Subject matter is polo 6r 1.2 3 cylinder 12 valve.
Hi I've recently replaced my timing chain and checked that it is perfectly in time using the VW locking tools, however, after the lllleeeeeeennnnnnggggtttthhhhyyyy reassembly the car won't start. It appears to have a severe misfire.
Compressions are high and damage to valves has been checked using a boroscope no damage is found. Injectors are fully operable and getting 3 sparks confirmed by visual test.
My question is if the VW locking tools can be inserted into the cam and crankshaft is there a chance of incorrect timing?
Due to the nature of the VW locking tools the crankshaft censor has to be removed is it possible it could have been damaged and failed. Would it cause these symptoms.
Any other ideas are welcomed as I'm at a loose end.
Thanks in advance any help would be greatly appreciated.
HELP !!! My car won't start after timing chain replacement
Jordan_Owen1
- Drives: 6r 1.2
Re: HELP !!! My car won't start after timing chain replacement
Sounds like the timing is out
