Testing Gateway codings.
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 0022FB :shock:
Shop #: WSC 12345 123 12345
VCID: 682176FECFDE5BD515-803C
Nothing found for now
Wednesday,17,May,2017,13:50:33:06516
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: TESTING (GATEWAY)
Mileage:   Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   VCID: 6A2F6AF4FFC84FE7E5-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 02C73ACC53D0BF8F25-8056
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Serial number: 08021613470174
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7E3B42302F2CC77345-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38F1D66E0FCE7B0595-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 320160060
   Coding: 3CB02FBF48E12400B3380FD17CEB9FD0DAC067AF600D30D0220000030800
   VCID: 2AEFEA34F788CFA7E5-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3EFBC2702FEC473345-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A0FAA947F280F87E5-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 219 91226
   VCID: 35F2D0570BD189708D-8060
   Revision: B9081001
   Coding: 0022FB
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2EEBE240EFBCA743C5-807A
   Component: IMMO          H05 0607
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   VCID: 37F0D46D0BCB7D029D-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2FE8E4457FB3AD4ADD-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 7730542D030BFD429D-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3BFCCC7933FF551E7D-806E
End-------------------------(Elapsed Time: 04:19)--------------------------
I think now it's harder to navigate through the forum with the upgrade. Maybe it's a personal feeling or lack of knowledge.
Some times I used to see/navigate through the forum without login, and now my browser (chrome) warns me that it is not a secure site due to the scripts (videos). I have to give the appropriate permissions every time I view a page that it contains videos to be able to see them. :?
I guess this will happen to many people without login and this limits the use of the forum widely. :( :cry: ... :lol:
The first page of my topic is an example.
CNK
Drives: 6R
Post by CNK »
It's because youtube BB Code uses http instead of https:
for images with http you can use proxy (I don't know if it's possible in phpBB, I'm owner of XenForo :P)
alexperkins
Site Admin
Post by alexperkins »
Ive fixed the Youtube issue. All videos are now in HTTPS
alexperkins wrote: Fri May 19, 2017 11:00 am Ive fixed the Youtube issue. All videos are now in HTTPS
Excellent. Thanks for all the great work you do. Image
CNK
Drives: 6R
Post by CNK »
Great! But why wrap block has got only 850px width? :(
.wrap {
    max-width: 850px;
:roll:
alexperkins
Site Admin
blame phpBB lol
They decided to make it a standard for an 850px wide forum
Ive just done some tweaking and got rid of that 'feature' :D
Dave v
Drives: 6n2
Post by Dave v »
Hi there
I've previously posted around the wiring for a 090 BCM on a T5.1, was following Adam's progress through the wiring diagrams and guidance from Ciclo.
I was advised and then planned to start a new thread, but not sure what section to place it in as not a Polo?
Anyhow, I'll chance my luck to see if Ciclo or anyone else maybe able to assist, read that Adam sorted Xenon's on he's T5.
I've replaced the BCM previously and wired the lights as per Elsa/the guide, eg all fed from the BCM- Everything has been working fine for some time.
