Willni wrote: Sun Jun 25, 2017 11:44 am
Nice
, should paint those calipers takes away from the alloys
Thanks yes is great idea
little work and good effect.
hi
I have made tooday rewiring for bcm max and xenon instalation with drl i have some problems....
After replace bcm to 7H0 937 090 B on model year A
1: windows not working via door switch only via remote controll
2: when made electric bridge in relay headlights all time is on when keys remowed and car is closed
3: no comunication with instrument cluster ( blinkers working but no visable on instrument cluster , no sound from blinkers)
4:DRL only working when manualy change to drive lights via light switch , or when made electric bridge on relay (togheter with xenon only not alone)
one year ago i have made retrofit on another polo witheout problems , now i dont have any idea.....
coding of bcm and some errors...
Address 09: Cent. Elect. Labels: 7H0-937-08x-09.clb
Control Module Part Number: 7H0 937 090 B HW: 7H0 937 090
Component and/or Version: BCM PQ25 Max4 H74 0712
Software Coding: 3CB02BB808E3240092300ED16E2B0CD0FA8067FF60851041200000010000
Work Shop Code: WSC 02310 790 00105
VCID: 2D4F295B2D11C66A84A6279-8079
4 Faults Found:
03433 - Terminal 30 for Backup Lights and Adaptive Lights
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 6
Time Indication: 0
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
01516 - Terminal 30; Left
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 6
Time Indication: 0
00927 - Terminal 30 (Right)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 6
Time Indication: 0
Many thanks for any support
this is old auto scan on 087B BCM
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BH HW: 03C 906 024 BH
Component: CGGB MM4HV G 8327
Revision: --H09--- Serial number:
Coding: 0000071
Shop #: WSC 00060 259 90613
VCID: 6524609B6C6E953A56C80C-515F
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 AC HW: 6R0 907 379 AC
Component: ABS8.2 front H04 0001
Revision: --------
Coding: 200228E3016E00B8042714E380D500000200
Shop #: WSC 02069 000 00000
VCID: 7FE8D2F3EEF2E8EABCC42E-802B
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 A HW: 6R0 820 045 A
Component: Climatic 23 0500
Revision: 00 09 23
VCID: 2CB2D5BF4F04A7724986B1-8079
3 Faults Found:
16372 - Control Module; Unspecified Internal Error
014 - Defective
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 1386 km
Time Indication: 0
Date: 2009.10.17
Time: 10:00:44
01317 - Control Module in Instrument Cluster (J285)
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 1
Time Indication: 0
00457 - Control Module for Network (J519)
Fault Priority: 6
Fault Frequency: 1
Reset counter: 243
Time Indication: 0
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 B HW: 6R0 937 087 B
Component: PQ25 BCM H08 0025
Revision: BF008001 Serial number: 9955A157090576
Coding: 3CB02BB808A10000003800003D2B0CD000C0000F608400002000
Shop #: WSC 124697 483 00190
VCID: 3C92E5FFBF6437F2D966C1-8069
Subsystem 1 - Part No SW: 6R0 959 801 H HW: 6R0 959 801 H Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 0803
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 802 K HW: 6R0 959 802 K Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 0803
Coding: 08BC30
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0033
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 B HW: 6R0 959 811 B
Component: J388__TSG_HL 002 0803
Coding: 08BC32
Subsystem 5 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Coding: 08BC32
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag005 H09 0018
Revision: -------- Serial number: 003DW003SVR8
Coding: 003035
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 426E9B07DD80490293AA8F-8017
Crash sensor for side airbag; driver side:
Serial number: 3572SRB400009028F12
Crash sensor for side airbag; front passenger side:
Serial number: 3582SRB400008F44B9EO
Crash sensor for side airbag; rear; driver side:
Serial number: 3516GRB402F968JOLJN4
Crash sensor for side airbag; rear; passenger side:
Serial number: 3526GRB402J968JP8446
2 Faults Found:
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 1
12674816 - Immobilizer Control Module
U0167 00 [008] - No Communications
Fault Priority: 6
Fault Frequency: 1
Reset counter: 243
Part No SW: 6R0 920 860 B HW: 6R0 920 860 B
Component: KOMBI H23 0110
Coding: 140A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3380CEC3923AF08A083C62-8067
1 Fault Found:
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
U0056 00 [008] - Performance
Fault Priority: 6
Fault Frequency: 1
Reset counter: 243
Mileage: 74439 km
Date: 2017.06.13
Time: 12:58:21
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 B
Component: GW-K-CAN TP20 0025
Coding: 002200
VCID: 700A01CFA3AC8392355E85-8025
1 Fault Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Component: IMMO H23 0110
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10150
Shop #: WSC 00000
VCID: 2EB6DFB77918416267F2AB-807B
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 156 B HW: 5M0 035 156 B
Component: Radio H21 0056
Revision: R0000000 Serial number: VWZAZ1I8504741
Coding: 0000020002
