firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
iichel, you, me, CNK should search BCM 7E0937090B from T6 if we would like to have RKDS system. Ciclo's BCM is for Russian Polo Sedans with bixenon headlights and it doesn't work properly with LED headlights. The DRL has only one mode with full LED brightness, the parking-lights doesn't work at all.iichel wrote:...
PS, ciclo, does your 7E0 937 090 B BCM have the adress 65 (TPMS) available in the CAN gateway?
my 7E0 937 090 does not have it
Yes, with Bixenon headlights it works great. (All functions)
That's why I asked you to test my new BCM with your LED headlights.
Edit (PR-codes)
7E0937090B ZWM
8AA,8DU,8K0,8K1,8K3,8IG,8YU,9AA,9AB,9AK,I6F,I7E,I7F,I7G
http://vwtech.pl/kody-wyposazenia or http://igorweb.org/equidec.aspx
8AA = Without radio
8DU = Radio Entry-G (type 2)
8K0 = Without special headlight activation
8K1 = Separate daytime running lights
8K3 = Separate daytime running lights with low beam assistant and "Coming Home" feature
8IG = Gas discharge headlamp (D1/D3 system)
8YU = Radio preparation for commercial goods
9AA = Manually controlled heating system
9AB = Manually controlled air conditioning
9AK = Climatronic with impact pressure control free of cfc
I6F = MIB-G Standard 2 DIN (Asia) Export
I7E = MIB2-G Entry PQ/MQB radio ROW
I7F = MIB2-G Standard PQ/MQB radio ROW
I7G = MIB2-G Standard Plus PQ/MQB radio ROW/China
Edit (PR-codes)
7E0937090B ZWM
8AA = Without radio
Monday,30,January,2017,15:14:59:06516
VCDS Version: 17.1.2.0
Data version: 20170109 DS267.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate:
Mileage: Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
VCID: 6ACFCA949F68AF074F-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 02679A6CF3701F2F8F-8056
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Serial number: 08021613470174
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EDBA2D0CFCC2793AF-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 3891360EAF6EDBA5FF-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 320160060
Coding: 3CB02FBF48E1240093380FD1FCEB9FD0DAC067AF600D30D0200000030800
Shop #: WSC 12345 123 12345
VCID: 2A8F4AD497282FC74F-807E
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 110215 03 37 0059
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361212601014
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E9B2210CF8CA753AF-806A
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
VCID: 4AAF0A341FC86F274F-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 00233 572 91226
VCID: 359230F7AB71E990E7-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002200
VCID: 68C1D69E6F7EBB757F-803C
Address 20: High Beam Assist. (J844) Labels: 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C00000000000000
Shop #: WSC 03607 002 104857
VCID: 2E8B42E08F5C07E32F-807A
Component: IMMO H05 0607
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5218
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
VCID: 3790340DAB6BDDA2F7-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V14 8477
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 00788
VCID: 2F8844E51F530DEA37-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77D0B4CDA3AB5DE2F7-8022
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3B9C2C19D39FB5BED7-806E
End-------------------------(Elapsed Time: 04:14)--------------------------
- CNK
- Drives: 6R
iichel wrote:the A1 is based on the PQ35 electronics, for sure
All the time I thought that Audi is also on the BCM PQ25. But you're right. This is BCM from Audi A1:
Source: http://allegro.pl/modul-sterownik-audi- ... 37297.html#
But.. on Golf MK5 it's possible to change old CECM + CCM to new BCM PQ35. It's very popular mod on Golf's and Tourans in Poland (guide in Polish language: http://www.oknabramy-ostrow.pl/forum_mk ... cm&bcm.htm )
firegrafik
I7E = RAO MIB2-G Entry PQ/MQB radio ROWciclo wrote: I7E = code not found
I7F = code not found
I7G = code not found
I7F = RAO MIB2-G Standard PQ/MQB radio ROW
I7G = RAO MIB2-G Standard Plus PQ/MQB radio ROW/China
Thanks!, edited at the same time.firegrafik wrote:I7E = RAO MIB2-G Entry PQ/MQB radio ROWciclo wrote: I7E = code not found
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
Hola Fernando.
Do you know if it is possible to code the bi-Xenon headlights so the LED DRL's turn of when the Xenon projectors turn on??
Hej Martin
DRLs are already turned off when the Bixenon projectors are turned on.
If you mean front parking/side lights, it's unknown to me.
However it should be possible due to they are separated from rear parking/side lights. Maybe through some BCM adaptation channel, but it wouldn't be legal to drive in that way.
- Mart!n-GTI-DK
- Platinum Member
I was the sidelights I meant.
I know it's not legal. But I would really like them off when the Xenon is on.
DRLs are only mandatory here after January 1st 2011. Before that, when DRL was not mandatory, there was already bi-xenon with LED DRL (even though probably not on the Polo).
So maybe it's somewhere
- CNK
- Drives: 6R
So RKDS is available only in latest version of BCM?firegrafik wrote:iichel, you, me, CNK should search BCM 7E0937090B from T6 if we would like to have RKDS system. Ciclo's BCM is for Russian Polo Sedans with bixenon headlights and it doesn't work properly with LED headlights. The DRL has only one mode with full LED brightness, the parking-lights doesn't work at all.iichel wrote:...
Is there no way to enter a value In gateway installation, like in LongCoding when check box is not available? I haven't ever seen a way but have never looked.
Only other way - gateway update/flash
CNK, If you mean Reifendruckkontrolle, so RDK, in such caseCNK wrote:So RKDS is available only in latest version of BCM?firegrafik wrote:iichel, you, me, CNK should search BCM 7E0937090B from T6 if we would like to have RKDS system. Ciclo's BCM is for Russian Polo Sedans with bixenon headlights and it doesn't work properly with LED headlights. The DRL has only one mode with full LED brightness, the parking-lights doesn't work at all.iichel wrote:...
(you know I would prefer it to be possible with your current BCM, as well as the ones from firegrafik and iichel for LED Headlights)
You'll have to scratch your pocket to find the solution... (again)
I think that the best BCM is the one from Adam87.
Maybe by updating, but the last few times I went to the VW dealer this new BCM software was already available and my BCM 7E0937090 was not updated.Adam87 wrote:Is there no way to enter a value In gateway installation, like in LongCoding when check box is not available? I haven't ever seen a way but have never looked.
BCM for HBA, etc...
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001
BCM for
Revision: B9081001
I would say VCP is the best option for a flash/update of the gateway, maybe an email or a post on the VCP forumciclo wrote:
