CNK wrote: Going back to our last conversation...
...can anyone confirm, that windshield from Polo 6RU Sedan fit to Polo 6R Hatchback? :lol:
Heated windshield :lol: 8) + RLS retaining plate from factory... good for Poland. :wink: (it is possible electrically)
I have checked on ETKA online but it's hard to know unless someone has done this mod. The Ref number would be 6RU845011J (it should be measured with extreme accuracy to compare with your current windshield :|)
Maybe your best option would be the windshield from Polo 6C.
JapFan
Drives: Roomster 1.2 TSI DSG
Post by JapFan »
Hello Ciclo,
What do you think about Front Assist upgrade I know its other platform. I have checked my current GW and I have option 13 Auto Dist. Reg. The automatic braking would most likely not work with my current ESP. But maybe at least the warning messages would go through BAP to the MAXI dot. What do you think would it be worth a test? If you know can you advise which radar unit would be best suitable to do the testing?
Hi Japfan.
I don't know anything of these issues. I'm sorry. However I am aware that there are several users who are gathering information from all these issues ...
By my side, I have yet to learn a lot about the units for ABS, engine and radar (ACC/Front Assist -city-/etc...).
My confirmation to firegrafik:
My BCM
I also made a picture of my fuse box (I forgot to make it when I upgraded my wiring looms)
diagram from here
CNK
Drives: 6R
Post by CNK »
firegrafik wrote me, that his new BCM from T6 which I sent to him works great with LED headlights ;)
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
ciclo wrote:Hi diskoboy, as can be seen this installation (process) is for a VW Transporter T5.2 (7L3) non Bluemotion, so that the full installation for your 6R BMT with external Gateway would be different.
Many parts of your current installation (with automatic lights) can be used, but first you have to carry all signals from your external Gateway to the 7E0 BCM (Internal Gateway)
iichel did this process (installation) under my recommendation to get that HBA system was recognized through IC CAN-lines. (in case you want detailed information about it)
Elsawin or Erwin would solve all your doubts about the pin assignment and correspondence. (External Gateway & other units to new 7E0 BCM)
After that, follow this diagram. IIRC w/o Front foglights in your case. :wink:
In ElsaWin.. what model / year should I've look at?
chisyelamos1
Drives: 6c 1.4tdi
Post by chisyelamos1 »
sorry for the offtopic but I would like to know where to buy the tape for car at a good price
Thanks!
Enviado desde mi LG-H815 mediante Tapatalk
chisyelamos1
Drives: 6c 1.4tdi
Re: RE: Re: ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
iichel wrote:I am very satisfied with this one: https://www.aliexpress.com/item/1-Pcs-1 ... 696fd76364
Thanks!
This is the best fabric tape Select your language :mrgreen:
Also coroplast.
Erwin...VW T6 (2016-2017)
CNK
Drives: 6R
Post by CNK »
ciclo wrote:This is the best fabric tape Select your language :mrgreen:
Also coroplast.
You can also buy it in local shops with electronic parts (where you are buying soldering iron, wires etc.)
or... if you love your local car dealership, you can order this: D 422 S25 A2 or 000 979 950 (however, the price will be several times higher) :D
100% OEM :mrgreen:
Locked
