BlueEyesGT
Posts: 13 Joined: Sat Feb 13, 2016 5:54 pm
Drives: Polo 1.2 TSi
Post
by BlueEyesGT » Tue Aug 29, 2017 4:33 am
rdasadia wrote: Mon Aug 28, 2017 8:46 pm
2) for the headlight washer retrofit from the past posts got the below parta details which needs to be procured.
- 6R0 955 978 nozzles. ( Can someone advise where they can be procured from)
- wire harness (
https://www.kufatec.de/shop/en/Volkswag ... VW-Polo-6R )
However could not gather from where to find the pumps(does it use the same pump that of windshield washer), and the hoses and connection diagram.
Here is the 6C headlight washer retrofit in progress,this might help.
viewtopic.php?t=70119
rdasadia
Posts: 68 Joined: Mon Mar 21, 2016 7:56 pm
Drives: Polo GT 1.2TSI DSG 6R 2016
Post
by rdasadia » Tue Aug 29, 2017 5:38 am
iichel wrote: Mon Aug 28, 2017 9:14 pm
There is a thread for headlight washer retrofit somewhere (or maybe 6R bi xenon retrofit). There is a list of parts, including the washer system.
I'm not aware of any retrofit kit or topic but it shouldn't be too difficult to make a wiring set for the new roof lining.
Thanks iichel. The kit I have got has only the visors which can support vanity light. It does not have the lights or the wiring details. I need to still procure the lights for which I dont have the part no. Also I can make the wiring if only I knew the connections. I mean I am sure the vanity lights wont work via BCM. But which fuse, etc
Posts: 8834 Joined: Sun Feb 24, 2013 10:20 am
Post
by ciclo » Tue Aug 29, 2017 5:45 am
So most recently got complete GTI body kit upgrade including bumpers (front & back), side skirts, interior "black" panels, etc
However require help for below two retrofits.
1) Sun visors with vanity light
2) front bumpers are with headlight washer space.
1) For sun visors tried to search for retrofit details but couldn't find any. Would like to know part no. of the light which is fixed on the roof and wiring details of this light and connector coming out of the visors.
- wire harness (
1)
2)
https://www.google.es/search?q=6R0+955+ ... 17&bih=708
Dealer?
Ask to firegrafik, CNK...
The relay adapter shown on the wiring picture (kufatec) does not fit into your Polo 6R 2016 relays holder. Ask before you buy.
Post
by ciclo » Tue Aug 29, 2017 8:14 am
iichel wrote: Tue Aug 29, 2017 8:03 am
... firegrafik's excellent post...
+1
rdasadia
Post
by rdasadia » Mon Oct 09, 2017 7:28 pm
Getting ready to install AFS. Have already ordered all other parts. Just for the AFS module one of the IIchel's post shows the part no. as 6R0 907 357. However there are many firmware versions avaliable as below.
https://i.imgur.com/rsEAqc1.jpg
Any specific which I need to buy.
Post
by ciclo » Wed Oct 18, 2017 3:23 am
The AFS module you should buy depends on the rear leveling sensor and the bixenon headlights you have purchased. Also of other factors like the brakes system installed (ABS, ESP).
The AFS module works in conjunction with the rear leveling sensor and the headlight range control motor that is inside the bixenon headlights.
Please tell me the bixenon headlights references (including date of manufacture), also the rear leveling sensor reference (including date of manufacture).
benzinkopf
Posts: 862 Joined: Wed Apr 02, 2014 4:01 pm
Drives: 1.2TSI 105HP DSG7
Post
by benzinkopf » Fri Oct 20, 2017 4:37 am
ciclo wrote: The AFS module you should buy depends on the rear leveling sensor and the bixenon headlights you have purchased. Also of other factors like the brakes system installed (ABS, ESP).
oh wow. i didnt know that. so is there any issue if i buy the complete set from kufatec and buy bixenon somewhere else?
Post
by ciclo » Fri Oct 20, 2017 5:23 am
The usual thing is that the parts are compatible ... but it always must be checked in the ETKA. Problems arise when people buy cheap, repaired or second-hand parts, something very common.
rdasadia
Post
by rdasadia » Sun Jul 01, 2018 2:33 pm
@ciclo
I have just installed the MIB Discover Media Headunit in my Polo along with a 8K OPS which has the moving lines interface.
But the ops is not working.
The most important issue is that I cannot get maps working on the unit. Can you help how to put india map on the unit.
I tried with Discover Care Software but no luck here.
Even Android auto won't work on the unit.
