I've installed reverse camera in the logo and everything is working perfect.
Problem is the drain pipe. The included one is approx 12 cm long and way to short if I've should use one of the original holes in the rear lid.
Does anyone know where I can find a pipe around 30 cm long?
Reverse Camera in logo - drain pipe
Re: Reverse Camera in logo - drain pipe
Its just a piece of flexible pipe isnt it from memory?
Yes but I've can't find one that's 30+ cm long on eBay...
Measure the outer and inner diameters and just pick a length up either on eBay, from halfords (washer hose) or your local aquatics store.
4StringBass
- Drives: 2017 Polo GTi
B&Q sell different diameter tubing on reels. You just cut the length you need and pay for it
Not everyone are from UK4StringBass wrote:B&Q sell different diameter tubing on reels. You just cut the length you need and pay for it
Perhaps you could complete the 'Location' details in your profile, so other forum members wouldn't assume you're in the UK.diskoboy wrote: Sat Jul 08, 2017 3:56 pmNot everyone are from UK4StringBass wrote:B&Q sell different diameter tubing on reels. You just cut the length you need and pay for it![]()
Don't know what diameter tubing you want but there's loads of choices on eBay - all different diameter options;
https://www.ebay.co.uk/sch/i.html?_from ... sacat=8444
Edit; the first seller in the above link to eBay will send items to Europe, so assuming you are in Europe, they will hopefully have what you need and be able to send it to you.
Exactly, help us help you?
