Big-PaPi
Drives: 6R Polo TSI SEL
Post by Big-PaPi »
ciclo wrote: Wed Apr 29, 2015 2:12 pm New Mod
Lower grill and fog covers RLine 6C. OEM.
Parts:
Lower grill R-line 6C
6C0853677J 041
Fog covers R-line 6C
6C0853665F 041
6C0853666F 041
PR-041 gloss black from factory
CHE SPETTACOLO! :D
Upper grill R-line 6C
This looks so smart, do you know if these fit the standard 2011 TSI SEL front bumper? or if not do you know if there is an option to have Gloss Black standard grills?
Welcome Big-PaPi
They do not fit into the standard bumper. Only for the front bumper R-line (6R, or 6C without ACC).
AFAIK the gloss black grills were not made for a standard 6R front bumper, so the only way is to paint them yourself, or in a paint shop.
patil
Post by patil »
Master Namaste :D
I need your help!
I am planning to install Mirror auto fold module K- 418 along with 5 pin JD-1914 relay, as you did previously.
My question is regarding tapping +12v/15amp fuse (+30) from the fusebox.
In my RHD fuse box, SB49 (+30) is not empty to tap the line. It has 15amp fuse.
Only SB44(+30) is empty with a line. It is assigned for Anti theft alarm ultrasonic sensor(Rated +5amp), which is not there in my car. Can I tap from here???
your suggestions will be important for me. I have put a picture of my fusebox layout, to help you understand better.
Do not touch the fuse 49, for the Polo 6R / Sedan / Vento sold in Russia & India is to power the BCM T73b/11 pin. (same as fuse 57 for Polo 6R Europe)
The fuse slot 44 is perfect to get +30 power signal in your 6R (IND). :wink:
Namaste Patil. (I'm glad to know you're around here :D )
Image :)
patil
Post by patil »
ciclo wrote: Wed Jun 07, 2017 6:15 pm Do not touch the fuse 49, for the Polo 6R / Sedan / Vento sold in Russia & India is to power the BCM T73b/11 pin. (same as fuse 57 for Polo 6R Europe)
Thanks a lot Master :D Will update you the results when installation is done 8)
I always think of you as a big brother watching over other kids playing around their toys(6R's) :mrgreen:
Good luck for your TPMS project :lol:
It would be interesting to have more information on this. (Autoscan, software, etc ...)
source: http://www.mytiguan.com/index.php?/topi ... ntry347841
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
ciclo wrote: Thu Jun 08, 2017 7:04 pm It would be interesting to have more information on this. (Autoscan, software, etc ...)
As I found out info on Russian forums it will be possible to see tire pressures on headunit if you reflash your RNS 510 with the Bentley's firmware, but there is no any additional clarifications. :(
http://forum.skoda-club.ru/viewtopic.php?f=99&t=112747
Many thanks firegrafik. :wink:
IIRC the 'Car' menu also is present in the RNS 810 (Tuareg, Phaeton)
What about a color cluster?
edited by ciclo: :mrgreen:
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Wow. last time i heard its not possible. Now i see it is. Lol. Time changes everything
iichel wrote: Fri Jun 09, 2017 5:42 pm What about a color cluster?
[youtube]https://www.youtube.com/watch?v=S2ZV5SwbGis[/youtube
8)
Why do you do that? :lol:
ciclo wrote: Sat Jun 10, 2017 8:30 am
8)
For the same reason we do everything. Because we can
graaja
Drives: Polo GT TSi
Post by graaja »
iichel wrote: Sat Jun 10, 2017 12:06 pm
8)
Looks great iichel! Can you share info on which instrument cluster this is? Did you code this yourself or got it done at a dealer?
This is the cluster from a T6 with custom firmware for Polo (vehicle picture, wheel circumference, tank level) and Kessy. No dealer will do this for you.
Locked
