[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 G40 brakes on a 1.3CL Coupe... - UK-POLOS.NET - THE VW Polo Forum
i can't remember how much mine cost me, but i found them on the polo-gt classifieds. the bonus was that the seller was local to me, without me realising!
Yes, like people have said you will need the brakes carriers and callipers from a golf Mk 1 gti or cabby, scirocco or G40 with the 239mm vented discs. Make sure you get the bolts for the callipers too. Basically whats in pettsy's pic there, obviously with your choice of pads and discs. I would also recomment a set of braided brake hoses.
hardhitter wrote:Yes, like people have said you will need the brakes carriers and callipers from a golf Mk 1 gti or cabby, scirocco or G40 with the 239mm vented discs. Make sure you get the bolts for the callipers too. Basically whats in pettsy's pic there, obviously with your choice of pads and discs. I would also recomment a set of braided brake hoses.
Superb information hardhitter!
239mm is the magic number that i shall be looking out for (they will fit behind some 6J Pirelli P's, ET38 wont they?)
How do you mean good / cheap ? As in performance or standard ? The cheapest brakes usually arent the best.
I can recomment going to somewhere like GSF and getting either standard brembo or max grooved discs. Combine them with a good make of pads like pagid, ate, ferodo or ebc greenstuff.
