Great, thanks!ciclo wrote:Ok. Thank you.
(I'll tell you later what to do with the cables you've already received)
I am subscribed to your topic.
I´ll try to do as much as possible... at least I´m willing to tryciclo wrote:The price of the wires depends on what you are able to do (with our help) with some cables that you will receive, maybe zero. We will try to make it zero (in your new topic).
Pave wrote:I´ll try to do as much as possible... at least I´m willing to tryciclo wrote:The price of the wires depends on what you are able to do (with our help) with some cables that you will receive, maybe zero. We will try to make it zero (in your new topic).
viewtopic.php?f=56&t=69826&p=520887#p520887
viewtopic.php?f=56&t=58703&start=3270#p520208
My first keychain 3D printed...
With secret compartment...
Big thanks benzinkopf!!
Lol I need to get myself one of those
At least vw had the decency to move the gear shift lever towards the driver
LOL!...iichel wrote:At least vw had the decency to move the gear shift lever towards the driver
Two clues, you have to take into account the ignition key position on the first image.
I don't know that, but I do have another question to VW.
They went through all the effort of making a RHD DSG lever with the push button on the right hand side. But somehow they forgot to put the PRNDS+- display on the right side too.
Now we start up the Adobe Photoshop
So we can see that the button is there, but it's not illuminated with the ignition on and even the engine running. In my Polo with the 7E0 BCM it is always illuminated, and more brightly than 7H0 BCM
Exactly!
It can be modified according personal taste of each one.
I'll have to do the tests this weekend.
New mod/discovery (VCDS)
Backlit Hazard Button. PQ25
How does it work?
- It works with the light switch in '0' position, or with the light switch in the 'AUTO' position and with the lights off.
- It turns on when you press the unlock button on the remote to open the car.
- It turns off when you press the lock button on the remote to close the car.
And the winner is:
Address 09: BCM Adaptation ---> channel 68 (from 0 to 1)
How does it work?
And the winner is:
benzinkopf
- Drives: 1.2TSI 105HP DSG7
So its going to light up permanently during the drive right?
Yes, on a medium level of lighting. When pressed the button it works as usual.
I will leave it activated, it reminds me of other flying ships.
In this other video you can see the difference (lights ON).
This video is from when I did the passenger airbag deactivation system installation. A long time ago... long story.
Thank you for the effort and dedication that you did to make the keychain. I like it a lot.
By the way, I forgot to mention that the
humidity sensor function works perfectly. Pleasantly surprised.
Excellent!!! I recommend it 100% (or more).
benzinkopf
No worries Master! I made the keychain for my personal use and im not sure you notice that it can be opened and I can store the coin battery for remote as spare. I'm worried that my key fob battery might die soon, so I made it. Its a small gift i can think of since you gave me lots of gifts!ciclo wrote:Yes, on a medium level of lighting. When pressed the button it works as usual.![]()