VCID: 28BA29AF5BFC8B52ADAEED-807D
1 Fault Found:
Fault Status: 00110100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 1
Mileage: 74439 km
Time Indication: 0
Date: 2011.11.04
Time: 00:22:45
End-------------------------(Elapsed Time: 02:40)--------------------------
new auto scan new module 090
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 10 15 17 19 25 44 56 77 0B
04-Steering Angle -- Status: Sporadic communication error 1000
10-Park/Steer Assist -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Not registered 0011
Address 01: Engine
Cannot be reached
Revision: --------
VCID: 7FE8D673EEF2E8EABCC42E-802B
1 Fault Found:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 47
Mileage: 0 km
Time Indication: 0
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x30E6
Hex Value: 0x139E
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Revision: 00 09 23
VCID: 2CB2D13F4F04A7724986B1-8079
3 Faults Found:
014 - Defective
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 1386 km
Time Indication: 0
Date: 2013.09.11
Time: 10:00:44
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 9
Reset counter: 8
Mileage: 0 km
Time Indication: 0
013 - Check DTC Memory
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 7
Mileage: 0 km
Time Indication: 0
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 0571 207130625
Coding: 3CB02BB808F32400923008D16E2B0CD0FA80670F60051041200000010000
Shop #: WSC 02310 790 00105
VCID: 2DB4DC3B741EAE7A5EF8A4-8079
Coding: 08BC30
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 811 B HW: 6R0 959 811 B
Coding: 08BC32
Subsystem 7 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Coding: 08BC32
7 Faults Found:
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 11
Reset counter: 8
Time Indication: 0
01134 - Alarm Horn (H12)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Time Indication: 0
000 - -
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Time Indication: 0
00901 - Back-Up Lamps
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Time Indication: 0
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 17
Reset counter: 8
Time Indication: 0
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 17
Reset counter: 8
Time Indication: 0
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 48
Time Indication: 0
Address 10: Park/Steer Assist Labels:
VCID: 554454DB3C0E56BAC668FC-9635
Coding: 003035
ASAM Dataset: EV_ A01001
ROD: N/A
VCID: 426E9F87DD80490293AA8F-8017
Subsystem 1 - Serial number: 3572SRB400009028F12
Subsystem 2 - Serial number: 3582SRB400008F44B9EO
Subsystem 3 - Serial number: 3516GRB402F968JOLJN4
Subsystem 4 - Serial number: 3526GRB402J968JP8446
No ASAM data for: "EV_" (VW25)
2 Faults Found:
12670208 - ROD - Unknown Error Code
- 00 [008]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 47
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12674816 - ROD - Unknown Error Code
- 00 [008]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 47
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Part No SW: 6R0 920 870 F HW: 6R0 920 870 F
Component: KOMBI H04 0709
Coding: 140A01
Shop #: WSC 00788 648 00255
VCID: 389AFD6F8B5C13D23D0E3D-806D
1 Fault Found:
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 8
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
Coding: 042200
VCID: 700A054FA3AC8392355E85-8025
4 Faults Found:
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
00778 - Steering Angle Sensor (G85)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 47
Time Indication: 0
03075 - Parallel Parking Assistance Control Module (J791)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Time Indication: 0
00381 - Databus Instrument Cluster
Fault Priority: 1
Fault Frequency: 18
Reset counter: 8
Time Indication: 0
Component: IMMO H04 0709
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6A3E1727857071427B1AC7-803F
Coding: 10150
Shop #: WSC 00000
VCID: 2EB6DB377918416267F2AB-807B
1 Fault Found:
49-10 - No Communications - Intermittent
Coding: 0000020202
VCID: 28BA2D2F5BFC8B52ADAEED-807D
1 Fault Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 7
Mileage: 0 km
Time Indication: 0
Address 0B: Sec. Air Heating Labels:
VCID: 554454DB3C0E56BAC668FC-95D1
fuses B15 and B16 i used for MFSW and G85 retrofit beacose have soon pins.... (on old BCM work all fine)
What I have to do with instalation:
Rewiring for BCM MAX from ciclo PDF.
58B - cut orginal wire and split to 73A/2
38B - cuto orginal wire and split to 73B/2
34B - split to new wire 73A/62
new wires from:
58B to 73A/63
38B to 73B/68
dimmer :
cut original t6/3 - add new wire from t6/3 to 73B/1
light switch:
cut original t17/3 - add new wire from t17/3 to 73B/29
cut original t17/9 and split to t73A/6
cut original wire t17/16 and split to 73B/7
new wire from t17/16 to 73A/45 ( original instalation used this pin from t17/14 so i cut this wire in light switch and split to t17/16)
new wire t17/9 to 73B/43
t17/7 is still in light switch not cutted.
and thats all , no bridge in relay 331 beacose lights is all time on , on any position in light switch , witheout ignition.
Best regards Chriss