I've recently purchased a set of Bi Xenons and adaptor plugs (T10-T14). When first fitted nothing worked, so I checked and re- wired the adapter plugs as below:
Pins 1-4 Not used currently as auto range control is in future plans
Pin 5 - Negative
Pin 6 - Dipped beam/Xenons
Pin 7 - Negative
Pin 8 - High Beam
Pin 9 - Indicator
Pin 10 - T73b/6
Pin 11 - High beam/for shutter control
Pin 12 - To TFL/DRL
All's working fine apart from the LED DRL's, full scan below
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CAAC) Labels: 03L-906-022-CAA.clb
Part No SW: 03L 906 022 CH HW: 03L 907 309 K
Component: R4 2,0L EDC X31 9126
Revision: 26X31--- Serial number: 00000000000000
Coding: 01194012231400080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01103L906022CH 002012
ROD: EV_ECM20TDI01103L906022CH_002.rod
VCID: 6DD1A8F5BC7F942914-8038
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 E HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0103
Revision: 00H43001
Coding: 508724AD89A50A9824A89171A96710
Shop #: WSC 02736 790 49152
VCID: 34677D9197D505E11B-8060
Address 04: Steering Angle Labels:
VCID: 55A1E015ACEF3CE9CC-956C
Address 08: Auto HVAC (J301) Labels: 7E5-907-047.clb
Part No SW: 7E5 907 047 BG HW: 7E5 907 047 BG
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
Shop #: WSC 02736 790 50316
ROD: EV_ClimaticT5.rod
VCID: 75E18095D42F5CE9EC-8020
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 HW: 7H0 937 090
Component: BCM PQ25 Max4 H72 0708
Revision: B9072001 Serial number: 0531 053120030
Coding: B8A020380E212021002800803C2B8450F00066FF60060040300000000000
VCID: 6BD5A6ED8A6B9A190A-803E
Subsystem 1 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-801.CLB
Component: J386__TSG_FT 003 0304
Coding: 050000
Subsystem 2 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-802.CLB
Component: J387__TSG_BT 003 0308
Coding: 040000
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0912947
Coding: 820000
Part No SW: 7E0 959 655 A HW: 7E0 959 655 A
Component: VW10Airbag00Y H05 0011
Revision: -------- Serial number: 003E5000CS7Q
Coding: 000000000000000000000000000000003059
ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 34677D919FD505E11B-8060
Part No SW: 7E0 920 970 E HW: 7E0 920 970 E
Component: KOMBI H04 0305
Coding: 160A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
VCID: 2C5765F147E55D2143-8078
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H72 0708
Revision: B9072001
Coding: 042300
VCID: 70EFB181A34D79C13F-8024
Component: IMMO H04 0305
Serial number:
VCID: 6ADBA3E98D91831171-803E
Address 56: Radio (J503) Labels: 1K0-035-1xx-56.lbl
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 013 0036
Revision: 00000000 Serial number: VWZ1Z2I6830021
Coding: 0500020002
Shop #: WSC 02736 790 00000
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 86
Mileage: 145936 km
Time Indication: 0
Date: 2017.05.21
Time: 11:00:03
Address 69: Trailer (J345) Labels: 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: 306F718163CD39C17F-8064
Address 0B: Sec. Air Heating Labels:
End-------------------------(Elapsed Time: 02:12)--------------------------
The side lights, T10/10 from the original isn't connected to anything- should it be?
Any help would be very much appreciated.
Hm, I cannot quickly check the coding, but these wires need to be ok:
T14/12 left to T73b/5
T14/12 right to T73b/6
T73b/11, check presence of a wire. There needs to be a +30 (constant 12V) to T73b/11. MIght already be present if you have static cornering lights...
Dave v
Drives: 6n2
Post by Dave v »
iichel wrote: Mon May 22, 2017 3:35 pm Hm, I cannot quickly check the coding, but these wires need to be ok:
Thanks for the reply.
I've checked and double checked Elsa:
T14/12 left to T73b/3
T14/10 left to T73b/5
T14/12 right to T73a/5
T14/10 right to T73b/6
Any idea if I'm checking the wrong version to have the above differences?
T14/11 also give the impression it's a switched live with the main beam, although can just try connecting to +30
T73b/11, not T14/11...
Dave v
Drives: 6n2
Post by Dave v »
iichel wrote: Mon May 22, 2017 5:01 pm T73b/11, not T14/11...
Sorry, somehow miss read that.
I'll check- thanks for you help.
Dave v
Drives: 6n2
Post by Dave v »
Tried connecting T73b/11 to +30, DRL's/LED's still not functioning.
Anything else I should check?
Hi Dave v. (welcome)
At a quick glance. It's a coding problem, I'll tell you the BCM coding tomorrow. :wink:
Dave v
Drives: 6n2
Post by Dave v »
ciclo wrote: Mon May 22, 2017 9:26 pm Hi Dave v. (welcome)
Thanks Ciclo, appreciated.
Locked
