retrofitting kessy to the Polo 6R
so, to avoid off-topic in ciclo's Polo thread, i'll do it here.
Objective:
To retrofit Kessy to the Polo 6R
Kessy is the keyless entry and start system
http://en.volkswagen.com/en/innovation- ... kessy.html
Progress so far:
- Removed old ignition lock
- Installed Kessy wiring to antennas
- Installed Kessy antennas
- Replaced door handles with Kessy variants
- Installed J935 converter box
- Installed Terminal 15 relay
- Bought ELV, start button, Kessy module
- Bought three new keys
- Adapted IMMO
- Coded BCM
To do:
- Adapt keys to kessy module for keyless entry
- Adapt keys to ELV?
- Successfully enter and start the car keylessly
See my first post here:
viewtopic.php?f=56&t=58703&start=3165#p518667
The door handles:
viewtopic.php?f=56&t=58703&start=3165#p518675
The wiring:
viewtopic.php?f=56&t=58703&start=3180#p518722
The parts needed and brainstorming in my google drive folder. Some of it in Dutch, some in English.
https://drive.google.com/drive/folders/ ... sp=sharing
I'll update the thread if I have some news. Also I'll try to answer some questions. And of course feel free to share ideas.
Re: retrofitting kessy to the Polo 6R
updated VCDS coding
Tuesday,28,February,2017,13:53:50:62066
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN:   License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56
          61 69 6C 77 0B
VIN:   Mileage: 0km-0miles
05-Acc/Start Auth. -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J000-CFWA)       Labels: 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9978
   Revision: 12005001    Serial number:
   Coding: 00114036033401080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TDI03103P906021B 001041
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 2757FDE35E1F667988-8073
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: None
   Part No HW: 6R0 907 379 AF
   Revision: --------
   Coding:
   Shop #: WSC 00788 648 00255
   VCID: 55AB872B38F324E9EA-8001
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 000F0F
   Shop #: WSC 01342 020 12345
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSYPQ35G_VW01.rod
   VCID: 37772DA38EBFF6F918-8063
1 Fault Found:
1057799 - Antenna for Keyless Entry System in Trunk
          B1173 11 [008] - Short to Ground
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 153
                    Mileage: 0 km
                    Date: 2017.02.28
                    Time: 01:41:03
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 38752E9F8BA1F98111-806D
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 092150183
   Coding: 3CB02FF828CB2400933806E2FFEB9FD080A073EFE08D78D020E050032800
   VCID: 68D5BEDF9B81A90141-803D
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 140415 03  37  0059
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140002547420014516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  002 0803
   Serial number: KU0-KU008.06.0910897
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231422402620
   Coding: 318001
   ROD: EV_EPHVA18VW250GPCS.rod
   VCID: 3B7F3193B297D299FC-806F
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A916457ED4D7B1177-801F
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140E01
   VCID: 336F19B39AC71AD924-8067
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 042201
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 040C00E200000000000000
   VCID: 2E5908C771E537314B-807B
   Component: IMMO          H04 0709
   Coding: 000007
   Shop #: WSC 09402 015 1048576
   VCID: 6AD1C4D78D8D9B1157-803F
2 Faults Found:
9456681 - Key
          B104C 29 [009] - Implausible Signal
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 0 km
                    Date: 2017.02.28
                    Time: 01:41:06
10493440 - Function Limitation due to Missing Enable from OCU/VTS
          B201E 00 [009] -  -
                    Fault Priority: 1
                    Fault Frequency: 1
                    Mileage: 0 km
                    Date: 2017.02.28
                    Time: 01:41:05
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F6715C376EF3E3940-807B
2 Faults Found:
1048838 - Terminal 15
          B1148 12 [137] - Short to Plus
                    Fault Priority: 1
                    Fault Frequency: 4
                    Reset counter: 113
                    Mileage: 0 km
                    Date: 2017.02.28
                    Time: 01:37:56
                    ELV State: 04
                    Information Clamps: 67 20
