Air bag light bypass
Cheesebrains
Drives: 6R r line
Post by Cheesebrains »
I'm getting fed up of the drivers airbag igniter high voltage warning coming up, is there any bypass for this, i.e. Rewire, resistors????
Ricmondo
Drives: Polo Blue GT
Re: Air bag light bypass
Post by Ricmondo »
Probably best to find out the cause of the fault and put it right. Quite apart from it being illegal to drive a car with a defective air bag there is also the little matter of staying alive when some twit drives into you.
+1. Find the cause and fix it.
It will get repaired after the crash surely?
Cheesebrains
Drives: 6R r line
It's not had a crash and I'm going round in circles changing related items and pretty sure it's a fault in the actual seat/side airbag but don't fancy stumping up for either the seat or airbag 😂😂
Step 1: find the fault (i.e. with an OBD diagnostic tool)
Step 2: find the cause (i.e. broken wire, short circuit, broken switch, broken airbag)
Step 3: solve
Cheesebrains
Drives: 6R r line
Thanks for your help 😂😂
alexperkins
Site Admin
Post by alexperkins »
Bypassing the air bag light isn’t the answer. High ignition voltage can actually prevent the air bag deploying in a crash. I wouldn’t want to risk ignoring something that could save my life.
There was a similar issue on mk5 golfs where the connector under the seat caused high resistance and had to by bypassed with crimps under a VW recall
