benzinkopf
- Drives: 1.2TSI 105HP DSG7
Dont have the bit 3 tick box doesnt mean you cant change the coding. Just change the fourth last binary digit to 1. Read the binary backwords.
76543210
76543210
Dammit.favi wrote: Sun Jun 11, 2017 7:30 pm Little problem with The two static cornering lights turn on with reverse
Don't have BIT3![]()
You have to change the Bit in the Binary.
How to do it?
firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
I will just put it here
New unit comes with Polo Sedans (Vento) from Russian VW factory.
Suspect this one is for MX market with 315MHz. I suppose we will see european 7E0937090D soon.
I know how it works (change BIT 3 in BYTE 21), but after changing BIT3 from 0 to 1 I have not seen the option, just like yours screenshot "Static cornering light ...."; Dciclo wrote: Sun Jun 11, 2017 7:57 pm Dammit.favi, all BCMs have such Bit.
But ... I saw today that everything works though
Hard days at work and such effects; D
So, thank u very much again ciclo
58 sec... (benji58
*****XML GENERATOR*****
http://htmlpreview.github.io/?https://r ... rator.html
*****TIRE PRESSURE*****
http://blobs.continental-tires.com/www8 ... e-data.pdf
There are still many things to test. (Play with CAN lines)
More information next week ... or ... when be possible.
Good info!! thanks firegrafik. Hmm... I want it!!!firegrafik wrote: Sun Jun 11, 2017 9:17 pm I will just put it here![]()
Hmm2
433 MHz 7E0 937 090 Max4
315 MHz 7E0 937 190 Max3
However, it is always necessary to verify it in the ETKA to be totaly sure.
firegrafik
As I have got for 090 units:ciclo wrote: Thu Jun 15, 2017 5:48 am
Good info!! thanks firegrafik. Hmm... I want it!!!![]()
Hmm2...as far as I know for 7E0:
However, it is always necessary to verify it in the ETKA to be totaly sure.![]()
7E0937090 - 434 MHz
7E0937090A - 315 MHz
7E0937090B - 434 MHz
7E0937090C - 315 MHz
so possible
7E0937090D - should have 434MHz
Guy, who sent me that photo,had tried to install that 090C on his Polo, keys adaptation wasn't success.
Okay. Thanks again.
I'll keep you informed by email about TPMS progress.
By the way, yesterday I went to my VW dealer to update the instrument cluster software and VW estimated that the software for my IC is correct and was not updated ... I had to pay for the diagnostic session (logically) ...
1000x
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 00788 219 00200
VCID: 35A22007DB61D9A0FD-8060
rdasadia
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140E01
Shop #: WSC 12345 123 12345
VCID: 47DEBB70FE4B81781C-8012
govindsharma
Component: KOMBI H03 0805
Coding: 140A00
Shop #: WSC 17218 938 12345
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 479D317AFE6CDE7A21-8012
Coding: 140E01
rdasadia
Coding: 140E01
govindsharma
Coding: 140A00
New CAN lines. TEST MODE
https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Images for TPMS wiring installation, the others CAN-lines are widely known.
More information when possible...
Wednesday,14,June,2017,11:29:20:06516
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: With indirect TPMS OFF (ABS & IC)
Mileage: 24890km-15465mi Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77 0B
VIN: WVWZZZ6RZDY0CICLO Mileage: 24890km-15465miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
VCID: 6A57422C17E0178FDD-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401500
Shop #: WSC 40308 002 104857
VCID: 02EF12E47BE887B71D-8056
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Serial number: 08021613470174
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7E631A684744AF1B3D-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 3819AE8657E6432D4D-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 320160060
Coding: 3CB02FBF48E12400B3380F916CEB9FD0DAC0672F600D30D0200000030800
VCID: 2A17C26C1FA0974FDD-807E
Component: RLHS 220816 0 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361212601014
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E239AA847042FDB3D-806A
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
VCID: 4A3782CC9740D7AFDD-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Coding: 140E00
VCID: 351AA88F23E9511865-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002200
VCID: 68494E1617F623FDCD-803C
Address 20: High Beam Assist. (J844) Labels: 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C00000000000000
Shop #: WSC 03607 002 104857
VCID: 2E13BA7807D48F6BBD-807A
Component: IMMO H05 0607
Shop #: WSC 00000 000 00000
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5218
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
VCID: 3718AC8553E3452A75-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V14 8477
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 00788
VCID: 2F10BC7DA7CB7572B5-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77582C455B23C56A75-8022
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000050821
ROD: EV_RDKBERU30_VW51.rod
VCID: 3718AC855BE3452A75-8062
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3B24A4914B173DC655-806E
End-------------------------(Elapsed Time: 04:25)--------------------------
At last one with TPMS (J502) can now compare auto scans,
Exactly!!Adam87 wrote: Sat Jun 17, 2017 12:23 pm At last one with TPMS (J502) can now compare auto scans,
I will be back soon.
Saturday,24,June,2017,14:41:06:06516
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: INDIRECT TPMS ON (DIRECT TPMS INSTALLED)
Mileage: 24920km-15484mi Repair Order:
VIN: WVWZZZ6RZDY0CICLO Mileage: 24920km-15484miles
Readiness: 0000 0000
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Coding: 01
Revision: V0000000
Coding: 0728DD
Coding: 0200A3
Coding: 1000AB
Coding: A4FFFF
Coding: 18BC32
Coding: 18BC32
Coding: 308001
Coding: 00314D
Serial number: 358
Coding: 140E01
Revision: B9081001
Coding: 002200
Revision: AA001001
Coding: 010100
Coding: 11221
Shop #: WSC 00788
End-------------------------(Elapsed Time: 04:28)--------------------------
More information when possible ...
PS: During the summer (vacations, etc...) I hardly have enough time to read the new topics of the forum (6R / 6C), I apologize for it.
patil
Master Namasteciclo wrote: Sun Jun 11, 2017 5:54 pm... in your case (6R IND), the winner ('ground wire') for trunk light is purple/violet wire. You can check with a diagnostic lamp/multimeter before splice or damage this wire.patil wrote: Sat Jun 10, 2017 8:15 pm Master Ciclo... I have a question regarding trunk light wiring.
Actually Indian Polo 6R does not come fitted with trunk light. I have retrofitted the trunk light and tapped the wiring from front dome light. So whenever any of the doors are opened trunk light will turn on, same way as footwell lights. I want to wire it like oem, so that light should lit only when trunk is opened and go off when trunk is closed. Is it possible?
I looked into wiring diagram, mentioned during your 2nd trunk light installation.
Pin 1 tapped from Pin1 T5h(Rear lid lock) RED/BLUE color wire.
Pin 2 from +30
Now the problem.. The RED/BLUE color wire in my car is in pin4, and a white wire is on pin1... please see picture.
How to proceed from here?![]()
Power supply is right (from the dome light).
Bang on!!! You are right..... purple/violet wire is indeed winning wire... Brilliant
I have rewired the trunk light connection, and now trunk light work exactly like OEM as I wished.
Thanks a lot again, Master
Hahaha ... perfect !!
I have to comment that it took me some time to review the diagrams to conclude that it was the purple wire, and taking into account that I do not have the diagrams for the Polo 6R IND
is a good find.
Thank you for the report!!. Namaste.
