Upgrading BCM (body control module) in my polo 6r
Vinayak185
- Drives: 6R Polo GT 1.6 TDI
Hello all, i have bought a new BCM part number 7H0 937 090 D. After installing this I'm getting fault codes and unable to adapt my keyfob to new BCM. Pls help guys.
Here is the log of autoscan
Monday,31,July,2017,15:21:45:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWC14608ET069582 License Plate: 5974
Mileage: 53225 Repair Order:
Chassis Type: 60 (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
Address 01: Engine (J623-CLNA) Labels: None
Part No SW: 03L 906 023 NT HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9971
Revision: --H33--- Serial number: 00000000000000
Coding: 00110016030500080000
Shop #: WSC 36792 002 104857
ASAM Dataset: EV_ECM16TDI02103L906023NT 003012
ROD: N/A
VCID: 8501F79F04D47D36275-80D0
No ASAM data for: "EV_ECM16TDI02103L906023NT" (VN75)
2 Faults Found:
7278 - ROD - Unknown Error Code
- 00 [037]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 61853 km
Date: 2000.00.00
Time: 00:00:00
7279 - ROD - Unknown Error Code
- 00 [037]
Fault Priority: 6
Fault Frequency: 1
Mileage: 61853 km
Date: 2000.00.00
Time: 00:00:00
Readiness: 1000 1000
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 BF HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0001
Serial number: --------------
Coding: 60DD2763412918C90619E471825318020000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 8305E9870AE04306091-80D6
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 408FA68BD376181ED43-8015
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
013 - Check DTC Memory
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H78 0725
Revision: B9078001 Serial number: 9000 238150833
Coding: 3AB82BB808A10000003800002C2B04900000414F60040000200000000000
Shop #: WSC 12345 123 12345
VCID: 2F6DF5377EE897663D9-807A
Subsystem 1 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5550
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Coding: 010000
Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Coding: 240000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Coding: 020000
4 Faults Found:
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
03432 - Activation of Right Parking Light
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
01516 - Terminal 30; Left
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
00927 - Terminal 30 (Right)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00PX2AZ
Coding: 003036
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4999BBAFE84CD95603D-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 150E00
Shop #: WSC 11802 938 12345
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 479DBD97FE582F26159-8012
1 Fault Found:
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-19.lbl
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H78 0725
Revision: B9078001
Coding: 002300
VCID: F0EFB64B2356489EE43-80A5
1 Fault Found:
00381 - Databus Instrument Cluster
Fault Priority: 1
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Component: IMMO H04 0805
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EADBA4230D8AB24EAA7-80BF
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-44.clb
Part No SW: 6RF 909 144 K HW: 6RF 909 144 J
Component: EPS_ECU H44 0401
Coding: 0000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK.rod
VCID: 54A79ADB3F0E94BE60B-8001
Address 56: Radio (J503) Labels: None
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 09475GD0078320
Coding: 0000040004000A
Shop #: WSC 00081 790 00133
VCID: 4581B79FCC543D36E75-8010
6 Faults Found:
00625 - Vehicle Speed Signal
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 52907 km
Time Indication: 0
Date: 2007.14.11
Time: 05:39:04
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 52907 km
Time Indication: 0
Date: 2007.14.11
Time: 05:39:04
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 94
Mileage: 52925 km
Time Indication: 0
Date: 2007.14.13
Time: 08:39:24
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 94
Mileage: 52925 km
Time Indication: 0
Date: 2007.14.13
Time: 08:39:24
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 94
Mileage: 52925 km
Time Indication: 0
Date: 2007.14.13
Time: 08:39:24
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 94
Mileage: 52925 km
Time Indication: 0
Date: 2007.14.13
Time: 08:39:24
End ---------------------------------------------------------------------
ROD: N/A
2 Faults Found:
- 00 [037]
Fault Priority: 6
Fault Frequency: 1
Mileage: 61853 km
Date: 2000.00.00
Time: 00:00:00
- 00 [037]
Fault Priority: 6
Fault Frequency: 1
Mileage: 61853 km
Date: 2000.00.00
Time: 00:00:00
Revision: V0000000
2 Faults Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Coding: 010000
Coding: 010000
Coding: 240000
Coding: 020000
Coding: 020000
4 Faults Found:
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Coding: 003036
Coding: 150E00
1 Fault Found:
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Revision: B9078001
Coding: 002300
1 Fault Found:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Coding: 0000
6 Faults Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 52907 km
Time Indication: 0
Date: 2007.14.11
Time: 05:39:04
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 52907 km
Time Indication: 0
Date: 2007.14.11
Time: 05:39:04
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 94
Mileage: 52925 km
Time Indication: 0
Date: 2007.14.13
Time: 08:39:24
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 94
Mileage: 52925 km
Time Indication: 0
Date: 2007.14.13
Time: 08:39:24
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 94
Mileage: 52925 km
Time Indication: 0
Date: 2007.14.13
Time: 08:39:24
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 94
Mileage: 52925 km
Time Indication: 0
Date: 2007.14.13
Time: 08:39:24
Re: Upgrading BCM (body control module) in my polo 6r
Please tell us what you did to the wiring.
