Upgrading BCM (body control module) in my polo 6r
Vinayak185
Drives: 6R Polo GT 1.6 TDI
Re: Upgrading BCM (body control module) in my polo 6r
Post by Vinayak185 »
Hi, I had installed auto dimming mirror and rain sensor in my polo. Rain sensor is working fine but rain closing isnot working. I tried changing coding but no luck. How to make it work?? Need help. Thnx
Sent from my Moto G (4) using Tapatalk
Autoscan.
Vinayak185
Here's the Autoscan
Friday,13,October,2017,15:43:40:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWC14608ET069582 License Plate: 5974
Mileage: 55587 Repair Order:
Chassis Type: 60 (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
Address 01: Engine (J623-CLNA) Labels: None
Part No SW: 03L 906 023 NT HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9971
Revision: --H33--- Serial number: 00000000000000
Coding: 00110016030500080000
Shop #: WSC 36792 002 104857
ASAM Dataset: EV_ECM16TDI02103L906023NT 003012
ROD: N/A
VCID: 8501F79F04D47D36275-80D0
No ASAM data for: "EV_ECM16TDI02103L906023NT" (VN75)
Readiness: 1000 1000
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 BF HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0001
Serial number: --------------
Coding: 60DD2763412918C90619E471825318020000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 8305E9870AE04306091-80D6
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 408FA68BD376181ED43-8015
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H78 0725
Revision: B9078001 Serial number: 9000 238150833
Coding: 38B82FBF48A10003013800C034AA1E90F00000FF60000000200000000000
Shop #: WSC 12345 123 12345
VCID: 2F6DF5377EE897663D9-807A
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 260215 03 37 0059
Coding: 028877
Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5550
Coding: 010000
Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH
Coding: 010000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Coding: 020000
4 Faults Found:
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 55587 km
Time Indication: 0
Date: 2009.14.24
Time: 15:38:22
03432 - Activation of Right Parking Light
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 55587 km
Time Indication: 0
Date: 2009.14.24
Time: 15:38:22
01516 - Terminal 30; Left
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 33
Mileage: 55587 km
Time Indication: 0
Date: 2009.14.24
Time: 15:38:23
00927 - Terminal 30 (Right)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 33
Mileage: 55587 km
Time Indication: 0
Date: 2009.14.24
Time: 15:38:23
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00PX2AZ
Coding: 003036
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4999BBAFE84CD95603D-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 140E00
Shop #: WSC 11802 938 12345
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 479DBD97FE582F26159-8012
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-19.lbl
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H78 0725
Revision: B9078001
Coding: 002300
VCID: F0EFB64B2356489EE43-80A5
Component: IMMO H04 0805
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EADBA4230D8AB24EAA7-80BF
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-44.clb
Part No SW: 6RF 909 144 K HW: 6RF 909 144 J
Component: EPS_ECU H44 0401
Coding: 0000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK.rod
VCID: 54A79ADB3F0E94BE60B-8001
Address 56: Radio (J503) Labels: None
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 09475GD0078320
Coding: 0000040004000A
Shop #: WSC 00081 790 00133
VCID: 4581B79FCC543D36E75-8010
4 Faults Found:
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 33
Mileage: 55587 km
Time Indication: 0
Date: 2009.14.24
Time: 15:39:58
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 33
Mileage: 55587 km
Time Indication: 0
Date: 2009.14.24
Time: 15:39:58
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 33
Mileage: 55587 km
Time Indication: 0
Date: 2009.14.24
Time: 15:39:58
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 33
Mileage: 55587 km
Time Indication: 0
Date: 2009.14.24
Time: 15:39:58
End ---------------------------------------------------------------------
Coding: 028877 :arrow: 0628DD (try it) ... in any case, this is a good coding for your RLS.
Vinayak185
Ok thanks
Vinayak185
Error 31: Request out of range - Coding Rejected.
This error is coming. :(
Vinayak185
Will try using another version and cable.
Vinayak185
Hi ciclo. I recieved damaged cruise control stalks unfortunately and now I need them again. I want to get them from u this time. Can u please arrange same stalks u showed me?
:shock:
viewtopic.php?f=62&t=70394#p524890
Vinayak185 wrote: Wed Oct 25, 2017 4:33 pm same stalks u showed me?
That is materially impossible in this universe ... you missed the best of your opportunities.
Vinayak185
thank u sir, glad that ur helping me. I will upload the required photos soon. :)
I have subscribed to your topic.
Do not rush to take the images, do it calmly, I will receive the notification of your new post. :wink:
Vinayak185
hi ciclo sir, I have taken all the images. sending you now. pls see
Heres the autoscan I took today. unfortunately I don't have latest vcds version.
Wednesday,16,December,2020,14:15:24:62939
VIN: WVWC14608ET069582 License Plate: MH
Mileage: 85077 Repair Order: 1
Coding: 00110016032500080000
ROD: N/A
Revision: V0000000
Coding: 38B82FB848A10003013800C03CAA1E90F08000FF60000000200000000000
Coding: 028877
Coding: 010000
Coding: 010000
Coding: 240000
Coding: 020000
Coding: 020000
4 Faults Found:
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 85077 km
Time Indication: 0
Date: 2045.14.19
Time: 14:03:21
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 85077 km
Time Indication: 0
Date: 2045.14.19
Time: 14:03:21
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 85077 km
Time Indication: 0
Date: 2045.14.19
Time: 14:03:21
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 85077 km
Time Indication: 0
Date: 2045.14.19
Time: 14:03:21
Coding: 003036
Coding: 140C00
Revision: B9078001
Coding: 002300
Coding: 0000
Coding: 0000044004000A
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 156
Mileage: 85076 km
Time Indication: 0
Date: 2045.14.18
Time: 19:41:10
I have given all the details if anything is missing please let me know. I will send it.
BCM max
BCM max
bcm max.jpg (787.17 KiB) Viewed 4871 times
after removing fuse tap cables..
fuse box.jpg (3.96 MiB) Viewed 4871 times
fuse box. there are 2 fuse tap cables I used for powering cruise control, auto dimming mirror and rain sensor.
fuse box 1.jpg (3.07 MiB) Viewed 4871 times
Relay Carrier
Relay Carrier
relay carrier.jpg (5.5 MiB) Viewed 4871 times
HL adjust level switch 2
dimmer switch.jpg (4.04 MiB) Viewed 4871 times
HL adjust level switch 1
dimmer switch 1.jpg (4.17 MiB) Viewed 4871 times
my car has only headlight level adjuster.
dimmer switch front.jpg (568.41 KiB) Viewed 4871 times
Healight switch connector back
light connector 3.jpg (3.36 MiB) Viewed 4871 times
Headlight switch connector pin 1 to 9
light connector 1.jpg (3.84 MiB) Viewed 4871 times
Headlight switch connector pin 10 to 17
light connector 2.jpg (3.99 MiB) Viewed 4871 times
Hi Vinayak185,
Thank you very much for the autoscan and the images, everything is fine this way.👍
We will make those 2 tap cables disappear with the new wiring adaptation, we will make it as OEM as possible.
Please be patient while I prepare your new wiring looms, it will take some time (longer than usual) until everything is ready to be shipped.
I will try to do it as soon as possible, but you must be patient.
You need to get/buy the AUTO light switch and a headlight level regulator with Dimmer, please ask Patil where he got them, I can't provide these switches for a long time anymore.
Own thoughts :lol:
This is the second time the original T17/11 wire is missing from a POLO (IND), ... I will include this necessary wire in the wiring looms.
