Polo 6R 2016 Mod.
Re: Polo 6R 2016 Mod.
I'm afraid not.
Look here, on a Golf VII. This way you already know what is necessary.
Btw, your wiring looms is already made. I will inform you by email. (I still have to do the installation guide)
- Drives: Polo GT 1.2TSI DSG 6R 2016
Ya I know these parts of PLA2.0 , i have retro fitted my Superb & Yeti and PLA 2.0 works just fine.ciclo wrote:I'm afraid not.
But I was wondering if any one has tried with the CAN lines of 7E0 BCM in 6R. I m sure it will work in 6C cause of seperate CAN.
I think the first thing to investigate is if the other units involved in this system can manage this function in your 6R. I think not, but since these units have been changing over the years I can not say that it is not possible. (I haven't done any thorough research, I don't have time as you already know )
In the tutorial for Golf VII (XaGiCo) you can clearly see all the units that need to be coded.
Hmm ... if I had a Golf VII already I would have done it. (with this guide )
How to install 7E0937090B BCM Max in 2016 Polo 6R RHD non Bluemotion. Halogen headlights. (rdasadia)
Preview. 13 pages
View or download here
Preview. 13 pages
- Drives: Polo 6R
Will led headlamps work with the bcm 6RU 937 087M?
Do we need to change the wiring ?
Which function of led headlamps may not support to stock BCM?
No the LEDs will not work.
- Drives: Polo 6R
BCM must be changed. For AFS there is another thread.
Ok!! So over the weekend I have completed the installation of Ciclo's harness exactly as per instructions. The instrucions were beautifully described by Ciclo in the installation guideciclo wrote: ↑Sat Apr 29, 2017 8:33 pm How to install 7E0937090B BCM Max in 2016 Polo 6R RHD non Bluemotion. Halogen headlights. (rdasadia)
Preview. 13 pages
[youtube]https://www.youtube*.com/watch?v=9ExrrmbJ82c[/youtube]
Below is the scan report. Now few queries and trouble shooting.
1) My DRLs are not working !! Right now the DRLs are working more like parking lights only when the low beam switches on. Once again I will remind you that my front lights are after market Chinese ones with 10 pin connector. How do I solve this issue?
2) My interior lights (lights in the window switches, dash board buttons, light switch, mirror adjustment knob) are not working. Is it a coding issue or blown fuse problem?
3) "Coming home" function is not working. However "Leaving Home" function working perfectly.
4) I have yet not ordered the dimming light switch and hence one of the error in the BCM
5) There is an error in HVAC.
VCDS Version: 17.7.0.4 (x64) HEX-NET CB: 0.4401.4
Data version: 20170721 DS276.1
www.Ross-Tech.com
VIN: MEXA16604GT072590 License Plate:
Mileage: 11960km-7431mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 65 0B
VIN: MEXA16604GT072590 Mileage: 11960km-7431miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: 00000000000000
Coding: 00250056232400080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
VCID: 6D9229D8BC778B2EF0-8038
Readiness: 0110 0101
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6501
Revision: 00043014 Serial number: CU501511017434
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 3A38D28475B9EC9625-806E
Part No SW: 6R0 907 379 BH HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422A03C2461924724251C0800908
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0542717884C7536E18-8050
Serial number: 05061504651234
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X_VW25.rod
VCID: 7EB01E94E11100B659-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41CAA568D86FBF4E64-8014
1 Fault Found:
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 11965 km
Time Indication: 0
Date: 2017.07.30
Time: 00:10:43
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 352161294
Coding: 3AB02BBF48B30000013806917CEB9E905AC0676F600D3041200000030000
Shop #: WSC 51200 002 104857
VCID: 2A18E2C445195C1655-807E
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 271115 03 37 0059
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 020 2551
Serial number: 13102848151112221545
