Hi people I am new to the forum, I'm just wondering if anyone knows whether or not I can put these fog lights (link below) on my polo which doesnt come with fog lights as standard, thanks in advance
http://m.ebay.co.uk/itm/131938558345
Fitting Fog Lights to Polo S
Harman2013poloS
- Drives: Polo 6R, 2013, S
Re: Fitting Fog Lights to Polo S
the light units and covers should fit.
the light switch will not fit, you'll need a different one with the big plug and no auto setting.
not so sure about the wiring.... i would recommend to invest some money in proper tools instead of the stuff that they deliver.
Or buy this wiring set: https://www.kufatec.de/shop/en/volkswag ... ?info=3665
wiring installation: fog light switch pin 7 - fuse box - fuse 15A - left and right fog lights
maybe, while you're at it, you could consider adding daytime running lights in the bumper as well. it's not difficult and hardly any extra effort when you do the fogs anyway.
Harman2013poloS
Thanks for the reply pal if it's not any hassle can you find out what switch i would need as I'm baffled by all this and don't actually know what I need for the set up, I was hopeing that kit would have it all
Harman2013poloS
thanks for the help pal I understand a little better now, ill tell you how it goes
MichelKasapovic
- Drives: Polo 1,2 tsi 90bhp 6r,6c
You can find a hole kit with swich, wiring and sensor for 50-60£ and free shipping from china, Hong kong ect. and its OEM. Works very well on mine tsi.
MichelKasapovic
Now i saw your pics from eBay. The same as im using. Fits and works very well. Be carefull with plastic round fog lights, breaks easy
- 6RPotentialBuyer
- Drives: Candy White Polo 6R
I'm not sure how to connect the wiring.iichel wrote:buy this wiring set: https://www.kufatec.de/shop/en/volkswag ... ?info=3665
Here's the Kufatec cable
I'm assuming the red connectors plug into the left and right fog lights.
However I'm not sure where the blue and green connectors go.
green is ground, anywhere on the chassis ground points, i.e. on the front longitudinal members.
Blue ones go to the BCM, for the static cornering lights + fogs. I think it needs another cable for the power supply though.
If you choose only to do the fog lights, you can do it as i suggested with light switch-fuse box- fogs.
It would be good to ask Kufatec for a manual