Sunday,01,July,2018,16:27:02:58997
VCDS Version: 18.5.2.0 (x64) HEX-NET CB: 0.4427.4
Data version: 20180518 DS291.0
www.Ross-Tech.com
VIN: MEXA16604GT072590 License Plate: ROHAN
Mileage: 18620km-11569mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 44 56 5F 65 77
VIN: MEXA16604GT072590 Mileage: 18620km-11569miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: 00000000000000
Coding: 00250056232400080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
VCID: 6D9229D8BC778B2380-8038
Readiness: 0110 0101
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6561
Revision: 00043014 Serial number: CU501511017434
Coding: 0000020
Shop #: WSC 57779 002 1048576
VCID: 3A38D28475B9EC9B55-806E
Part No SW: 6R0 907 379 BH HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422A03C2461924724251C0800908
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0542717884C7536368-8050
Serial number: 05061504651234
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EB01E94E11100BB29-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41CAA568D86FBF4314-8014
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 352161294
Coding: 3AB02BB848B30000013806917CEB9E90BAC067FF600D30C1200000030000
Shop #: WSC 51200 002 104857
VCID: 2A18E2C445195C1B25-807E
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 271115 03 37 0059
Coding: 0730DD
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 020 2551
Serial number: 13102848151112221545
Coding: 050008
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 020 2551
Serial number: 13202849151112235703
Coding: 050008
Subsystem 4 - Part No SW: 13 202 849 15 HW: 132 028 491 51
Component: RLS 271115 03 37 1122
Serial number: ˇ132028491511122357
Coding: 353730
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 019 1552
Serial number: 13202728151109234823
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 019 1552
Serial number: 13202729151110091329
Coding: 020000
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 228
Mileage: 18629 km
Time Indication: 0
Date: 2018.07.01
Time: 16:23:46
02746 - Bulb for Daytime Running Light; Right
Fault Priority: 3
Fault Frequency: 1
Reset counter: 228
Mileage: 18629 km
Time Indication: 0
Date: 2018.07.01
Time: 16:23:46
Address 10: Park/Steer Assist (J446) Labels:. 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 64931721802185
Coding: 0000000000
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: N/A
VCID: 373ECBB08EABF1F3AA-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VW25)
2 Faults Found:
13636352 - ROD - Unknown Error Code
- 00 [009]
[Steuerger‰t f¸r Reifendruck¸berwachung: keine Kommunikation]
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 228
Mileage: 18629 km
Date: 2018.07.01
Time: 16:23:48
12718592 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 18629 km
Date: 2018.07.01
Time: 16:23:48
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW012EG31
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 49DABD48E85F7703CC-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 141E01
Shop #: WSC 12345 123 12345
VCID: 47DEBB70FE4B8173DA-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002300
VCID: 689C58CC9B95AE0BF3-803C
Component: IMMO H05 0805
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A9822C48D999C1BE5-803E
Address 37: Navigation
Cannot be reached
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 41CAA568D06FBF4314-8014
Address 56: Radio
Cannot be reached
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5C0 035 682 E HW: 5C0 035 682 E
Component: MU-S-N-CN H31 0359
Serial number: VWZAZ2S5285330
Coding: 02140105FF00000011150001001028001F0100D400200100C6
Shop #: WSC 19460 666 12345
ROD: N/A
VCID: 250211F82407736308-8070
No ASAM data for: "EV_MUStd4CTSAT" (VW25)
9 Faults Found:
1555 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 18629 km
Date: 2018.07.01
Time: 16:23:47
15360256 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 4
Fault Frequency: 1
Reset counter: 228
Mileage: 18629 km
Date: 2018.07.01
Time: 16:23:48
2565 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 4
Fault Frequency: 1
Reset counter: 228
Mileage: 18629 km
Date: 2018.07.01
Time: 16:23:48
1564 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 4
Fault Frequency: 1
Reset counter: 228
Mileage: 18629 km
Date: 2018.07.01
Time: 16:23:47
7178 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 18629 km
Date: 2018.07.01
Time: 16:23:50
7194 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 18629 km
Date: 2018.07.01
Time: 16:23:50
0001 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 18629 km
Date: 2018.07.01
Time: 16:23:48
0003 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 18629 km
Date: 2018.07.01
Time: 16:23:48
1637 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 4
Fault Frequency: 1
Reset counter: 228
Mileage: 18629 km
Date: 2018.07.01
Time: 16:23:48
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 30000000054715
ROD: EV_RDKBERU30_005.rod
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:20, VBatt start/end: 13.5V/13.5V)-----------
Posts: 6685 Joined: Fri Nov 14, 2014 2:14 pm
Post
by iichel » Sun Jul 01, 2018 4:07 pm
Wrong PDC ECU... you need 7E0 919 475 L (for example)
I think you should also deselect 37 and 56 and 77 from the gateway, to replace them with 5F (already selected).
rdasadia
Post
by rdasadia » Sun Jul 01, 2018 6:54 pm
Thank you @iichel
But the Chinese seller said it will work perfectly with 6R polo and said they have tested it in china.
Paid a lot for this module and the headunit.
Please help make them work.
Post
by iichel » Sun Jul 01, 2018 7:13 pm
I'm afraid it isn't possible. You'll need a different PDC module.
rdasadia
Post
by rdasadia » Sun Jul 01, 2018 7:18 pm
What about the Headunit,
Android Auto and CarPlay is not working.
Also how do I make navigation work on it.
The unit came with china maps and that worked perfectly but when I tried to load india maps its not reading them.
Also the unit has a cracked firmware to bypass the component protection.
