RCD310 to RCD510
CGreen98
Drives: Polo 1.6 TDI SEL
RCD310 to RCD510
Post by CGreen98 »
Hi Everyone, I am thinking about upgrading my standard RCD310 to a RCD510 unit! My question is will the Multifunction steering wheel buttons still work and has anybody done this before and is it a relatively easy swap over job? Haven't really got time to be re-wiring.
Thanks Cam.
alexperkins
Site Admin
Re: RCD310 to RCD510
Post by alexperkins »
Yes but it might need some VCDS coding
It should be a straight swap however
yes and the RCD510 had two FM antennas as opposed to the single antenna on RCD310
CGreen98
Post by CGreen98 »
Hmm thanks guys, I really want one but don't want to waste £250 on a stereo I can't use...[emoji31] I think I might remove the RCD310 and check the connections.
So here's what I've gathered:
The normal 310 I have looks like this:Image
And then the bit that confuses me, there's 2 different RCD510's! One the same as mine and one with a strange yellow port?
From what I've read there's a Bosch one made in Portugal for the earlier cars and then a Delphi (or something like that) one that was made in China for the later cars. Seeming as mine is an earlyish 2011 maybe the Bosch would work better?
joe6
Drives: Golf Mk6 GTI (Scirocco gone) Polo 6c GTI
Post by joe6 »
This link will help with identifying the RCD510 connections http://workshop-manuals.com/volkswagen/ ... t;rcd_510/
alexperkins
Site Admin
The yellow plug is for a reverse camera
CGreen98
Post by CGreen98 »
Thanks guys I ordered one without the yellow plug anyways. Hopefully won't have any issues and will update once it's in!
