1.9tdi abs problems - no start.
jclay
Drives: 9n
Post by jclay »
Hi guys, this is my last chance before i decide to sell the car as a non runner so any help will be much appreciated!
Story goes,
Back in Jan, i started the car but it soon stopped about 100m later. Called the AA, and basically came to the conclusion that the fuel lift pump in the tank isn't priming.
Replaced the pump but nothing, checked all the fuses and all good. Same for the 109 relay. My brother plugged in diagnostics and cleared some fault codes and it started up and ran for 3-5 minutes. After that it hasn't started again. Dropped it in to a friend who works with seat and he had a look. Came to the conclusion that the ECU isn't communicating to the abs unit. Brought a second hand working abs module, plugged that in and still diagnosing as no connection to abs module.
Last diagnostics scan returned this (yes its the lite version, i'll get a full version scan for tomorrow):
VCDS-Lite Version: Release 1.2
Tuesday, 13 June 2017, 20:33:33.
Chassis Type: 9N - VW Polo
Scan: 01,02,03,08,09,15,17,19,25,37,44,45,46,56,76
Address 01: Engine Labels: 038-906-019-AXR.LBL
Controller: 038 906 019 ND
Component: 1,9l R4 EDC G000SG 6118
Coding: 00002
Shop #: WSC 00788
VCID: 66BF359B117F
WVWZZZ9NZ5Y054212 VWZ7Z0D9927124
3 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 35-00 - -
18057 - Shareware Version. To Decode all DTCs
P1649 - 35-00 - Please Register/Activate
18263 - Shareware Version. To Decode all DTCs
P1855 - 35-10 - Please Register/Activate - Intermittent
Readiness: N/A
Address 08: Auto HVAC Labels: 6Q0-820-045.LBL
Controller: 6Q0 820 045
Component: Klimaanlage X0840
VCID: EAA7C1AB8567
4 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-00 - Open or Short to Plus
00819 - Shareware Version. To Decode all DTCs
07-00 - Please Register/Activate
00705 - Shareware Version. To Decode all DTCs
31-00 - Please Register/Activate
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
Any ideas?
alexperkins
Site Admin
Re: 1.9tdi abs problems - no start.
Post by alexperkins »
A fault in the ABS controller wont cause it to fail to start. Not quite sure how your mate managed to come to that conclusion
Is it cranking but just not starting?
Have you had the compression tested?
Have you had the injectors removed to see if fuel is actually coming down the lines?
Is there damage to the wiring loom? Presume you have checked all fuses with a multimeter and also the battery side fuses?
