Hi Peter...
working on it... but you must be very patient.benzinkopf wrote: Thu Oct 19, 2017 4:22 pm anybody knows what adaptation channel 73 bcm does?
Ive accidentally changed adapt channel 69 from 0 to 1. Turned out its switching off the dimmer switch for interior buttons and make the cluster full brightness.![]()
Beware with channel 69.
https://youtu.be/i3jI3RrMsVI?t=43sciclo wrote: Thu Oct 19, 2017 8:57 pmworking on it... but you must be very patient.benzinkopf wrote: Thu Oct 19, 2017 4:22 pm anybody knows what adaptation channel 73 bcm does?
benzinkopf
- Drives: 1.2TSI 105HP DSG7
im patient right now that i decided i want to have full label of the adaptation. any list to start with?
benzinkopf
The only list available is what we know from VCDS, VCP, and the tests that a few do (very few).benzinkopf wrote: Fri Oct 20, 2017 4:30 am im patient right now that i decided i want to have full label of the adaptation. any list to start with?
Welcome to the BCM PQ25 world.
Some time ago I was thinking about doing it, but it would create confusion...
It already is enough with the horrible codings that are often seen ...
Original Xhorse Iscancar VAG MM-007 OBD2benzinkopf wrote: Fri Oct 20, 2017 4:30 amwow. it seems like you dont need to visit the dealer for cluster swap? [emoji848]ciclo wrote:Meanwhile I bought another diagnostic tool, etc ...
[img]https://i62.servimg.com/u/f62/18/94/39/39/_5710.jpg[/img
To walk through other spaces.
So I need (read to the end)
https://youtu.be/1hdZeOE0zuo?t=4m29s
Just tryin' to get it right.
How many times did VW have the opportunity to do it for me? Ten?
Now is my turn.
peter_dk25
- Drives: Blue GT
Hi Fernando - It's been a while since last
I am still here...
sunilsoft
- Drives: Polo 6R Tdi 2015
Hi Ciclo,
This is Sunil from India,
Brilliant Mods.
Ciclo I need help regarding folding mirrors. I have installed them by following k418 module method.
The mirrors auto fold and auto unfold when we use the remote to lock and unlock the car.
However I wasn't able to fold the mirrors using the folding mirror switch.
I have connected it to the relay pin 86 via pin 26 of driver side door and then to pin 8 of the folding mirror wire connector.
I am little confused which is the connector where the wire to pin no.8 should be connected. Is it the connector that connects to the windows regulator motor?
I have checked the wire by grounding it with metal and it folds the mirror. That means the circuit to the relay and k418 works.
The only problem is with the switch. I guess I am not connecting the pin 8 to the right connector.
Brilliant Mods.
Fernando, been reading last posts and thank you for the nice words.
In my case the Acivation of GRA_high wasn't enough because sending GRA info out of Engine was disabled. So in my case both had to be activated, the GRA-High Flag and enable CCS "output" message.
It exists the possibility that the engine flash was never developed to deliver CCS message, and in that case this can't be activated. If same controller is used in Golf then you are sure it can be activated.
Recently I connected my old Black and White cluster to the car and CCS icon appeared imediatly, so no doubt this is only ECU related.
If you want some help with investigations I will help you the best I can!
Hi sunilsoft, welcome.sunilsoft wrote: Fri Oct 20, 2017 8:25 am Hi Ciclo,
Brilliant Mods.
You must insert the pin into the mirror switch connector.
Thanks Ruben, we have to wait at least a month (tools, ECUs, etc), will be in touch by email, I want you to know the whole process with my Simos.n4s wrote: Fri Oct 20, 2017 10:13 am If you want some help with investigations I will help you the best I can!
peter_dk25 wrote: Fri Oct 20, 2017 6:36 amHi Fernando - It's been a while since last
I am still here...
What is the current BCM of your BlueGT? (Ref.)
benzinkopf
need a little favor. anyone knows if these mounting brackets available in the market? where can i find one? partnumber?