Coding: 030008
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 020 2551
Serial number: 13202849151112235703
Coding: 050008
Subsystem 4 - Part No SW: 13 202 849 15 HW: 132 028 491 51
Component: RLS 271115 03 37 1122
Serial number: ÿ132028491511122357
Coding: 353730
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 019 1552
Serial number: 13202728151109234823
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 019 1552
Serial number: 13202729151110091329
Coding: 020000
6 Faults Found:
03428 - Activation of Left Adaptive Light
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 85
Mileage: 11965 km
Time Indication: 0
Date: 2017.07.30
Time: 00:11:50
03429 - Activation of Right Adaptive Light
006 - Short to Plus - Intermittent
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 85
Mileage: 11965 km
Time Indication: 0
Date: 2017.07.30
Time: 00:12:31
00901 - Back-Up Lamps
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Mileage: 11965 km
Time Indication: 0
Date: 2017.07.30
Time: 00:10:10
02745 - Bulb for Daytime Running Light; Left
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Mileage: 11965 km
Time Indication: 0
Date: 2017.07.30
Time: 00:10:09
02746 - Bulb for Daytime Running Light; Right
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Mileage: 11965 km
Time Indication: 0
Date: 2017.07.30
Time: 00:10:09
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Mileage: 11965 km
Time Indication: 0
Date: 2017.07.30
Time: 00:10:09
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 J HW: 7N0 919 475
Component: PARKHILFE 8K H06 0105
Revision: -------- Serial number: 28261224902578
Coding: 300101
Shop #: WSC 02756 790 50316
ROD: EV_EPHVA18VW250GPCS.rod
VCID: 393ACD88B8BFE78E2C-806C
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW012EG31
Coding: 003036
VCID: 49DABD48E85F770EBC-801C
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 141C01
Shop #: WSC 12345 123 12345
VCID: 47DEBB70FE4B817EAA-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002300
VCID: 689C58CC9B95AE0683-803C
Component: IMMO H05 0805
VCID: 6A9822C48D999C1695-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014_VW12.rod
VCID: 41CAA568D06FBF4E64-8014
Address 56: Radio (J503) Labels: None
Part No SW: 6RF 035 187 HW: 6RF 035 187
Component: Radio 013 0116
Revision: -------- Serial number: VWZGZ1R3521196
Coding: 0000044000000F
VCID: 06407674B1C1587611-8052
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 30000000054715
ROD: EV_RDKBERU30.rod
VCID: 373ECBB08EABF1FEDA-8062
End----------(Elapsed Time: 01:34, VBatt start/end: 13.3V/13.4V)-----------
1 --> I don't know since the OEM wiring is not made for aftermarket headlights. maybe check with the
2 , 4 and 5 are related. did you make a new cable between the dimmer and the BCM (T73b/4 and T6aa/3 iirc)? then it will be resolved after the dimmer is fit
3 --> did you pull high beam shortly, before opening the door after switching ignition off and removing key?
concerning the adaptive lights, do you have static cornering lights in the foglights?
it will work?... .... hmm ...
rdasadia, the next thing you are going to read is in funny way, not personal, or similar ... ( myself should apply me this same story for many things I do)
Please install the appropriate parts:
1- The most urgent thing is the dimmer, your current dimmer does not have the necessary pin-terminal (T6/3). (read instructions guide )
2- Do what you said you were going to do, install the Binexon headlights and dismantle those monstrous headlamps.
The BCM coding is done based on what you said you were going to do.
Everything will work perfectly when you do what you said you were going to do.
My wiring, my coding and my instructions are correct (perfect) according to what you said you were going to do, ...remember that I insisted on this many times, here in the forum, by email, etc...
(I had the impression that you did not pay enough attention )
For example, you would know that the Coming Home function is semiautomatic if you put enough attention and read the instructions (including links)...
