govindsharma
- Drives: polo 1.2 petrol HighLine
Sir in my polo there is only 5 wire and in sixth pin there is black wire where you said that its for can wire.Please tell me how to upload pics in this forum i will want to upload some image to you.
Sir you said that
1st pin: power (ignition switched 12V)
8th pin: ground it is there.
2 you said that
2nd pin: speaker ground
10th pin: speaker plus it is there
3 you said that
6th pin: can powertrain high
15th pin: can powertrain low it not there
there is black wire in 6th pin and 15th is blank.Than why this black wire is connected sir.
Sir you said that
2 you said that
3 you said that
Perfect!JapFan wrote:Ok, sorry the letter is E.
Here a youtube from my archive I just uploaded... https://www.youtube.com/watch?v=eO9nMFgwg3M
Please tell us the parking unit reference number. Take a picture, upload on a image hosting website... and paste here the link.govindsharma wrote:Sir in my polo there is only 5 wire and in sixth pin there is black wire where you said that its for can wire.Please tell me how to upload pics in this forum i will want to upload some image to you.
govindsharma
Sir I am posting my PDC picture and model number.Sir tell me Is this security code works in my car or how can i get my car security code for adapataion.
1.https://s26.postimg.org/vi63rqna1/PDC_model.jpg( My polo PDC No)
2 https://s26.postimg.org/bh6d2iyxl/12_pin_connector1.jpg 12 pin connector
3. https://s26.postimg.org/v1kw5azix/12_pi ... ctor_2.jpg 12 pin connector
4 https://s26.postimg.org/6z42afivt/16_pi ... ctor_1.jpg
5 https://s26.postimg.org/v44rs536h/16_pi ... ctor_2.jpg.
Sir these are the PIN OUT of my POLO PDC and its model and please tell me what can i do now.
peter_dk25
- Drives: Blue GT
benzinkopf
- Drives: 1.2TSI 105HP DSG7
So what does this do?ciclo wrote:Meanwhile...![]()
[img]http://i35.servimg.com/u/f35/18/94/39/39/sin_ty12.png[/img]
Thanks for the pictures. Forget security access, you do not need this code.govindsharma wrote:Sir tell me Is this security code works in my car or how can i get my car security code for adapataion.
From-Between 2014-2015 there are several parking units for Polo 6R, these depend on each country and model-equipment 4k - 8k (Polo, Polo Sedan, Vento, Ameo,...) 6R0 919 475 C, 6RU 919 475, 6R0 919 064 A,B,C
However all wires for supply, ground, buzzer in 16-pin connector are the same for all models despite being a different reference number, except in your case with the black wire to pin No.6. I do not know what is the black wire function, my diagrams are only until 2014. Perhaps, my good friend firegrafik (RU) could help us. Also ask to Gannu_1 (IND).
Edit:
Logically the black wire is the reverse gear signal.
@JapFan
You can install a BCM Max in your Roomster (7L3).
7H0937090D Z00 is the best BCM that was installed in the Roomster at the end of production (2015) for BlueMotion models. You can install this BCM with two additional wires, from instrument cluster to BCM. Also the 7E0 BCM in the same way.
Installing a BCM Max is meaningless if you do not modify the wiring of the lights in the same way as the Roomster models with start-stop system (7L6). It is not difficult if you have some experience with wirings, terminals, crimp tools, remove parts, etc... and you have Elsawin to make your own schemes. Consists in that all the lights are controlled by the BCM, a similar process is explained here for BCM Max POLO 6R.
I can help you with diagrams and coding, but I can not manufacture the wirings for your Roomster, I only have knowledges in the wiring distances and placement of them in Polo 6R.
Why do you want to install a BCM Max?
Lady luck is with me.peter_dk25 wrote:![]()
BINGO!
I do not knowbenzinkopf wrote: So what does this do?
govindsharma
Sir than please tell me how can i contact to firegrafik (RU) or Gunnu_1.Sir if you are touch with them kindly tell them problem and take solution for my problem.Gunnu is in this forum or in other one.
Thank you.
Thank you.
Your parking unit works properly, so I guess it is not a problem.
The problem is to know if your parking unit supports CAN BUS. Contact Gannu_1 in this forum http://www.team-bhp.com/ an excellent Indian forum. I'm sure he will help you with pleasure.
govindsharma
Dear Sir i had registered in this forum team bhp but there is very difficult to contact such technical person administrator had not given rights to post any thing.Sir if i will change PDC buy new one from aliexpress then it is possible to see image in my car head unit. and in that case where i have to put this black wire.Dear I had read in gunnu's forum that new polo PDC is not with CANBUS.
JapFan
- Drives: Roomster 1.2 TSI DSG
Thanks Ciclo and @Ciclo,
So basically from the change I can only get automatic lights hmm not sure if that’s worth it. What about something more advanced like adaptive cruise control from the T6??
Regarding wiring modification and various module upgrades I already have some past experience let’s say so that’s OK. The cornering for my roomster was already an upgrade. That was worth it because you needed only wire mods and coding. Minor challenge was to find the reverse gear bit for the corners as ross tech did not provide complete label...
What for are the 2 wires for the instruments? Will I be able then to modify adaptation channels from the KI menu? Like rain closing or turning on and off CH LH and other functions like in Golf or Octavia?
If I decide to remain with my current BCM and install RLS do you think I can get at least CH LH working? I think there is the bit to switch the CH LH to the fog lamps. These are already on the BCM directly so that should be OK. The only thing is the AUTO position of the light switch. Is there any way to run the feature manually? Because when I look with VCDS on my current BCM CH LH coding is available. Sure could by a wrong label from ross tech nothing new. But I see also live adaptation channels are active for the CH LV times so the BCM should support the function or?
Also another question is there a possibility to add OEM front parking aid? I have also a friend with Polo 2012 and he is interested in this. Maybe it would be also a valid upgrade for me.
the leaving home leaving home with the current bcm.. i think it will work through the fog lights but not trough dipped beam. since the fogs are now bcm-controlled (cornering lights). you do need the RLS, of course.
coming home will require a toggle of the high beam stick.
the extra 2 wires to the instrument will replace the old powertrain can wires. they make the new can network that is required for the IC.
i'm not familiar with any new functions in the IC, but i think it will not be the case.
OEM front and rear PDC will not be a problem. use the module from example from a golf 6 or a transporter t6. (8K parkhilfe from PQ25 or PQ35)
govindsharma wrote:Dear Sir i had registered in this forum team bhp but there is very difficult to contact such technical person administrator had not given rights to post any thing.Sir if i will change PDC buy new one from aliexpress then it is possible to see image in my car head unit. and in that case where i have to put this black wire.Dear I had read in gunnu's forum that new polo PDC is not with CANBUS.
6R0 919 064 unit does not support OPS.
So,
You have to buy a 6R0 919 475 unit (4K = rear sensors, in your case), and wires for CAN BUS.
unit e.g http://www.aliexpress.com/item/OEM-Orig ... 5fd31a7fc5
Isolate the black cable (forever). Now the reverse signal is via CAN BUS. Remove it from 16-pin connector and isolate with cloth tape.
Install the CAN BUS wires as explained.
Install the new unit.
Codify the new unit.
And you'll get the Optical Parking System.
