I left the report open but Alex closed it. I cannot find the username. mcp.php?i=logs&mode=topic_logs&t=58703& ... 857cf8a641
Ok, then everything is fine. 8)
akshay922
Drives: 6C GT TSI
Post by akshay922 »
Shishir wrote: Wed Sep 06, 2017 5:57 am
akshay922 wrote: Sat Sep 02, 2017 8:10 am Hi Ciclo/Graaja/Patil?Gannu
You are such an inspiration!
I'm located in India and contemplating the below headlights for my polo 6c:
http://www.vagtune.in/volkswagen/vw-lig ... 6rx-detail
I'm not sure if its worth the price, will it be plug and play and how are DRL's going to function and finally pro's and cons of buying this.
If anyone can shed some light on this, will be appreciated.
Hi akshay922,
I would advise against this headlight unit from VagTune. I received very poor service from them(I am based out of Bangalore). In the end, swapped these headlights to OEM Valeos`. They are brighter than these headlights and are superior in quality.
Best,
Shishir
Shishir wrote: Wed Sep 06, 2017 5:57 am Hi Akshay,
1. Warranty depends on your relationship with your respective dealership. I am taking my chances. They claimed that my warranty would be void even on aftermarket Roots horn. :D
2. Yes, it was plug and play
3. Yes
4. I did not get LED DRL activated but you can ask the installer for the same(they come on with headlights). Cornering lights were left untouched so they continue to work as they worked before.
5. You may contact German DNA for these headlights. You can find their contact details on Facebook and give my reference (Shishir, Grey GT TSI). They are based out of Bangalore.
On a side note, switching off of DRL when indicators are turned on, will not work because of BCM issue but it was not a deal breaker for me.
Best,
Shishir
Sorry for the late reply Shishir.
I did talk to your reference for headlights in Banglore, turns out that he does custom coding and custom wires must be drawn from BCM.
Also, he did tell me he will have to cut and splice some wires which virtually cant be detected, "THIS ISNT PLUG AND PLAY" and he was exteremly confident that this wont cause warranty issues!!
Lastly, Once you do this modification and you want to go back to OEM you will have to get it done at his place, you cant do it at home or anywhere else, since his custom coding has to be changed.
firegrafik wrote: Sat Sep 16, 2017 3:25 pm
iichel wrote: Sat Sep 16, 2017 9:51 am very interesting. i need to find a BCM 7E0 B with LED headlight support :D :D
I bought used 7E0937090B from T6 with LED headlights (but still haven't installed it). Anyway if someone could teach me how to read/write the EEPROM dump using VCP from that my BCM, and it could be possible to make any 7E0937090B to be compatible with LED headlights by writing that dump.
I haven't forgotten this, but so far I've failed in my attempts to read eeprom from bcm with my vcp cable.
Adam87
Drives: T5.2
Post by Adam87 »
I couldn’t either [emoji848], closest I got was it started to do something and went crazy, interior lights flashed on/off cluster started beeping and lights flashing then eventually stopped [emoji15] ....... I didn’t try again [emoji23]
iichel wrote: Fri Sep 22, 2017 3:55 pm .... but so far I've failed in my attempts to read eeprom from bcm with my vcp cable.
I also tried it and it didn't work.
Direct TPMS 8)
drive2 your dreams :wink:
Everything works like a charm. :lol:
My BlueGT IC: (It's not my new GTI IC)
Before
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 00788 219 00200
VCID: 3502C0673BC17907FE-8060
After
Part No SW: 6R0 920 870 F HW: 6R0 920 870 C
Component: KOMBI H05 0709
Coding: 140E01
VCID: 38F9CE663FC6630A0E-806C
Saturday,23,September,2017,20:27:05:06516
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: Direct TPMS OK!!
