Noted Wrecksigge. I'm back now. will try to send the file to you soon!wrecksigge wrote:PM sent
Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
- Drives: 1.2TSI 105HP DSG7
Re: Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
In the meantime, here's the update on the BCM Max and Auto Lighting installation and testing. I've edited the first post with the latest autoscan which is now superb with all the controllers accessible (in customized autoscan as per suggested by UWE from ross-tech forum) :
http://forums.ross-tech.com/showthread. ... le&p=81850
The latest autoscan from the first page:
viewtopic.php?f=56&t=69026
Here's again the coding from 09 Cent. Elect.
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001 Serial number: 0771 139150190
Coding: 3CB02BBF48A10E0013380EB07CEB9ED91BC0612F608C2000200000030800
Shop #: WSC 12345 123 12345
VCID: 68D5B7809B48190167-803C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 180812 05 54 0403
Coding: 06302D
Subsystem 2 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU030061100013270
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU001071100011802
Coding: 08BC30
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B
Component: E221__MFL-TAS H30 0032
Serial number: 0122863
Coding: 830000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU030061100015373
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU001071100015810
Coding: 08BC32
Happily, I've been testing and test driving around alot to really test the system. I would say everything works perfect and what more when the wiring looms, diagrams, installation guide and support came in from the best of best: CICLO!!!
Unfortunately, i didnt have a good camera to really record the performance of auto lighting system at night. As far as i can tell, the RLS will start to detect the different between dark/daylight within just 2 seconds! that's i believe the same time you take when you re just thinking that you should switch ON the light. So its superb!
With the new BCM MAX and AUTO lighting as well as all others sub-features like CH/LH, Rain Light Features, it is indeed very convenience when you are travelling a lot around with tunnels, moving into inside parkings below the buildings etc.
Now, I'm still testing some bytes and bits for rain closing to work properly. Right now, the rain closing only works when the car is unlock and even with that, it seems to not have some sort of consistency and after more than 15mins, it doesnt work. I would like to believe that this is due to the unknown coding for the system to work permanently. Interestingly. it does work (while unlock) with the AUTO light switch OFF and wiper stalk OFF.
Just to share: If i changed both the bits below:
Byte 0, Bit 1 = Change to 1
Byte 0, Bit 2 = Change to 0
I lost my remote function. Then i changed back Byte 0 Bit 2 to 1, so its working again. but still Rain closing didnt work
Coding: 06302D
Coding: 18BC30
Coding: 08BC30
Coding: 830000
Coding: 08BC32
Coding: 08BC32
Wow! ... I hope the best is yet to come.
Just food for thought...
I dissembled the side mirror from jetta model with blind spot detection led.
These are the two images related:
So i believe it should be possible to make the cut-out and mask the indicator as per original and put the led behind it, but it seems impossible without cutting the heating element since the original part has specific heating element layout. [emoji848]
Got this one today. But notice it doesnt have one pin (i think T69b) compared to my current 7e0937090 [emoji848]
Ausgezeichnet. RDKS high? (+Bixenon)
T73b/69...The mysterious pin.
It was probably deleted because its function (unknown) is now managed electronically. +/- ???. For special vehicles?...
Hehe. Sorry for the wrong typo. It is T73b/69!!! Thank you ciclo!ciclo wrote:Ausgezeichnet. RDKS high? (+Bixenon)
We will see. But first, the issue with unreachable dsg.
I was actually afraid that this unit had broken pin! Because its used item.
Just managed to steal 30mins to swap to the latest BCM 7E0937090B and recode everything necessary incl. keyfobs matching process.
Here's the latest "customized" autoscan
Sunday,28,May,2017,17:48:07:15298
VCDS Version: 17.1.3.0 (x64)
Data version: 20170220 DS267.3
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN: WVWZZZ6RZCUBENZINKOPF License Plate: BENZINKOPF
Mileage: 205190km-127499mi Repair Order: 170528-NewBCM090B
Chassis Type: 6R (01)
Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 44 56 77
VIN: WVWZZZ6RZCUBENZINKOPF Mileage: 205190km-127499miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 HF HW: 03F 907 309 J
Component: SIMOS10.22H03 2698
Revision: --H03--- Serial number:
Coding: 002500F6202400080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TFS02103F906070HF 004004
VCID: 6DDBC694BCAA3C2932-8038
Readiness: 0010 0101 (My last BCM Autoscan showed Readiness 0000 0000. Not sure why this is different??)
