Sloppy gearstick syndrome
Is this fixable?
Re: Sloppy gearstick syndrome
Yes. It's either a loose linkage or the shift cables bushes have split engine side. Easy enough to sort with a few cable ties
TRiBaL
- Drives: 1.4 16V 6n2
Had the same issue. Fixed after linkage replacement.
Should be cable
What's the easiest way to check? Can you see the cables under the gaitor?
Yeah they clip onto the bottom of the gearstick
Or just stick your head under the front and you'll see them come through following the exhaust
Slightly unrelated,
1st & reverse are inconsistant when stationary, well, you think you're in & you're not.
Gears are fine when driving.
Could this be selector adjustment?
Sounds like the bushes are worn. have you checked them for splits?
Otherwise, linkage is out
Got under it tonight, all looked in reasonable nick for age,
Most wear appears to be on the L/R axis bell crank above the gearbox selector shaft, not sure how fixable that is?
For/aft stick position adjusted back to limit of adjustment.
I don't think any of this relates to 1st & reverse selection.
Gearbox getting noisy as well.
Pop up a pic
Oil change on the gearbox would be a good idea
Stealing someone elses photo:
http://s1109.photobucket.com/user/fridg ... D.jpg.html
B marks the adjuster for the L/R axis, above the adjuster you can see a 90Deg bracket that pivots, that pivot is sloppy.
I could change the trans oil, would mineral do?
Nooooo 75W90 fully synthetic. Use genuine VW gearbox oil if possible or Castro syntrans
That's what I thought you'd say.
Are those boxes prone to bearing failure?
Yep, very common. The 5 gear taper bearing breaks up and destroys the gearbox