                    CoCo State: B0 01
                    WFS State: 10 1A
                    Vehicle speed: 0.00 km/h
                    Voltage: 68
1048840 - Terminal 15 Redundancy
          B11D6 12 [137] - Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 113
                    Mileage: 0 km
                    Date: 2017.02.28
                    Time: 01:37:56
                    ELV State: 04
                    CoCo State: B0 01
                    WFS State: 10 1A
                    Voltage: 68
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
   VCID: 2B5F01D34AF742196C-807F
Address 37: Navigation        Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Coding: 00070002010000A10001
   VCID: 366920A781B50FF103-8063
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH14 0120
   Revision: 00H14000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   Shop #: WSC 02757 790 00000
   VCID: 2F6715C3BEEF3E3940-807B
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H09 0110
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ÿ
   Subsystem 4 - Serial number: H21982ÿ
   Part No: 6R0 423 156 B
   Coding: 11220
   Shop #: WSC 00788
   VCID: 2F6715C3EAEF3E3940-807B
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
   VCID: 2855FEDF5301690181-807D
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0192000001000000
   VCID: 77F7EDA3CE3F36F9D8-8023
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Component: EU West V14  8477
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0733
   Coding: 03071A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F6715C37EEF3E3940-807B
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65CBB7EBAC93B4697A-8031
1 Fault Found:
03006 - Back-up Camera System not calibrated
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 113
                    Time Indication: 0
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105254406
   Coding: 020100000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_002.rod
   VCID: 254BF7EB24137469BA-8071
End-------------------------(Elapsed Time: 05:08)--------------------------
result with normal ignition lock:
if ignition is on, it says in the segment display 'no key'.
also, if there is something wrong with the kessy it says 'check keyless'. very neat.
Car now unlocks when ignition is switched off, instead of key removal.
Problem with the converter box/BCM wiring: viewtopic.php?f=56&t=58703&start=3180#p518773
:?: LC,17,1,Funktion Anlasswiederholsperre aktiv
My German is extraordinarily limited (sorry) :oops: .... :lol:
8)
anlasswiederhohlsperre, a beautiful word for sure
anlasser = starter engine
wiederhohl = to repeat
sperre = blocking, blockade
iichel wrote:
ciclo wrote:
However, it is very important to take into account all these positive signals (+50, +75, +30, +15). Especially for Kessy ... :lol:
Any progress with Byte25 Bit5?
Luckily the two extra modules are +30
The converter box J935 makes things a bit more complicated
Byte 25 bit 5 seems to work.
The only thing is the T73a/51. That is a power supply to the converter box on T10/10. It is the power for terminal 50.
J764 steering lock T16/12 gives a signal to converter box on T10/6. Then T73a/51 is connected to T10/1. T10/1 is the starter signal.
T73a/51 needs to output 12V at some point, for engine start. The problem is that it isn't, it's 0V. For now, I improvised and made the T10/10 a +15. This is not very nice solution.
(and to be fair, it makes the converter box obsolete too). I need to check out why this is.
T73a/51 is not correct, this pin is not used since a long time (it was for sill lights on some PQ25 models -T5-).
I suppose you mean to the T73b/51 pin which is the 75x input signal to the BCM indicating that 75 terminal is active (from J680 relay). Or maybe you mean to the T73b/50 pin which is a input signal to the BCM (starter signal).
T10/10 is an output signal from the J935 converter in order to activate relay J329 (to supply +15).
Power to J935 is through T10/7 (+30).
J907 also informs via T7b/6 pin (D) of the starter process to the other units (According to the equipment).
Your diagrams: Beetle :arrow: https://drive.google.com/drive/folders/ ... UdUdDZrSms , from here.
Apart:
Hmm... maybe you need a BCM for Kessy.
Specified in ETKA.
As for coding:
I have reviewed some Autoscans :) (Jetta & Beetle) in addition to, test to activate also the following Bits:
Byte 26 Bit4
Byte 28 Bit5
And tell us the results or faults.