Separate theme:
TPMS direct for your Skoda Yeti. (suggestions and questions)
Maybe you should disable Byte17 Bit2? ... in addition to Byte16 Bit2...
e.g
Does the BCM have the correct coding for direct TPMS?
e.g
(Note that this BCM (above image) is from a Golf/Jetta, I do not know if the Bits descriptions are the same)
Separate theme:
Wednesday,26,April,2017,21:44:35:58997
VCDS Version: 17.1.3.0 (x64) HEX-NET CB: 0.4336.4
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: TMBKCL5L8BA7 License Plate: 359
Mileage: 59730km-37114mi Repair Order:
Chassis Type: 5L (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 4C 52 55 56 62 65 72
77
VIN: TMBKCL5L8BA7 Mileage: 59730km-37114miles
16-Steering wheel -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CLCA) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 NH HW: 03L 906 018 BR
Component: R4 2,0L EDC H25 3773
Revision: 42H25--- Serial number:
Coding: 00110012040500080000
Shop #: WSC 23000 663 88866
ASAM Dataset: EV_ECM20TDI01103L906018NH 003003
ROD: EV_ECM20TDI01103L906018NH.rod
VCID: 7DB21998EC171BA982-8028
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 933F200E092205FCC90E04ED901AA08A310DF0
Shop #: WSC 59639 002 104857
VCID: 7BB61780FA031599BC-802E
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3T0 820 047 AK HW: 3T0 820 047 AK
Component: AC Manuell H20 0709
Revision: 00001016
Coding: 0010001002
Shop #: WSC 30419 002 1048576
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_SK35.rod
VCID: 78BC088CC3353E81D1-802C
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 R HW: 1K0 937 087 R
Component: BCM PQ35 H+ 110 0651
Revision: 00110 AC
Coding: 06190AB8E03308C0004A0080310089C007F51DAE536DC160640C40040040
VCID: 40CCA06CD365B641A9-8014
Subsystem 1 - Part No: 5L2 955 119 A Labels: 1KX-955-119.CLB
Component: SK356 26 0604
Coding: 00F7B5
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 031011 05 54 0403
Coding: 072B21
5 Faults Found:
00984 - Left Tail Light (M4)
014 - Defective
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 28
Reset counter: 92
Mileage: 59621 km
Time Indication: 0
Date: 2017.04.23
Time: 19:03:40
Term 15 Off
Voltage: 12.30 V
OFF
ON
Term 50 Off
OFF
OFF
00985 - Right Tail Light (M2)
014 - Defective
Fault Priority: 2
Fault Frequency: 28
Reset counter: 92
Mileage: 59621 km
Time Indication: 0
Date: 2017.04.23
Time: 19:03:40
Term 15 Off
Voltage: 12.30 V
OFF
ON
Term 50 Off
OFF
OFF
00987 - Lamp for Brake Light; Left (M9)
Fault Priority: 1
Fault Frequency: 40
Reset counter: 92
Mileage: 59621 km
Time Indication: 0
Date: 2017.04.23
Time: 19:05:45
Term 15 On
Voltage: 13.65 V
ON
ON
Term 50 Off
OFF
OFF
00988 - Lamp for Brake Light; Right (M10)
Fault Priority: 1
Fault Frequency: 38
Reset counter: 92
Mileage: 59621 km
Time Indication: 0
Date: 2017.04.23
Time: 19:05:47
Term 15 On
Voltage: 13.65 V
ON
ON
Term 50 Off
OFF
OFF
02661 - Wire for Speed Signal
Fault Priority: 4
Fault Frequency: 1
Reset counter: 88
Mileage: 59621 km
Time Indication: 0
Date: 2017.04.23
Time: 19:06:17
Term 15 On
Voltage: 13.75 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.clb
Part No SW: 3AA 919 475 M HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0030
Revision: -------- Serial number: 56261220200568
Coding: 141001
Shop #: WSC 12345 123 123456
ASAM Dataset: EV_EPHVA2C000000000 002011
ROD: EV_EPHVA2C000000000_VW41.rod
VCID: 45C2B178C44793699A-8010
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6RA4MB6J
Coding: 00005442
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3228FAA465C914D12F-8066
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 AT HW: 5K0 953 569 H
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20120808201549
Coding: 1082140002
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWSXS.rod
VCID: 7CB4149CF70D12A1B5-8028
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 820000