Mileage: 27970km-17379mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage: 27970km-17379miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   VCID: 6A37620CF7C037E89E-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 02CF32C45BC8A7905E-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X_VW25.rod
   VCID: 7E433A482724CF7C3E-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38F9CE6637C6630A0E-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 122170091
   Coding: 3CB02FBF48E32400B3380F916CEB9FDCDAC0672F600D30D0200000030800
   VCID: 2BF4E441E387BDB196-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E03BA8827E44F3C3E-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A17A2AC7720F7889E-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Coding: 140E01
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002200
   VCID: 68296EF6F7D643DA8E-803C
Address 20: High Beam Assist. (J844)       Labels:. 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   ROD: N/A
   VCID: 2EF3DA58E7B4AF4CBE-807A
No ASAM data for: "EV_HighBeamAssisAU316" (VW25)
   Component: IMMO          H05 0709
   Shop #: WSC 00000 000 00000
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2AF7E24CFF80B7A89E-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 37F8CC6533C3650DF6-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2FF0DC5D87AB9555B6-807A
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77384C253B03E54DF6-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 40000000050821
   ROD: EV_RDKBERU30.rod
   VCID: 37F8CC653BC3650DF6-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B04C4712BF75D2116-806E
End-------------------------(Elapsed Time: 04:27)--------------------------
Parts:
It can also be 7E0937090B.
http://www.ebay.es/itm/Nuevo-original-V ... 3641.l6368
Installation:
Sensors/valves
TPMS unit
Wiring
Editing Parameters:
You can use this editor :arrow: http://htmlpreview.github.io/?https://r ... rator.html
Or this editor :arrow: https://skodapilot.com/rdkseditor/
I have used both, but finally I used the RDKS editor from Skodapilot. Many thanks to its creator (a big hug).
Image :)
More info:
viewtopic.php?f=56&t=58703&start=2835#p516356
viewtopic.php?f=56&t=58703&p=517343#p517336
viewtopic.php?f=56&t=58703&start=3390#p521807 Thank you very much to both!
viewtopic.php?f=56&t=58703&start=3450#p522430
viewtopic.php?f=56&t=58703&start=3630#p524720
Thanks again to all for your participation in this adventure.
Of course, even without Gra_high on my 6R. :twisted:
it's not october 11 yet. that means you figured it out with your original cluster?
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
Congratulations, Fernando! Great work!
iichel wrote: Sun Sep 24, 2017 10:49 am it's not october 11 yet. that means you figured it out with your original cluster?
Exactly iichel.
On October 11, more ...
firegrafik wrote: Sun Sep 24, 2017 1:53 pm Congratulations, Fernando! Great work!
Many thanks firegrafik, were 00:14:09 very exciting minutes with the VCP ... Image :lol:, as you can see in the video image.
(left bottom corner of image)
Everything was perfect, no hassle. In case you want to do it. :wink: (with the proper patches for the 6R Sedan)
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Speechless.
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
Excellent work Fernando...[emoji1303]
Scotty_boy vw
Post by Scotty_boy vw »
Hi Ciclo I'm new on here and was wondering if you could help me with my retro fit of folding mirrors to my 6c polo.
I will be adding the extra wiring thats needed but what I'm really looking to do is add the folding on remote if it can be done?
was wondering if you could help me with this please.
regards
scott
Pm me please :D
Maybe a stupid question, but I'm wondering two things...
1) Why does everyone want to be helped by ciclo? I know he's probably the best, by some distance, but there are other people here too that know a thing or two. And he's a bit busy (celebrating holidays and stuff).
2) Why does everyone want to be helped by PM? The point of a forum is to share stuff in public. The reason why this topic is probably one of the most popular in Polo history is because everything is explained in detail, in a public way. Everyone can read, everyone can add.
Scotty_boy vw
iichel wrote: Mon Sep 25, 2017 7:51 pm Maybe a stupid question, but I'm wondering two things...
The reason i asked ciclo is because he has done this mod so i was hoping he could help although if someone else can help with this then that would be great also.....
The reason i asked to be pm'd is so his build thread would not be clogged up with things like this happening!!!!!
scott
Locked