The most interesting thing would be to get the .csv BCM adapmap file from a Beetle with kessy.
It's T73a/55 to converter box T10/5. I thought I ninja-edited it, but it seems not.
T73a/55 is giving 0V, and thus preventing any terminal 50 activity to the ECU.
Converter box J935 T10/...
...1 = terminal 50 output, 'start engine' signal. output when active = 12V?
...2 = GND
...3 = GND (only in beetle, not in Jetta)
...4 = terminal 75 input signal, from J764 T16/6
...5 = terminal 50s, from T73a/55. this is short to T10/1, when T10/6 is given input signal
...6 = terminal 50 input signal, from J764 T16/12 'start engine' signal
...7 = +12V terminal 30 power supply
...8 = terminal 15 input signal, from J764 T16/8
...9 = terminal 75 output signal, to terminal 75 relay or BCM. output when active = 12V
...10 = terminal 15 output signal, to terminal 15 relay or BCM. output when active = 12V
it's a bit confusing that sometimes the terminal 75 and terminal 15 switch names and sometimes the terminal 86 is also involved.
Example, a bit like the epic image compositions of firegrafik (the master, I really appreciate them)
PS, byte 17 bit 1 doesn't appear to do much. T73a/55 is still 0V all the time
Might need some more wires to T73a...
It's very easy iichel, e.g. +30 = Milliarium Aureum (+15,+75,+86,+50 ... all roads lead to Rome). :mrgreen:
All positive signals are specified in the Beetle diagrams, it is not necessary to rename them. Each of them has its mission and its moment, conditioned by your actions, the relays and the units that transform these positive signals into each other. All them are important and none them is the same as the other.
If you re-condition one of those signals are renamed, e.g. 15a, 50a, etc ...
It is the same as a normal Ignition/starter switch (D) but controlled by units and relays. (check it out)
The last condition for 50a is the BCM, so ... :?: Coding, Adaptation, a new BCM for kessy?
I'm not sure the BCM itself is the problem. In the beetle 5C1 and new Jetta, the normal ignition lock also involves the converter box J935 and T73a/55.
It's not that the T73a/55 is exclusive to the kessy system. It's present in all cars. My current 7E0 937 090 has the necessary pins for kessy (T73a/47, /55).
Concerning the names, you're right. I've 'translated' them into the names that make sense for me. Maybe it's better to name them with the J324 J680 J681 etc. No confusion :mrgreen:
edit 1:
T73a/55 is also present in the Polo 6R, but only in the wiring scheme for the 6-speed automatic gearbox. ELSAWIN 96/2
edit 2:
my T73a/ inside
The key to a live T73a/55 is probably in the adaptation channels. None of the long codings of the Jetta does it for me now... Still no activity on it. :mrgreen:
Maybe. You must get the BCM adaptation channels from a Beetle with kessy to compare.