Part No SW: 5L0 920 840 H HW: 5L0 920 840 HX
Component: KOMBI H21 0422
Coding: 120E01
Shop #: WSC 11111 222 11223
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
VCID: 302CF0AC6BC526C159-8064
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN
Component: J533 Gateway H56 1642
Revision: H56 Serial number: 261113F1003554
Coding: 356303
VCID: 7CB4149CFF0D12A1B5-8028
Component: IMMO H21 0422
VCID: 6A9822C48D999C1157-803E
Address 42: Door Elect, Driver (J386) Labels: 7N0-959-793.clb
Part No SW: 7N0 959 793 G HW: 7N0 959 793 G
Component: TSG FA H03 0553
Revision: Serial number: 0000128461195
Coding: 011402208001231004
VCID: 46C0B674F141987193-8012
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
Shop #: WSC 73430 790 00074
VCID: 3424FCBC57DD1AE13D-8060
Address 52: Door Elect, Pass. (J387) Labels: 7N0-959-792.clb
Part No SW: 7N0 959 792 D HW: 7N0 959 792
Component: TSG BF H04 0400
Revision: Serial number: 0000120223903
Coding: 01140020D001231003
Shop #: WSC 73430 790 00999
VCID: 42C8AA64DD69A451BF-8016
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 3671067
Subsystem 1 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0008
Coding: 00000056
Subsystem 2 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0008
Coding: 00000056
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3T0 035 156 B HW: 3T0 035 156 B
Component: BOLERO 008 0054
Revision: 0A001001 Serial number: SKZ1Z3K0524841
Coding: 090004000003
Shop #: WSC 96034 793 698508
VCID: 2D12E9D874F74B2972-8078
Address 62: Door, Rear Left (J388) Labels: 7N0-959-795.clb
Part No SW: 7N0 959 795 D HW: 7N0 959 795
Component: TSG HL H03 0400
Revision: Serial number: 0000119425685
Coding: 010000200001531004
VCID: 45C2B178CC4793699A-8010
Serial number: 30000000054012
ROD: EV_RDKBERU30_VW51.rod
VCID: 373ECBB08EABF1F918-8062
Address 72: Door, Rear Right (J389) Labels: 7N0-959-795.clb
Component: TSG HR H03 0400
Revision: Serial number: 0000119427849
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:15, VBatt start/end: 13.7V/0.0V)------------
e.g
e.g
ciclo wrote: ↑Mon Jul 31, 2017 12:01 pm it will work?... .... hmm ...
Separate theme:
Maybe you should disable Byte17 Bit2? ... in addition to Byte16 Bit2...Code: Select all
Wednesday,26,April,2017,21:44:35:58997 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 17.1.3.0 (x64) HEX-NET CB: 0.4336.4 Data version: 20170320 DS267.7 www.Ross-Tech.com VIN: TMBKCL5L8BA7 License Plate: 359 Mileage: 59730km-37114mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 5L (7N0) Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 4C 52 55 56 62 65 72 77 VIN: TMBKCL5L8BA7 Mileage: 59730km-37114miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 4C-Tire Pressure II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CLCA) Labels: 03L-906-018-CFF.clb Part No SW: 03L 906 018 NH HW: 03L 906 018 BR Component: R4 2,0L EDC H25 3773 Revision: 42H25--- Serial number: Coding: 00110012040500080000 Shop #: WSC 23000 663 88866 ASAM Dataset: EV_ECM20TDI01103L906018NH 003003 ROD: EV_ECM20TDI01103L906018NH.rod VCID: 7DB21998EC171BA982-8028 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ Component: ESP MK60EC1 H31 0121 Revision: 00H31001 Coding: 933F200E092205FCC90E04ED901AA08A310DF0 Shop #: WSC 59639 002 104857 VCID: 7BB61780FA031599BC-802E No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb Part No SW: 3T0 820 047 AK HW: 3T0 820 047 AK Component: AC Manuell H20 0709 Revision: 00001016 Coding: 0010001002 Shop #: WSC 30419 002 1048576 ASAM Dataset: EV_ACManueBHBVW36X A01010 ROD: EV_ACManueBHBVW36X_SK35.rod VCID: 78BC088CC3353E81D1-802C No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 1K0 937 087 R HW: 1K0 937 087 R Component: BCM PQ35 H+ 110 0651 Revision: 00110 AC Coding: 06190AB8E03308C0004A0080310089C007F51DAE536DC160640C40040040 Shop #: WSC 59639 