TPMS error
Kaalund
Drives: Polo 6C 2017 Comfortline
TPMS error
Post by Kaalund »
Hi guys
New to this forum, just got my Polo 6C 2017 and my buddy wanted to code some things in 17 instrument cluster. I think he did it in adaption.
Somehow he made a mistake and now the TPMS light is flashing in the cluster. I have tried to set it in the Car Setup but it doesn't work.
I have a theory that it has been reset somehow so the coding is lost, any help?
FYI he used OBDEleven and I have a backup but you cannot restore a backup in OBDEleven.
Re: TPMS error
Compare backup to current coding and adapt accordingly
Kaalund
Re: TPMS error
Post by Kaalund »
iichel wrote:Compare backup to current coding and adapt accordingly
Hi
I already reverted from the backup settings, but that didn't change the error unfortunately.
Re: TPMS error
What is the current error in the abs module?
Kaalund
Re: TPMS error
Post by Kaalund »
iichel wrote:What is the current error in the abs module?
Hi
No errors in abs according to scan
joe6
Drives: Golf Mk6 GTI (Scirocco gone) Polo 6c GTI
Re: TPMS error
Post by joe6 »
Kaalund wrote: Tue Jul 18, 2017 12:59 pm
Hi
You may be able to fix it if you have access to VCDS and the original coding settings.
Kaalund
Re: TPMS error
Post by Kaalund »
Hi
Hi
Is it impossible with OBDEleven?
joe6
Re: TPMS error
Post by joe6 »
Should be possible with OBDeleven. VCDS has more features if OBDeleven does not work.