This morning I tried with all possible Bytes on my 6R and no fault was reported in the Autoscan. :|
autoscan VW beetle with kessy:
Saturday,04,March,2017,14:22:29:62066
VCDS Version: 17.1.3.0 (x64)
Data version: 20170220 DS267.3
www.Ross-Tech.com
Workshop Code: 111 11111 011111
VIN: WVWZZZ16ZCM  License Plate:
Mileage: 63520km-39469mi   Repair Order:
Chassis Type: 16 (6R0)
Scan: 01 02 03 05 08 09 10 15 17 19 25 2B 2E 44 55 56
VIN: WVWZZZ16ZCM   Mileage:
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 06J 906 027 AJ    HW: 06J 907 309 A
   Component: MED17.5.2        04 2159
   Revision: P3H07---    Serial number:
   Coding: 0403000C1C070160
   Shop #: WSC 00066 000 00000
   VCID: 73EFD9B312475AD9E4-8026
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 057 C    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2726
   Revision: 05351113    Serial number: 00001108031637
   Coding: 0000020
   VCID: 1933CB1BD06BC0890E-804C
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 5C0 907 379 C    HW: 5C0 907 379 C
   Component: ESP MK60EC1   H31 0156
   Revision: 00H31001
   Coding:
   VCID: 2E5908C779E537314B-807A
1 Fault Found:
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded - Intermittent
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 141
                    Mileage: 63479 km
                    Time Indication: 0
                    Date: 2017.02.17
                    Time: 16:33:10
                    Count: 0
                    Count: 32768
                    Count: 12800
                    Count: 397
                    Count: 50944
                    Count: 0
                    Count: 65275
                    Count: 0
   Part No SW: 5K0 959 434 A    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0802
   Revision: 00085000    Serial number: 0152699723
   Coding: 030C0C
   ASAM Dataset: EV_KESSY_PQ35GP A01018
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 336F19B39AC71AD924-8066
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5C0 907 044 N    HW: 5C0 907 044 N
   Component: Climatronic   043 0203
   Revision: 00001001
   Coding: 3010004002
   Shop #: WSC 00066 000 00233
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_VW32.rod
   VCID: 2E5908C771E537314B-807A
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 088 F    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H50 0352
   Revision: BU050001    Serial number: 04571045120169
   Coding: 6CB8697B0801080008A809916E0F84C4F8C2670F60851841B2E004010000
   VCID: 4183437BD87BB849A6-8014
   Subsystem 1 - Part No SW: 6R0 959 801 AQ    HW: 6R0 959 801 AQ  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 1060
   Serial number: KU0KU012121200015262
   Coding: 0CBC34
   Subsystem 2 - Part No SW: 6R0 959 802 BD    HW: 6R0 959 802 BD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 1060
   Serial number: KU0KU014121200012026
   Coding: 0CBC34
   Subsystem 3 - Part No SW: 5C5 959 591     HW: 5K0 959 591
   Component: J245 PS71.023  H09 0007
   Serial number:     WRH000488A0
   Coding: 381000
   Subsystem 4 - Part No SW: 5C0 959 442     HW: 5C0 959 442
   Component: E221__MFL-TK6  H02 0103
   Serial number: 30000000000000388094
   Coding: E30000
Address 10: Park/Steer Assist (J446)       Labels: 1Q0-919-475.clb
   Part No SW: 5C5 919 475     HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H10 0005
   Revision: --------    Serial number: 83491133900210
   Coding: 108101
   Shop #: WSC 00066 000 00125
   ASAM Dataset: EV_EPHVA18VW3240000 001004
   ROD: EV_EPHVA18VW3240000.rod
   VCID: 70E5D6BFAB5161C119-8024
   Part No SW: 5C0 959 655 F    HW: 5C0 959 655 F
   Component: AirbagVW10    013 0613
   Serial number: 003JQM007V0M
   Coding: 0000424B
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 356B27AB94B304E90A-8060
   Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME3B476368ZZZ+
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME4E657468ZZZ5
   Part No SW: 5C5 920 870     HW: 5C5 920 870
   Component: KOMBI         H10 0015
   Revision: X0010005    Serial number:
   Coding: 150B01
   ASAM Dataset: EV_KombiUDSMM9RM10 A04305
   ROD: EV_KombiUDSMM9RM10_VW32.rod
   VCID: 67D7BDE39E9FA67948-8032
Address 19: CAN Gateway (J533)       Labels: 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H38 0035
   Revision:   H38       Serial number: 05021201300171
   Coding: 254080
   VCID: 346D1AAF97C91DE13D-8060
   Part No SW: 5K0 953 234     HW: 5C5 920 870
   Component: IMMO          H10 0015
   Coding: 000007
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
   ROD: EV_ImmoUDSMM9RM10_VW21.rod
   VCID: 6AD1C4D78D8D9B1157-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000245748003
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7661805893
   Coding: 010000
   VCID: 2953FBDB400B50099E-807C
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 346D1AAF57C91DE13D-8060
   Coding: 0310000001000000
   ROD: EV_HeadlRegulVWLWRPt_VW32.rod
   VCID: 77F7EDA3CE3F36F9D8-8022
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 F    HW: 3C8 035 195 F
   Component: Radio RCD510  050 0207
   Revision: 00000001    Serial number: VWZ1Z3M8222131
   Coding: 01000400040002
   VCID: 2B5F01D34AF742196C-807E
End-------------------------(Elapsed Time: 02:38)--------------------------
adapmap BCM:
;SW:6R0-937-088-F   HW:6R0-937-088 ---  Cent. Elect.