002 104857 VCID: 40CCA06CD365B641A9-8014 Subsystem 1 - Part No: 5L2 955 119 A Labels: 1KX-955-119.CLB Component: SK356 26 0604 Coding: 00F7B5 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 031011 05 54 0403 Coding: 072B21 5 Faults Found: 00984 - Left Tail Light (M4) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 2 Fault Frequency: 28 Reset counter: 92 Mileage: 59621 km Time Indication: 0 Date: 2017.04.23 Time: 19:03:40 Freeze Frame: Term 15 Off Voltage: 12.30 V OFF ON Term 50 Off OFF OFF 00985 - Right Tail Light (M2) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 2 Fault Frequency: 28 Reset counter: 92 Mileage: 59621 km Time Indication: 0 Date: 2017.04.23 Time: 19:03:40 Freeze Frame: Term 15 Off Voltage: 12.30 V OFF ON Term 50 Off OFF OFF 00987 - Lamp for Brake Light; Left (M9) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 1 Fault Frequency: 40 Reset counter: 92 Mileage: 59621 km Time Indication: 0 Date: 2017.04.23 Time: 19:05:45 Freeze Frame: Term 15 On Voltage: 13.65 V ON ON Term 50 Off OFF OFF 00988 - Lamp for Brake Light; Right (M10) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 1 Fault Frequency: 38 Reset counter: 92 Mileage: 59621 km Time Indication: 0 Date: 2017.04.23 Time: 19:05:47 Freeze Frame: Term 15 On Voltage: 13.65 V ON ON Term 50 Off OFF OFF 02661 - Wire for Speed Signal 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 4 Fault Frequency: 1 Reset counter: 88 Mileage: 59621 km Time Indication: 0 Date: 2017.04.23 Time: 19:06:17 Freeze Frame: Term 15 On Voltage: 13.75 V ON ON Term 50 Off OFF OFF ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.clb Part No SW: 3AA 919 475 M HW: 4H0 919 475 E Component: PARKHILFE PLA H06 0030 Revision: -------- Serial number: 56261220200568 Coding: 141001 Shop #: WSC 12345 123 123456 ASAM Dataset: EV_EPHVA2C000000000 002011 ROD: EV_EPHVA2C000000000_VW41.rod VCID: 45C2B178C44793699A-8010 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 5K0-959-655.clb Part No SW: 5C0 959 655 C HW: 5C0 959 655 C Component: AirbagVW10 013 0613 Serial number: 003G6RA4MB6J Coding: 00005442 Shop #: WSC 33361 790 00999 ASAM Dataset: EV_AirbaVW10SMEVW360 A01014 ROD: EV_AirbaVW10SMEVW360.rod VCID: 3228FAA465C914D12F-8066 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb Part No SW: 5K0 953 501 AT HW: 5K0 953 569 H Component: LENKS.MODUL 014 0140 Revision: FF010041 Serial number: 20120808201549 Coding: 1082140002 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_SMLSNGVOLWS A01004 ROD: EV_SMLSNGVOLWSXS.rod VCID: 7CB4149CF70D12A1B5-8028 Multifunction steering wheel control module: Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB Component: E221__MFL-URO H07 0012 Coding: 820000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 5L0 920 840 H HW: 5L0 920 840 HX Component: KOMBI H21 0422 Serial number: 00000000000000 Coding: 120E01 Shop #: WSC 11111 222 11223 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089 ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod VCID: 302CF0AC6BC526C159-8064 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN Component: J533 Gateway H56 1642 Revision: H56 Serial number: 261113F1003554 Coding: 356303 Shop #: WSC 59639 002 104857 VCID: 7CB4149CFF0D12A1B5-8028 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H21 0422 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: 6A9822C48D999C1157-803E No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 7N0-959-793.clb Part No SW: 7N0 959 793 G HW: 7N0 959 793 G Component: TSG FA H03 0553 Revision: Serial number: 0000128461195 Coding: 011402208001231004 Shop #: WSC 30419 002 1048576 VCID: 46C0B674F141987193-8012 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 M Component: EPS_ZFLS Kl. 69 3201 Revision: 00H20000 Shop #: WSC 73430 790 00074 VCID: 3424FCBC57DD1AE13D-8060 