I have 2010 Polor 6R Highline with TPMS. I have a reset button in the glovebox so I guess its indirect TPMS. The warning light is on (not blinking), but I can not turn it off (reset it). I am holding the button with ignition on for like ten seconds, but no beep and the light s still on.
What am I doing wrong?
TMPS reset button
Re: TMPS reset button
Button broken/disconnected?
maTTew
- Drives: 6R 2010 1.4 16V 63kW Highline
That would be weird. The buton has red backlight so its connected somehow.
Penarth Blues
- Drives: 2015 Polo GTI 5 door Black M6
Obvious question but have you checked the tyre pressures are actually correct?maTTew wrote:Hi,
maTTew
Yes, I checked all of them.
maTTew
It was the button. I removed glovebox and push connector on the tpms button. It clicked somehow and button now works. I just dont know how that happend. Airbag was never changed.
You can access to this connector by removing the dashboard side cover... in case it happens again.