It also seems you're using a bit of an outdated version of VCDS (12.12, we are at 17.1 with the latest version). That in itself is no problem. But it might limit your possiblities and DTC database a bit.
Anyways, it would be good if you tell us what you did to the wiring, so we can have a look at what might have gone wrong.
Remote matching: http://wiki.ross-tech.com/wiki/index.ph ... Adaptation
This doesn't work?
This doesn't work?
Read here
viewtopic.php?f=62&t=69223#p516196
'B'
Maybe, it is possible that by reading the point B (all links) you can solve your problems by yourself.
***The first thing*** you have to do is to install new communication lines (CAN) between the instrument cluster and the new BCM. (pair of wires)
https://drive.google.com/file/d/0B2nv91 ... sp=sharing
It is possible to install the BCM 7H0937090D in your Polo, but I would recommend installing a more updated one.
You have to do something like this. It depends ... automatic lights or not.
'B'
Vinayak185
Hello thnx ciclo sir. i did wiring as u mentioned and everything is working fine except two things. These fault codes are still coming in autoscan.ciclo wrote: Mon Jul 31, 2017 7:32 pm Read hereviewtopic.php?f=62&t=69223#p516196
'B'
pls help me in this. Thnx again
4 Faults Found:
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Vinayak185
hie. problems are solved by wiring as ciclo sir mentioned. but the 4 fault codes are not going. thnx for ur replyiichel wrote: Mon Jul 31, 2017 7:19 pm Please tell us what you did to the wiring.
This doesn't work?
Check with these people, they had the same 4 DTCs:
viewtopic.php?f=56&t=69746
viewtopic.php?f=56&t=69687
Did you solve the four faults?Vinayak185 wrote: Sun Aug 06, 2017 11:28 am Hello thnx ciclo sir. i did wiring as u mentioned and everything is working fine except two things. These fault codes are still coming in autoscan.
antardaksh04
- Drives: TSI
Hi iichel ,iichel wrote: Sun Aug 06, 2017 11:34 am Check with these people, they had the same 4 DTCs:
These errors in VCDS are because I have installed BCM Max but have not completed wiring. I have already got wiring from Ciclo which I need to install.
Regards.
Perfect I have no doubts that this will complete your installation.
Vinayak185
Hello. Not yet. These fault codes are still coming. I haven't done rls installation and auto headlights wiring. I need solution on it. Pls help. Thnx
Vinayak185
No, I couldn't solve those faults. They are still appearing in autoscan. I haven't done rls installation and auto headlights wiring. I have auto headlight switch with independent sensor. Pls help me in this. Thnxciclo wrote: Thu Aug 17, 2017 7:34 amDid you solve the four faults?Vinayak185 wrote: Sun Aug 06, 2017 11:28 am Hello thnx ciclo sir. i did wiring as u mentioned and everything is working fine except two things. These fault codes are still coming in autoscan.
You must install the adaptation wiring for BCM Max.Vinayak185 wrote: Sat Aug 19, 2017 12:07 pmNo, I couldn't solve those faults. They are still appearing in autoscan. I haven't done rls installation and auto headlights wiring. I have auto headlight switch with independent sensor. Pls help me in this. Thnxciclo wrote: Thu Aug 17, 2017 7:34 amDid you solve the four faults?Vinayak185 wrote: Sun Aug 06, 2017 11:28 am Hello thnx ciclo sir. i did wiring as u mentioned and everything is working fine except two things. These fault codes are still coming in autoscan.
viewtopic.php?p=523860#p523234
For example, none of the following adaptation wiring is related to faults in your BCM.
Wiring for light sensor.
Wiring for automatic lights.
Wiring for Bixenon headlights.
Wiring for AFS. (automatic leveling system for Bixenon)
Before you do anything, show us the images required to guide you in the right direction.
antardaksh04
- Drives: TSI
Hi Vinayak185 ,Vinayak185 wrote: Sat Aug 19, 2017 12:07 pm No, I couldn't solve those faults. They are still appearing in autoscan. I haven't done rls installation and auto headlights wiring. I have auto headlight switch with independent sensor. Pls help me in this. Thnx
I believe you have only connected 2 wires from BCM to CAN line. This will let you run your car with BCM max and all the lights will function but you will get error in VCDS. Also lights will not be controlled by BCM.
I enable all functions such as auto headlight/ rain sensing wipers you need to complete all wiring.
The auto headlight switch mentioned by you is an independent unit. It has its own sensor and does not work through BCM.
Regards.
Vinayak185
Hi antardaksh. Yes Ur right. I need to complete all the wiring to remove those faults. Car is running fine with BCM max. Right now I want to install cruise control in my polo. So, I'm searching for cruise control stalks.
Vinayak185
Yes, i need to install the wiring to get rid of the faults in vcds. I need cruise control stalks for my polo. im unable to get them. can u pls help me to source the original stalks?ciclo wrote: Sun Aug 20, 2017 4:38 amYou must install the adaptation wiring for BCM Max.Vinayak185 wrote: Sat Aug 19, 2017 12:07 pmNo, I couldn't solve those faults. They are still appearing in autoscan. I haven't done rls installation and auto headlights wiring. I have auto headlight switch with independent sensor. Pls help me in this. Thnx
