☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼
Re: ☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. Light Assist. ☼
Hi Pavol, welcome
Yes I still sell these wiring. According to your indications would be the wiring 'A' indicated on the first page of this topic.
I now send you a private message with my email so that you can send me the Autoscan (TXT file) to my email, this way I can make a perfect wiring for your 6R. :wink:
Easy, fast and totally safe.
Regards
Fernando
Tuli82
Drives: VW Polo 6R
Post by Tuli82 »
Hi Fernando,
autoscan is waiting for you, please check email.
Thanks. Your wiring is ready to be sent. :wink:
Eduard
Drives: 6C
Post by Eduard »
Hi Fernando!
I've seen somebody ask for a Polo 6C wiring. Any chance you've got the hang of it ? I believe 6Cs will be seen more often here.. so if you want a tester, I'm up for the job.
I opened some threads ( to no avail though ) regarding BiXenon ( with or without AFS / Autoleveling lol ).
Send me a PM so we can hang out and talk it through if you're interested, for a price, if needed, of course ( I'm unable to send PMs due the lack of activity )
Hi Eduard
Thank you for contacting me.
I do not manufacture wiring looms for the Polo 6C. I'm really sorry.
Please, open a new topic in the forum (like mine), I'm sure it will be very interesting for everyone and I guess you will receive a lot of help. :wink:
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
https://uploads.tapatalk-cdn.com/201708 ... 54e04a.jpg
My current bcm is attached in pic
I want to install Rls, Auto switch & electrochromic mirror CH LH should work
Do I need to change bcm ?
Yes
anupamp
Drives: Polo Sedan TDI
Post by anupamp »
Do you still make wiring for CH LH?
Hi anupamp.
No. I am truly sorry, I do not have time for this right now.
I would have liked to help more people with all this (especially for the friendly people of India).
Try to do it for yourself. (you can get many help in this forum)
Thank you very much for your interest on my wiring.
anupamp
Post by anupamp »
ciclo wrote:Hi anupamp.
Thank you very much for your help and support.
favi
Drives: 6R
Post by favi »
hello :)
I would like to order:
B- Wiring for BCM Max adaptation + Automatic Lights Wiring + CH/LH
I have already bought 7E0937090, AUto switch and rls :)
Hey favi :D
Ok :wink: , please I need the next info to make the specific wiring for your 6R.
Pictures from:
Relay Carrier.
Light switch connector (both sides).
Dimmer connector.
Fuse box.
New BCM.
VCDS Autoscan. Recent.
As seen in the examples on first page of this sale.
If possible some pictures from your 6R. Front and dashboard (general view).
For this you can:
- Open a new topic in 6R section and upload the info there. (recommended for future help apart from this installation, in case you need it for other installations)
- Or send me the info through email.
Look at your inbox. You will have my email to contact me.
Fernando
bbnijn1987
Drives: Polo 6r 1.2 TSI BLM
Post by bbnijn1987 »
Hi Fernando,
I would like to order an wiring loom for my Polo 6R BLM Comfort.
i'm interested in option:
A- Automatic lights wiring + CH/LH
This is my VCDS autoscan:
Sunday,04,March,2018,16:04:38:00001
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY229185   License Plate:
Mileage: 92810km-57669mi   Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56 61
VIN: WVWZZZ6RZCY229185   Mileage: 92810km-57669miles
2E-Media Player 3 -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 FJ    HW: 03F 907 309 K
   Component: SIMOS10.23AH10 5465
   Revision: --H10---    Serial number:
   Coding: 00110096202401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070FJ 004008
   VCID: 6FECEB20B69D0D3E63-803A
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 210228E3216F00BB842614EA84D600501300
   VCID: 000EB89C970302468A-8054
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 387E107C8B538A8672-806C
2 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
            000 -  -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 81608 km
                    Time Indication: 0
                    Date: 2017.08.11
                    Time: 09:18:33
01272 - Positioning Motor for Central Flap (V70)
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 204
                    Mileage: 92816 km
                    Time Indication: 0
                    Date: 2018.03.04
                    Time: 15:51:03
   Part No SW: 6R0 937 088 F    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H50 0353
   Revision: BU050001    Serial number: 0456 054121186
   Coding: 3AB02BBF08A1000021300FF06C2B0ED85FC0612F7E860049200000000000
   VCID: 41887D98D889CB4EC5-8014
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 170212 05  54  0403
   Coding: 03302D
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU001031200014514
   Coding: 58BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU021021200011501
   Coding: 58BC30
   Subsystem 4 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027021200016621
   Coding: 58BC32
   Subsystem 5 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU024021200011339
   Coding: 58BC32
1 Fault Found:
00447 - Function Limitation due to Over-Voltage
            001 - Upper Limit Exceeded - Intermittent
                    Fault Status: 00100001
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 204
                    Mileage: 91836 km
                    Time Indication: 0
                    Date: 2018.01.27
                    Time: 08:23:27
   Component: VW10Airbag022 H10 0020
   Revision: --------    Serial number: 003GX014464S
   Coding: 003232
   Shop #: WSC 01383 785 00200
   VCID: 4A9A5AB4EDBF081614-801E
   Serial number: 3575HRB406914JQM4GR+
   Serial number: 3585HRB406515IRSF94Q
   Serial number: 3515RRB405N15A9Q5OL/
   Serial number: 3525RRB404P13B6CO8IO
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 860 HX    HW: 6R0 920 860 HX
   Component: KOMBI         H03 0505
   Coding: 540A01
   Shop #: WSC 00531 211 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 11288DD8C0697BCE15-8044
Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H38 0035
   Revision:   H38       Serial number: 230212F1002585
   Coding: 2500C2
   VCID: 3466244C973B6EE65E-8060
   Component: IMMO          H03 0505
   Shop #: WSC 00000 000 00000
   VCID: 6ADAFA348D7FE81634-803E
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7662031795
   Coding: 010000
   VCID: 2958C53840F9230EFD-807C
1 Fault Found:
03138 - Input AUX IN
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 164
                    Mileage: 92816 km
                    Time Indication: 0
                    Date: 2018.03.04
                    Time: 16:00:52
   Part No: 6R0 423 156 B
   Coding: 11220
   Shop #: WSC 00788
   VCID: 2F6C2B20EA1D4D3E23-807A
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: Radio RCD310  042 0082
   Revision: 01000001    Serial number: VWZ1Z2M4065880
   Coding: 01000400020001
   VCID: 33642750923569DE47-8066
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0035
   Coding: 032B7A64
   VCID: 74E6E44CD7BB2EE69E-8020
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 00000000004970250179
End-------------------------(Elapsed Time: 02:18)--------------------------
Do i need anything else besides my RLS, already ordered auto light switch and BCM?
Cheers,
Bbnijn
Hello bbnijn1987.
Thanks for the Autoscan.
Your current BCM can manage the automatic lights (you do not need a new BCM for this purpose).
You only need the A wiring and the light switch with AUTO function.
I send you my email by private message so you can contact me.
Please check your inbox and contact me by email. Thanks.
In this way I will provide you with all the information you need. :wink:
Fernando
