Indian Polo does not come fitted with brightness control switch(Dimmer switch), but only fitted with headlight range control switch.
I am planning to install dimmer switch " 6Q0 941 333 C" . It has controls for both brightness as well as headlight range control.
I am posting a new topic with pictures as per advice of master ciclo
Picture of stock switch
Picture of new switch, which I am planning to install " 6Q0 941 333 C" .
Comparison
Back side of both switches(left is stock, right one is new switch)
Pictures of stock T6 connector
Fuse box Layout
VCDS autoscan
Thursday,02,March,2017,00:28:24:05031
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: MEXL15606GT048293 License Plate:
Chassis Type: 60 (6RU)
Scan: 01 02 03 08 09 15 17 19 25 44 56
VIN: MEXL15606GT048293 Mileage: 15420km-9581miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: 00000000000000
Coding: 00250056232400080000
Shop #: WSC 53863 002 1048576
ASAM Dataset: EV_ECM21TFS02103F906070KC 004006
ROD: N/A
VCID: 6DD6519BBC82595686-8038
No ASAM data for: "EV_ECM21TFS02103F906070KC" (VW26)
Readiness: 0000 0000
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6502
Revision: 00043014 Serial number: CU501508317273
Coding: 0000020
Shop #: WSC 01260 002 1048576
VCID: 3A7CAAC7754C3EEE53-806E
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422703C8461624724254C0800908
Shop #: WSC 29230 002 1048576
ASAM Dataset: EV_Brake1ES9P0iBOSCH 003031
ROD: N/A
VCID: 0B123F03A256F76638-805E
No ASAM data for: "EV_Brake1ES9P0iBOSCH" (VW26)
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 418EDD2BD89A6D3612-8014
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6RU 937 087 M HW: 6RU 937 087
Component: BCM IM H+4 H40 0432
Revision: BZ040001 Serial number: 0300 294150201
Coding: 3AB02BFF08A10000003800007C2B949000C0414F608C0000200000000000
Shop #: WSC 124697 483 00190
VCID: 6CD05C9F8F98505E91-8038
Subsystem 1 - Part No SW: 6R0 959 802 CC HW: 6R0 959 802 CC Labels: 6R0-959-802.CLB
Component: ------------- 007 5551
Coding: 050000
Subsystem 2 - Part No SW: 6R0 959 801 BT HW: 6R0 959 801 BT Labels: 6R0-959-801.CLB
Coding: 050000
Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Coding: 240000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5550
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Coding: 020000
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW0118WCJ
Coding: 003036
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_AirbaVW10BPVAW250 A01001
ROD: N/A
VCID: 499EC50BE8AAA576CA-801C
No ASAM data for: "EV_AirbaVW10BPVAW250" (VW26)
Part No SW: 6RF 920 861 HW: 6RF 920 861
Component: KOMBI H01 0214
Coding: 140800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 0818000FB3209C7E15-805C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 087
Component: GW-K-CAN TP20 H40 0432
Revision: BZ040001
Coding: 002300
VCID: 193E554B108A15F6BA-804C
Component: IMMO H01 0214
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_DVD_RM09 A03710
ROD: N/A
VCID: 6ADC5A878D6C4E6EE3-803E
No ASAM data for: "EV_Immo_UDS_DVD_RM09" (VW36 *)
Address 44: Steering Assist (J500) Labels: 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ASAM Dataset: EV_TseerAssisNSK 014008
ROD: N/A
VCID: 418EDD2BD09A6D3612-8014
No ASAM data for: "EV_TseerAssisNSK" (VW12)
Address 56: Radio (J503) Labels: None
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 01855GD0000318
Coding: 00000440010005
Shop #: WSC 00081 790 00118
VCID: 4586C93BCCB241162E-8010
End-------------------------(Elapsed Time: 02:22)--------------------------
Namaste.
