Does the micrphone from china work OK?robertsm66 wrote:271587710788 Item on eBay or 201103230356. Green connector plugs straight into a spare slot on the harness (rear of stereo).
You just need to route the cable behind the glove box, up the pillar trim into the space behind the interior light. If you haven't installed a mic previous, you'll need to break off the insert for the mic on the required side and fit.
Nice and easy.
RNS315 microphone
- Bigtam
- Drives: Polo GTI 2016
Re: RNS315 microphone
AdamRutherford
I've just installed a RNS315 into my 2011 Polo 6R, I have also bought an OEM microphone that is supposed to be installed in the interior light. Can someone let me know where this can be installed if the interior light doesn't have any inserts to break off? Do I need to upgrade the light as well? Cheers
- CNK
- Drives: 6R
Can you attach a photo of your light?AdamRutherford wrote:I've just installed a RNS315 into my 2011 Polo 6R, I have also bought an OEM microphone that is supposed to be installed in the interior light. Can someone let me know where this can be installed if the interior light doesn't have any inserts to break off? Do I need to upgrade the light as well? Cheers
Welcome.AdamRutherford wrote:I've just installed a RNS315 into my 2011 Polo 6R, I have also bought an OEM microphone that is supposed to be installed in the interior light. Can someone let me know where this can be installed if the interior light doesn't have any inserts to break off? Do I need to upgrade the light as well? Cheers
With
Without
