Steering angle sensor
Cheesebrains
Drives: 6R r line
Post by Cheesebrains »
Can anyone point me in the direction of some instructions to reset the steering angle sensor?? Also read somewhere that it can be bypassed if it becomes a regular thing??!
alexperkins
Site Admin
Re: Steering angle sensor
Post by alexperkins »
It’s a VCDS calibration job to reset this. It can’t be bypassed either. It’s used for all sorts of things in the car
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post by Jay-Jay »
With VCDS go into ABS Unit.
Click on "Security Access" and type "40168".
Make sure your steering is perfectly straight.
Then go into "Basic Setting", type Group "060" and click "Go". You'll see the program will inform you about the recalibration process. It will take only few seconds.
Cheesebrains
Drives: 6R r line
Tried through vcds to reset/calibrate this just now but says "aborted safety reasons" any ideas??
I did change the sensor for a new 1 but didn't think it needed coding or is this the reason why it's saying this??
EdgardoRodriguez
Drives: other
Post by EdgardoRodriguez »
Cheesebrains wrote:Tried through vcds to reset/calibrate this just now but says "aborted safety reasons" any ideas??
Hello!
Have you solved this safety reasons issue ? I am through the same now..
Enviado desde mi iPhone utilizando Tapatalk