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 7N0-959-792.clb Part No SW: 7N0 959 792 D HW: 7N0 959 792 Component: TSG BF H04 0400 Revision: Serial number: 0000120223903 Coding: 01140020D001231003 Shop #: WSC 73430 790 00999 VCID: 42C8AA64DD69A451BF-8016 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl Part No SW: 5M0 907 357 C HW: 5M0 907 357 C Component: AFS-Steuergeraet 0142 Revision: 00H04000 Serial number: Coding: 3671067 Shop #: WSC 11111 222 11223 VCID: 3424FCBC57DD1AE13D-8060 Subsystem 1 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul l 0008 Coding: 00000056 Subsystem 2 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul r 0008 Coding: 00000056 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb Part No SW: 3T0 035 156 B HW: 3T0 035 156 B Component: BOLERO 008 0054 Revision: 0A001001 Serial number: SKZ1Z3K0524841 Coding: 090004000003 Shop #: WSC 96034 793 698508 VCID: 2D12E9D874F74B2972-8078 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 7N0-959-795.clb Part No SW: 7N0 959 795 D HW: 7N0 959 795 Component: TSG HL H03 0400 Revision: Serial number: 0000119425685 Coding: 010000200001531004 Shop #: WSC 73430 790 00999 VCID: 45C2B178CC4793699A-8010 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb Part No SW: 3AA 907 273 F HW: 5Q0 907 273 Component: RDKBERU30 H04 0011 Serial number: 30000000054012 ASAM Dataset: EV_RDKBERU30 005005 ROD: EV_RDKBERU30_VW51.rod VCID: 373ECBB08EABF1F918-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 7N0-959-795.clb Part No SW: 7N0 959 795 D HW: 7N0 959 795 Component: TSG HR H03 0400 Revision: Serial number: 0000119427849 Coding: 010000200001531004 Shop #: WSC 73430 790 00999 VCID: 45C2B178CC4793699A-8010 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End----------(Elapsed Time: 01:15, VBatt start/end: 13.7V/0.0V)------------
e.g
e.g
I agree absolutely your instruction , harness and coding is perfect. Ofcourse I will be installing the dimmer switch and have already ordered the original bi xenon front lights.
I also agree sometimes I don read all instructions completely. Impatient that I am Please tell why is "coming home" function semi automatic?
Well, as far as I know the BCM PQ25 is not ready for the automatic Coming Home function. On pq25 platform this feature is not dependent on the light sensor (such as the leaving home function), depends (among others) on the door signals, and needs the driver action (pull from stalk).
Hmm... imagine that you park at night in a lit area (with streetlights), the illumination power from streetlights is not enough to prevent that works the Coming Home function in case it was automatic (through the light sensor), if it was automatic your lights would be working unnecessarily...
... not in all cases...
or
If you have to pull from stalk, you decide if you need this function...
On other VW models it is possible to code as automatic, but for the pq25 platform we need a genius (with lamp ) to figure out how to make this function automatic (e.g, when removing the key from the ignition switch).
or
Hi Ciclo!! Checked all coding as above , ABS & BCM both of correct coding as suggested by you. Any more ideasciclo wrote: ↑Mon Jul 31, 2017 12:01 pm it will work?... .... hmm ...
Separate theme:
e.g
e.g
Not for the moment, now I do not have all the information within my reach ...
As for your Polo, thank you very much for all the information you provided me by email, it is of great value to me ...
Please, can you do a test on your 6R?, with VCDS uncheck Byte2 Bit1 from your instrument cluster and tell me if the direct TPMS is still working without vcds faults.
If you need a new BCM coding for your 6R tell me what lights and wires (all) you currently have installed, please one by one (better by email), It will be a provisional coding until you install the dimmer and Bixenon headlights.
