Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
Re: Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
sanders, where do you live in the netherlands? maybe you can have a go with my module?
sanders
Drives: 6r bluemotion tdi 1.2
Post by sanders »
Yes I live in Enschede, but do you have a spare module?
sanders
Post by sanders »
@Adam87,
Thanks for reply, don't have VCP so not able to reflash the AFS module.
My parents live near Ommen, we could meet up when I'm around.
sanders
Post by sanders »
Changed the module, and same results. Same fault codes in can gateway and headlight range
try this coding: 0192000001000000
sanders
Post by sanders »
Did this code maken no difference.
Some ideas:
Check the wiring again (meticulously) from the rear sensor to module 55.
Unplug the sensor connector and plug it in again.
Do the basic setting again.
sanders
Post by sanders »
Thanks for the reply Ciclo, wil report back with my findings.
sanders
Post by sanders »
Checked the wiring but made no difference. Strange thing is that the gateway still comes with faultcode 01771??
Eduard
Drives: 6C
Post by Eduard »
Hello gents! Anyone here can help with some tips on where exactly does the afs wiring get inside the car from the sensor ?
Thanks!
Eduard
Drives: 6C
Post by Eduard »
Thanks buddy! iichel pmed me earlier, wires are now in place :)
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Hi. this is my brake line bracket in the area for leveling sensor. Do i need to replace this brake bracket to fit in the leveling sensor ? because i tried to fit the sensor mounting, seems like its not right.
