Can anybody help tonight I blew a fuse for the interior lights whilst changing them to led I didn't know which fuse to replace so I pulled out each 1 to see if I could see the blown 1 I managed to change it but now the EPC warning light is on.....any ideas
EPC warning light
Re: EPC warning light
Push all fuses more strongly into their slot (with a reasonable force
Do the ignition process again.
Perhaps the EPC warning light needs to be erased with some diagnostic tool. VCDS for example.
Vasey
- Drives: Polo gt bluemotion
Hi ciclo what a nightmare tonight started a job what should of taken half hour max been outside all night it drives ok still pulls could I disconnect the battery then re connector would that work? The car is still under warranty would vw know that I've had the fuses out?ciclo wrote:Push all fuses more strongly into their slot (with a reasonable force).
Vasey
Well disconnected the battery for half an hour lights gone out I've took it up the road seems to be ok
Perfect!