;Component:BCM PQ25 Re4  H50 0352	 Coding:6CB8697B0801080008A809916E0F84C4F8C2670F60851841B2E004010000
;Saturday	4	March	2017	14:31:12:62066
;VCDS Version: Release 17.1.3 (x64)  Data version: 20170220 DS267.3
;VCID: 4183437BD87BB849A6-8014
Channel		Field 1	Field 2	Field 3	Field 4
1	0	N/A	N/A	N/A	N/A
2		ERROR:	Channel 02	Not	Available
3	1	N/A	N/A	N/A	N/A
4	0	N/A	N/A	N/A	N/A
5	0	N/A	N/A	N/A	N/A
6	0	N/A	N/A	N/A	N/A
7	1	N/A	N/A	N/A	N/A
8	0	N/A	N/A	N/A	N/A
9	0	N/A	N/A	N/A	N/A
10	0	N/A	N/A	N/A	N/A
11	0	N/A	N/A	N/A	N/A
12	1	N/A	N/A	N/A	N/A
13	0	N/A	N/A	N/A	N/A
14	0	N/A	N/A	N/A	N/A
15	0	N/A	N/A	N/A	N/A
16	0	N/A	N/A	N/A	N/A
17		ERROR:	Channel 17	Not	Available
18	0	N/A	N/A	N/A	N/A
19		ERROR:	Channel 19	Not	Available
20	1	N/A	N/A	N/A	N/A
21		ERROR:	Channel 21	Not	Available
22	1	N/A	N/A	N/A	N/A
23	1	N/A	N/A	N/A	N/A
24	0	N/A	N/A	N/A	N/A
25	0	N/A	N/A	N/A	N/A
26		ERROR:	Channel 26	Not	Available
27	0	N/A	N/A	N/A	N/A
28	0	N/A	N/A	N/A	N/A
29	1	N/A	N/A	N/A	N/A
30	2	N/A	N/A	N/A	N/A
31	0	N/A	N/A	N/A	N/A
32	40	N/A	N/A	N/A	N/A
33	80	N/A	N/A	N/A	N/A
34	30	N/A	N/A	N/A	N/A
35	2	N/A	N/A	N/A	N/A
36	2	N/A	N/A	N/A	N/A
37	80	N/A	N/A	N/A	N/A
38	21	N/A	N/A	N/A	N/A
39	20	N/A	N/A	N/A	N/A
40	14	N/A	N/A	N/A	N/A
41	20	N/A	N/A	N/A	N/A
42	5	N/A	N/A	N/A	N/A
43	3	N/A	N/A	N/A	N/A
44	5	N/A	N/A	N/A	N/A
45	100	N/A	N/A	N/A	N/A
46	1	N/A	N/A	N/A	N/A
47	15	N/A	N/A	N/A	N/A
48	15	N/A	N/A	N/A	N/A
49		ERROR:	Channel 49	Not	Available
50	0	N/A	N/A	N/A	N/A
51	0	N/A	N/A	N/A	N/A
52	0	N/A	N/A	N/A	N/A
53		ERROR:	Channel 53	Not	Available
54		ERROR:	Channel 54	Not	Available
55		ERROR:	Channel 55	Not	Available
56		ERROR:	Channel 56	Not	Available
57		ERROR:	Channel 57	Not	Available
58		ERROR:	Channel 58	Not	Available
59		ERROR:	Channel 59	Not	Available
60		ERROR:	Channel 60	Not	Available
61		ERROR:	Channel 61	Not	Available
62		ERROR:	Channel 62	Not	Available
63		ERROR:	Channel 63	Not	Available
64		ERROR:	Channel 64	Not	Available
65		ERROR:	Channel 65	Not	Available
66		ERROR:	Channel 66	Not	Available
67		ERROR:	Channel 67	Not	Available
68		ERROR:	Channel 68	Not	Available
69		ERROR:	Channel 69	Not	Available
70		ERROR:	Channel 70	Not	Available
71		ERROR:	Channel 71	Not	Available
72		ERROR:	Channel 72	Not	Available
73		ERROR:	Channel 73	Not	Available
