Smoke and smells burnt when motor stressed
Franciswat
Drives: 6R 1.6 Bifuel
Post by Franciswat »
Hi guys,
happened 2 times to see little of smoke (cigarette like) from lower part of
engine compartment and smells burnt which invades the cockpit. :cry:
That occurred to:
- go out slowly from a sloping ramp (to avoid car hits ground)
- park along a steep descent
In both cases I think motor was stressed because I had to use 1st/reverse gears with high rpm to move quite sloowly.
Smoke burnt need at least 1 hour to disappeared. :|
Oil changed with VW long life 1 month ago.
Why you think that happened?
PS Car has 60k kilometers or 37k miles.
fivelittlefish
Drives: 2016 GTI
Re: Smoke and smells burnt when motor stressed
Post by fivelittlefish »
Sounds like a burnt clutch.
Franciswat
In 2 years happened 2 times and only probably for excessive clutch stressing. :roll:
Ricmondo
Drives: Polo Blue GT
Post by Ricmondo »
If you were using high revs to move quite slowly you must have been slipping the clutch which will create the smell of burning and often smoke, the bonus will be a worn out clutch. DONT DO IT! Keep the revs down and clutch engaged, alternatively start saving up to have a new clutch fitted and to pay for taxis whilst the garage repace the dead clutch.
Franciswat
As I said that happened few times in 2 years. Now that I know the problem I'll be carefull in those rare conditions.
