it means .
thank you.
1 I have to buy can cable that is http://www.aliexpress.com/item/Rear-OPS ... d56a5a0f48. Please check it . i will extract twisted can cable from it and connect it from PDC to BCM or to canbus powertrain cable.
Excellent idea.
2. have to cut it and sould it in between instrument and BCM power train cable.
YES and NO, the easiest place to do it is next to instrument cluster connector. (T32 blue)
You should never cut the original cables, it is better to cut, weld, crimping the repair wires.
E.g
3. which wire will i have to connect with head unit.
Forget that. You do not even have to remove the head unit.
... 4. can i connect these can wire to my Head unit's can high and can low point because these cable are there.
Never do that
. The CAN BUS radio (convenience) is a different data line of CAN BUS powertrain .5. can i make these cable by own .
Sure, but it is better that you buy the wires from aliexpress.
Hello JapFan, WELCOME!JapFan wrote:Hello All,
I have been studying this issue and I find very interesting. I searched for information about the units you currently have installed, all clear, except the instrument cluster. (Please a picture)
You also need to tell me the 'Model Year' (tenth digit of VIN), to take a look at all the electrical installations (Elsawin) of your Roomster 1.2 TSI (CBZB) DSG. It is essential to know what is possible and what is not...
JapFan
Thanks for the welcome guys
Regarding the upgrades you suggested...
- Xenon headlights - Roomster does not come with xenon...
I do have projector headlights but only way to get xenon is some CN xenon bulbs. That is not the way I want to go.
- MDI-I have lots free GBs of space on the RNS 510 for music and also SD cards are very cheap so MDI can be a good thing but its really not needed in my case.
- Heated seats - already have them from factory.
- High beam assist? (don't know whether it will fit, the 7E0 mirror)- maybe
- Rear view camera - good idea not very expensive when I already have RNS 510...but I think the handle which has the camera is bigger and I would need to do some cuttings on the 5th door. That I do not like doing very much because it can catch rust very easy then.
Regarding the cluster photo and VIN can you ping me over PM with mail pls. I am new and I am unable to send PMs...
It is not necessary to be exactly your IC, you can put here a link of one that is exactly the same. Search on google
5J0 920 841 G or a youtube video for example.
You only need to tell me the tenth letter of the VIN.
A, B, C, D, E, F? Explanation of VIN here
JapFan
Ok, sorry the letter is E.
Here a youtube from my archive I just uploaded... https://www.youtube.com/watch?v=eO9nMFgwg3M
govindsharma
Dear Sir thank you i had gain knowledge from you but sir one problem occurs while i had doing it is that in PDC 16 PIN connector 6th pin is already engaged with black wire.There is 5 wire connected in 16 PIN connector that points are 1 with green 2 with brown white 6 with black and 8 with brown 10th with white red and in 12 pin connector 6 wire is engaged that is 2,3,4,5,8 and 11.Sir now tell me what will i do.
Thank you
Thank you
there should be 6 wires from the 16 pin connector:
6th pin: can powertrain high
15th pin: can powertrain low
2nd pin: speaker ground
10th pin: speaker plus
1st pin: power (ignition switched 12V)
8th pin: ground
the colors may differ depending on the manufacturer of the wiring loom, but this is how the 16 pin connector is laid out on the Polo 6R (only rear sensors)
8th pin: ground