74		ERROR:	Channel 74	Not	Available
75		ERROR:	Channel 75	Not	Available
76		ERROR:	Channel 76	Not	Available
77		ERROR:	Channel 77	Not	Available
78		ERROR:	Channel 78	Not	Available
79		ERROR:	Channel 79	Not	Available
80		ERROR:	Channel 80	Not	Available
81		ERROR:	Channel 81	Not	Available
82		ERROR:	Channel 82	Not	Available
83		ERROR:	Channel 83	Not	Available
84		ERROR:	Channel 84	Not	Available
85		ERROR:	Channel 85	Not	Available
86		ERROR:	Channel 86	Not	Available
87		ERROR:	Channel 87	Not	Available
88		ERROR:	Channel 88	Not	Available
89		ERROR:	Channel 89	Not	Available
90	0	N/A	N/A	N/A	N/A
91		ERROR:	Channel 91	Not	Available
92		ERROR:	Channel 92	Not	Available
93		ERROR:	Channel 93	Not	Available
94		ERROR:	Channel 94	Not	Available
95		ERROR:	Channel 95	Not	Available
96		ERROR:	Channel 96	Not	Available
97		ERROR:	Channel 97	Not	Available
98		ERROR:	Channel 98	Not	Available
99	0	N/A	N/A	N/A	N/A
now time for number crunching :lol:
my bcm:
;SW:7E0-937-090   HW:7E0-937-090 ---  Cent. Elect.
;Component:BCM PQ25 Max4 H80 0733	 Coding:3CB02FF828CB2400933806E2FFEB9FD080A273EFE08D78D020E050032800
;Saturday	4	March	2017	18:41:02:62066
;VCID: 68D5BEDF9B81A90141-803C
1	0	N/A	N/A	N/A	N/A
3	1	N/A	N/A	N/A	N/A
4	1	N/A	N/A	N/A	N/A
5	0	N/A	N/A	N/A	N/A
6	0	N/A	N/A	N/A	N/A
7	0	N/A	N/A	N/A	N/A
8	0	N/A	N/A	N/A	N/A
9	0	N/A	N/A	N/A	N/A
10	1	N/A	N/A	N/A	N/A
11	1	N/A	N/A	N/A	N/A
13	1	N/A	N/A	N/A	N/A
16		ERROR:	Channel 16	Not	Available
18		ERROR:	Channel 18	Not	Available
27	1	N/A	N/A	N/A	N/A
28	1	N/A	N/A	N/A	N/A
32	50	N/A	N/A	N/A	N/A
33	50	N/A	N/A	N/A	N/A
34	20	N/A	N/A	N/A	N/A
39	15	N/A	N/A	N/A	N/A
42	10	N/A	N/A	N/A	N/A
43	4	N/A	N/A	N/A	N/A
45	70	N/A	N/A	N/A	N/A
47	30	N/A	N/A	N/A	N/A
48	30	N/A	N/A	N/A	N/A
53	1	N/A	N/A	N/A	N/A
54	1	N/A	N/A	N/A	N/A
55	0	N/A	N/A	N/A	N/A
56	0	N/A	N/A	N/A	N/A
57	0	N/A	N/A	N/A	N/A
58	0	N/A	N/A	N/A	N/A
59	1	N/A	N/A	N/A	N/A
60	200	N/A	N/A	N/A	N/A
61	200	N/A	N/A	N/A	N/A
62	5	N/A	N/A	N/A	N/A
63	21	N/A	N/A	N/A	N/A
64	0	N/A	N/A	N/A	N/A
65	0	N/A	N/A	N/A	N/A
66	3	N/A	N/A	N/A	N/A
67	8	N/A	N/A	N/A	N/A
68	0	N/A	N/A	N/A	N/A
69	0	N/A	N/A	N/A	N/A
70	20	N/A	N/A	N/A	N/A
71	0	N/A	N/A	N/A	N/A
72	0	N/A	N/A	N/A	N/A
73	0	N/A	N/A	N/A	N/A
74	0	N/A	N/A	N/A	N/A
75	0	N/A	N/A	N/A	N/A
76	0	N/A	N/A	N/A	N/A
77	0	N/A	N/A	N/A	N/A
78	0	N/A	N/A	N/A	N/A