Part No SW: 0AM 300 060 G HW: 0AM 927 769 D
Component: GSG DSG AG7 431 5270
Revision: 00043014 Serial number: CU501411296648
Coding: 0000020
Shop #: WSC 25802 001 1048576
VCID: 2E590198BA2C87314B-50E6
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 230228E3416E00B4C42C14E382D800801700
Shop #: WSC 31414 790 31414
VCID: 0717943CB216F679A8-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326115E86D14A3D12F-8066
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 259161638
Coding: 3CB02BBF48A10E0013380EB07CAB9ED910C0612F608C2000200000030800
VCID: 2A510D8845C4EB1197-807E
Coding: 07302D
Coding: 18BC30
Coding: 08BC30
Coding: 830000
Coding: 08BC32
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 B HW: 7E0 919 475
Component: PARKHILFE 4K H11 0012
Revision: -------- Serial number: 47301119600512
Coding: 108101
ROD: EV_VW250ParkiAssis2.rod
VCID: 3D7B36D4AC4A6CA9C2-8068
Component: VW10Airbag027 H09 0020
Revision: -------- Serial number: 003GX00RY8XP
Coding: 003237
VCID: 4A916D08ED84CB1177-801E
Serial number: 3575HRB405H0IRE2COP8
Serial number: 3585HRB405J0ISD6C8T3
Serial number: 3515RRB405J0LMIQ6PBL
Serial number: 3525RRB405H0LMIQCGRX
Part No SW: 6R0 920 860 H HW: 6R0 920 860 H
Component: KOMBI H03 0505
Coding: 140C01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 397322C4B8625089EE-806C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002300
VCID: 68D5B7809B48190141-803C
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6AD1CD888D442B1157-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660415697
Coding: 010000
VCID: 2953F28440C2E0099E-807C
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 31414
VCID: 2F671C9CEA268E3940-807A
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0236
Revision: 00000001 Serial number: VWZ1Z3N1941321
Coding: 09000401020001
Shop #: WSC 43038 123 12345
VCID: 244DE3B027E03D61AD-8070
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663752927
Coding: 0110000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A713DC8BD645B91E7-806E
End-------------------------(Elapsed Time: 03:23)--------------------------
www.Ross-Tech.com
Coding: 0000020
Revision: --------
Revision: 0002S 02
Coding: 07302D
Coding: 18BC30
Coding: 08BC30
Coding: 830000
Coding: 08BC32
Coding: 08BC32
Coding: 108101
Coding: 003237
Coding: 140C01
Revision: B9081001
Coding: 002300
Serial number:
Coding: 010000
Coding: 11250
Shop #: WSC 31414
...and the backlit for Hazard Light button worked by default. I guess it's default in the T6 anyway.
And yes, i can agree with Ciclo! Its a little touch that makes a different! I like it. With this, feel like I'm entering into the car knowing the car is "switch-ON" and ready for next action from the driver!
30 minutes? With five it would have to be enough.benzinkopf wrote: ↑Sun May 28, 2017 6:40 pm Just managed to steal 30mins to swap to the latest BCM 7E0937090B and recode everything necessary incl. keyfobs matching process.
Also, makes it easier to locate it just when it is most needed, eg. sunset/sunrise times, or when you temporarily/suddenly drive in poor light areas.benzinkopf wrote: ↑Sun May 28, 2017 6:45 pm [IMG]
http://www.ross-tech.com/vag-com/tour/readiness.html
Yeah. Its 30mins. Simply because i dont want to steal your Master title Ciclo! [emoji13]
Thanks a lot on the readiness info! News to me. Will check further. I didnt have any MIL or warning lights just now.
Hi everybody.
Need a little help of understanding with my factory foglights with static cornering light and the existing headlight wirings.
1. as of now, my foglights are ONLY connected to the BCM T73b/9 and T73b/10. so for me to install the BIXENON headlight with static cornering light function (In headlight), I need to reroute these two wires to PIN14 headlights and ADDITIONALLY put new wires + fuse for my foglights directly from Light Switch?
2. currently, i believe my side lights/parking (T10/10) are connected to T73a/41 and T73a/40. While the parking function for bixenon headlights are connected to T73b/5 and T73b/6. Any differences with these two connection? I shall rewire to T73b/5 and /6 and left T73a/41-40 empty?
1: correct!
2: the front and rear parking lights are interconnected. leave the pins in, so the tail lights still work
Thanks iichell. Btw on no. 2.iichel wrote:1: correct!
Do you mean the system will still works with front side lights connected to 2 new bcm pins and the rear will use the existing pin 40/41? In that case, the new pins are just due to lower consumption of the leds right?
the first part is correct.
the second part:
The LEDs need to be active as DRL and as parking lights.
So they need a power wire and a PWM wire. the PWM wire tells the LED to dim or the be full brightness.
the second part:
