retrofitting kessy to the Polo 6R
Re: retrofitting kessy to the Polo 6R
Yes, but who is expecting kessy on a Polo? ;) Probably not a lot of people.
No I understand your concern, it' a good point. But, you can even open a car with a screwdriver and some strength. Just brute force the lock...
If they want the car, they'll get it. A window can be smashed, an immobiliser can be hacked, an engine can be started.
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
Any updates?
Nothing to report so far. Busy, but on other things ;)
update for having nothing to update.
the immobilser part is not really working with me so far.
Normal Polo 6R:
Immobiliser is located in Instrument Cluster, the immobiliser chip reader and steering column lock are in the ignition lock. The immobilser works together with the Engine ECU to authorize start.
Modified Polo 6R with Kessy:
Immobiliser chip reader is distributed between start button and by proxy (kessy aerials)
Kessy aerials connect to kessy module
Electronic steering column lock is now part of the immobiliser too
The start button is connected to the steering column lock
Keys are completely new
So... what to do:
Programm IC to new keys
Match keys with steering column lock
Match keys with kessy module
Match steering column lock with IC
This process is done by a person I'd call a friend now. He's very busy making it all work, and with some small successes too. The new kessy keys can now start the engine... But not yet with the start button.
Thank you very much for the information. You two are doing a great job. 8)
I hope you both have success with the start button soon.
Looks good.
Please can you explain it? Thanks.
Yes master ;-)
It's the emergency start procedure. Here you hold the key against the reader coil and press the start button. This involves the electronic steering column lock, tacho, key and engine ECU. This works together now.
The next and final step is start by proxy, to detect the key by proxy through the kessy antennas. This will enable true keyless start and keyless entry and exit.
Ok thanks. Awesome, good luck with that final step. :wink:
quick autoscan, just need to adapt the keys to the kessy module to make keyless entry and keyless start possible.. :-)
Thursday,15,June,2017,14:43:53:62066
VCDS Version: 17.1.3.0 (x64)
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWZZZ6RZBYiichel   License Plate:
Mileage: 10km-6mi   Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56 61 69 6C 77
VIN: WVWZZZ6RZBYiichel   Mileage: 10km-6miles
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J000-CFWA)       Labels: 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9978
   Revision: 12005001    Serial number:
   Coding: 00114036033401080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TDI03103P906021B 001041
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 2757FDE35E1F667988-8072
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210248E3416F00B7842B12E782D500521700
   VCID: 07179D63B2DF4679A8-8052
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 000F0F
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSYPQ35G_VW01.rod
   VCID: 37772DA38EBFF6F918-8062
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 38752E9F8BA1F98111-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 092150183
   Coding: 3CB02FF828CB2400933806E2FFEB9FD080A273EFE08D78D0228400030800
   VCID: 68D5BEDF9B81A90141-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 140415 03  37  0059
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140002547420014516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  002 0803
   Serial number: KU0-KU008.06.0910897
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231422402620
   Coding: 318001
   ROD: EV_EPHVA18VW250GPCS.rod
   VCID: 3B7F3193B297D299FC-806E
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A916457ED4D7B1177-801E
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140E01
   VCID: 336F19B39AC71AD924-8066
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 042201
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 040C00E200000000000000
   VCID: 2E5908C771E537314B-807A
   Component: IMMO          H04 0709
   Coding: 000007
   VCID: 6AD1C4D78D8D9B1157-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F6715C376EF3E3940-807A
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
   VCID: 2B5F01D34AF742196C-807E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Coding: 00070002010000A10001
   VCID: 366920A781B50FF103-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH14 0120
   Revision: 00H14000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   Shop #: WSC 02757 790 00000
   VCID: 2F6715C3BEEF3E3940-807A
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H09 0110
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ˇ
   Subsystem 4 - Serial number: H21982ˇ
   Part No: 6R0 423 156 B
   Coding: 11220
   Shop #: WSC 00788
   VCID: 2F6715C3EAEF3E3940-807A
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
   VCID: 2855FEDF5301690181-807C
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0192000001000000
   Shop #: WSC 00788 648 00255
   VCID: 77F7EDA3CE3F36F9D8-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0733
   Coding: 03071A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F6715C37EEF3E3940-807A
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65CBB7EBAC93B4697A-8030
1 Fault Found:
03006 - Back-up Camera System not calibrated
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 17
                    Time Indication: 0
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105254406
   Coding: 020100000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_002.rod
   VCID: 254BF7EB24137469BA-8070
End-------------------------(Elapsed Time: 04:47)--------------------------
You are close to getting it. :wink:
So, some kessy update..
Kessy is in it, car can be started by push button
For push button, it needs new steering column trim
For kessy, it also needs electronic steering column lock, does not fit in the current Polo OEM trim
So I bought a Scirocco trim: 1K8 858 599 A
For that it needs the steering column switch to fit, i.e. for VW Up (with rear window washer/wiper): 1S0 959 503 x
For that you need a new steering angle sensor.
I first had one from the Beetle 5C: 5C0 959 653. But this one only works on CAN powertrain protocol 2.0
Our polos still have the protocol 1.6 for the ABS. Probably it will work with the 6RA 959 654.
So, that's the plan now.
I also plan to transform the stalks to those of the Golf 7. Simply because they looks better. Will be a job, to transform CC etc inside the stalk..
Work in progress...
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
[emoji106][emoji106]
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
iichel wrote: Tue Jun 27, 2017 1:17 pm So, some kessy update..
Work in progress...
sir,
you are amazing.
bow down to your dedication and finding way to achieve this.
spacewalker
Drives: Just a VW
Post by spacewalker »
I have solution for you
In weekend will add keys again to my car , because device have wrong desctription
seems to be wrong because not working like that , but working in a different way , so need to re-learn all keys again to be sure procedure is good
screw VAS ;)