79	0	N/A	N/A	N/A	N/A
80	0	N/A	N/A	N/A	N/A
81	0	N/A	N/A	N/A	N/A
82	0	N/A	N/A	N/A	N/A
83	0	N/A	N/A	N/A	N/A
84	0	N/A	N/A	N/A	N/A
85	0	N/A	N/A	N/A	N/A
86	0	N/A	N/A	N/A	N/A
87	0	N/A	N/A	N/A	N/A
88	0	N/A	N/A	N/A	N/A
89	0	N/A	N/A	N/A	N/A
91	0	N/A	N/A	N/A	N/A
92	0	N/A	N/A	N/A	N/A
93	0	N/A	N/A	N/A	N/A
94	0	N/A	N/A	N/A	N/A
95	0	N/A	N/A	N/A	N/A
96	0	N/A	N/A	N/A	N/A
97	0	N/A	N/A	N/A	N/A
And the winner to best diagram I've ever seen is:
Thanks! :lol: :lol: :lol:
Michel, I'm still checking ... I hope to find more of these things. :mrgreen:
Are you sure that Byte17 Bit1 does nothing?
Adam87
Drives: T5.2
Post by Adam87 »
ciclo wrote:And the winner to best diagram I've ever seen is:
Image?
[emoji23][emoji23] great mod [emoji106]
Thanks guys for the support.
My plan now:
1. Remove Kessy fuse
2. Revert to original coding of 3CB02FF828CB2400933806E2FFEB9FD080A073EFE08D78D0228400030800
3. Try to get T73a/55 active, as it sort of is part of the immobiliser (either BCM coding or adaptations)
4. Revert to kessy configuration, with a live T73a/55
After this, I'll continue work on the elec steering lock. Maybe it's the BCM that's causing some issues.
ciclo I think that's simply the audible feedback for Terminal 75. Hear click to continue ignition :mrgreen:
Because for BCM PQ25 there is hardly any information in the function descriptions, everything is always assumptions and tests.
BCMs comparison Beetle 2012 vs iichel's Polo(last BCM coding)
Long coding
Byte17 Bit1 ... Hmm, maybe this Bit is for T73a/55 output (it's an assumption, not sure :?).
Elsawin, search J682, J935... e.g. take a look at New Bora 2014 engine and kessy diagrams, also Jetta (AW0) & Beetle, compare with your 11' 6R CFWA (7L6)
Byte25 Bit6 ... Opening comfort through Kessy (if my translation from German is correct :oops:)
;LC,25,1,KESSY Wieder?ffnung ESchiebet?r
;LC,25,3,KESSY ?ffnung Heckdeckel bei Wiederentriegelung
;LC,25,4,KESSY Komfort-Reichweitenbegrenzung Verdeck
;LC,25,5,Komfortschlie?en ?ber Kessy
;LC,25,6,Komfort?ffnen ?ber Kessy
;LC,25,7,Verbau Kessy
Adaptation Channels
16,available (Kessy or sunroof?)
18,available (Kessy or sunroof?)
The most curious of all this is that the ETKA defines the BCM 6R0937088F for vehicles without kessy ... :lol:
